cs_interface.h
1#ifndef __CS_INTERFACE_H__
2#define __CS_INTERFACE_H__
5 * Main structure for handling of interfaces associating mesh elements
6 * (such as inter-processor or periodic connectivity between cells, faces,
7 * or vertices);
8 *============================================================================*/
9
10/*
11 This file is part of code_saturne, a general-purpose CFD tool.
13 Copyright (C) 1998-2025 EDF S.A.
14
15 This program is free software; you can redistribute it and/or modify it under
16 the terms of the GNU General Public License as published by the Free Software
17 Foundation; either version 2 of the License, or (at your option) any later
18 version.
19
20 This program is distributed in the hope that it will be useful, but WITHOUT
21 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
22 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
23 details.
24
25 You should have received a copy of the GNU General Public License along with
26 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
27 Street, Fifth Floor, Boston, MA 02110-1301, USA.
28*/
30/*----------------------------------------------------------------------------*/
33 * Local headers
36#include "fvm/fvm_defs.h"
37#include "fvm/fvm_periodicity.h"
38
43/*=============================================================================
44 * Macro definitions
46
48 * Type definitions
50
51/*----------------------------------------------------------------------------
52 * Structure defining an I/O numbering scheme
53 *----------------------------------------------------------------------------*/
54
55/*
56 Pointer to structures representing an interface and a list of interfaces.
57 The structures themselves are private, and are defined in cs_interface.c
58*/
59
60typedef struct _cs_interface_t cs_interface_t;
61typedef struct _cs_interface_set_t cs_interface_set_t;
62
63/*=============================================================================
64 * Static global variables
65 *============================================================================*/
66
67/*=============================================================================
68 * Public function prototypes
69 *============================================================================*/
70
71/*----------------------------------------------------------------------------*/
72/*
73 * \brief Return process rank associated with an interface's distant elements.
74 *
75 * \param[in] itf pointer to interface structure
76 *
77 * \return process rank associated with the interface's distant elements
78 */
79/*----------------------------------------------------------------------------*/
80
81int
83
84/*----------------------------------------------------------------------------*/
85/*
86 * \brief Return number of local and distant elements defining an interface.
87 *
88 * \param[in] itf pointer to interface structure
89 *
90 * \return number of local and distant elements defining the interface
91 */
92/*----------------------------------------------------------------------------*/
93
96
97/*----------------------------------------------------------------------------*/
98/*
99 * \brief Return pointer to array of local element ids defining an interface.
100 *
101 * The size of the array may be obtained by cs_interface_size().
102 * The array is owned by the interface structure, and is not copied
103 * (hence the constant qualifier for the return value).
104 *
105 * \param[in] itf pointer to interface structure
106 *
107 * \return pointer to array of local element ids (0 to n-1) defining
108 * the interface
109 */
110/*----------------------------------------------------------------------------*/
111
112const cs_lnum_t *
114
115/*----------------------------------------------------------------------------*/
116/*
117 * \brief Return pointer to array of matching element ids defining an interface.
118 *
119 * This array is only available if cs_interface_set_add_match_ids() has
120 * been called for the containing interface set.
121 *
122 * The size of the array may be obtained by cs_interface_size().
123 * The array is owned by the interface structure, and is not copied
124 * (hence the constant qualifier for the return value).
125 *
126 * \param[in] itf pointer to interface structure
127 *
128 * \return pointer to array of local element ids (0 to n-1) defining
129 * the interface
130 */
131/*----------------------------------------------------------------------------*/
132
133const cs_lnum_t *
135
136/*----------------------------------------------------------------------------*/
137/*
138 * \brief Return size of index of sub-sections for different transformations.
139 *
140 * The index is applicable to both local_num and distant_num arrays,
141 * with purely parallel equivalences appearing at position 0, and
142 * equivalences through periodic transform i at position i+1;
143 * Its size should thus be equal to 1 + number of periodic transforms + 1,
144 * In absence of periodicity, it may be 0, as the index is not needed.
145 *
146 * \param[in] itf pointer to interface structure
147 *
148 * \return transform index size for the interface
149 */
150/*----------------------------------------------------------------------------*/
151
154
155/*----------------------------------------------------------------------------*/
156/*
157 * \brief Return pointer to index of sub-sections for different transformations.
158 *
159 * The index is applicable to both local_num and distant_num arrays,
160 * with purely parallel equivalences appearing at position 0, and
161 * equivalences through periodic transform i at position i+1;
162 * In absence of periodicity, it may be NULL, as it is not needed.
163 *
164 * \param[in] itf pointer to interface structure
165 *
166 * \return pointer to transform index for the interface
167 */
168/*----------------------------------------------------------------------------*/
169
170const cs_lnum_t *
172
173/*----------------------------------------------------------------------------*/
174/*
175 * \brief Creation of a list of interfaces between elements of a same type.
176 *
177 * These interfaces may be used to identify equivalent vertices or faces using
178 * domain splitting, as well as periodic elements (on the same or on
179 * distant ranks).
180 *
181 * Note that periodicity information will be completed and made consistent
182 * based on the input, so that if a periodic couple is defined on a given rank,
183 * the reverse couple wil be defined, whether it is also defined on the same
184 * or a different rank.
185 *
186 * In addition, multiple periodicity interfaces will be built automatically
187 * if the periodicity structure provides for composed periodicities, so they
188 * need not be defined prior to this function being called.
189 *
190 * \param[in] n_elts number of local elements considered
191 * (size of parent_element_id[])
192 * \param[in] parent_element_id pointer to list of selected elements
193 * local ids (0 to n-1), or NULL if all
194 * first n_elts elements are used
195 * \param[in] global_number pointer to list of global (i.e. domain
196 * splitting independent) element numbers
197 * \param[in] periodicity periodicity information (NULL if none)
198 * \param[in] n_periodic_lists number of periodic lists (may be local)
199 * \param[in] periodicity_num periodicity number (1 to n) associated
200 * with each periodic list (primary
201 * periodicities only)
202 * \param[in] n_periodic_couples number of periodic couples associated
203 * with each periodic list
204 * \param[in] periodic_couples array indicating periodic couples
205 * (interlaced, using global numberings)
206 * for each list
207 *
208 * \return pointer to list of interfaces (possibly NULL in serial mode)
209 */
210/*----------------------------------------------------------------------------*/
211
214 const cs_lnum_t parent_element_id[],
215 const cs_gnum_t global_number[],
216 const fvm_periodicity_t *periodicity,
217 int n_periodic_lists,
218 const int periodicity_num[],
219 const cs_lnum_t n_periodic_couples[],
220 const cs_gnum_t *const periodic_couples[]);
221
222/*----------------------------------------------------------------------------*/
223/*
224 * \brief Destruction of an interface set.
225 *
226 * \param[in, out] ifs pointer to pointer to structure to destroy
227 */
228/*----------------------------------------------------------------------------*/
229
230void
232
233/*----------------------------------------------------------------------------*/
234/*
235 * \brief Duplicate an interface set, applying an optional constant stride.
236 *
237 * \param[in, out] ifs pointer to interface set structure
238 * \param[in] stride if > 1, each element subdivided in stride elements
239 *
240 * \return pointer to new interface set
241 */
242/*----------------------------------------------------------------------------*/
243
246 cs_lnum_t stride);
247
248/*----------------------------------------------------------------------------*/
249/*
250 * \brief Duplicate an interface set for coupled variable blocks.
251 *
252 * \param[in, out] ifs pointer to interface set structure
253 * \param[in] block_size local block size (number of elements)
254 * \param[in] n_blocks number of associated blocks
255 *
256 * \return pointer to new interface set
257 */
258/*----------------------------------------------------------------------------*/
259
262 cs_lnum_t block_size,
263 cs_lnum_t n_blocks);
264
265/*----------------------------------------------------------------------------*/
266/*
267 * \brief Return number of interfaces associated with an interface set.
268 *
269 * \param[in] ifs pointer to interface set structure
270 *
271 * \return number of interfaces in set
272 */
273/*----------------------------------------------------------------------------*/
274
275int
277
278/*----------------------------------------------------------------------------*/
279/*
280 * \brief Return total number of elements in interface set.
281 *
282 * This is equal to the sum of cs_interface_size() on the cs_interface_size()
283 * interfaces of a set.
284 *
285 * \param[in] ifs pointer to interface set structure
286 *
287 * \return number of interfaces in set
288 */
289/*----------------------------------------------------------------------------*/
290
293
294/*----------------------------------------------------------------------------*/
295/*
296 * \brief Return pointer to a given interface in an interface set.
297 *
298 * \param[in] ifs pointer to interface set structure
299 * \param[in] interface_id index of interface in set (0 to n-1)
300 *
301 * \return pointer to interface structure
302 */
303/*----------------------------------------------------------------------------*/
304
305const cs_interface_t *
307 int interface_id);
308
309/*----------------------------------------------------------------------------*/
310/*
311 * \brief Return pointer to the periocicity structure associated of an
312 * interface set.
313 *
314 * \param[in] ifs pointer to interface set structure
315 *
316 * \return pointer to periodicity structure, or NULL
317 */
318/*----------------------------------------------------------------------------*/
319
320const fvm_periodicity_t *
322
323/*----------------------------------------------------------------------------*/
324/*
325 * \brief Apply renumbering of elements referenced by an interface set.
326 *
327 * For any given element i, a negative old_to_new[i] value means that that
328 * element does not appear anymore in the new numbering.
329 *
330 * \param[in, out] ifs pointer to interface set structure
331 * \param[in] old_to_new renumbering array (0 to n-1 numbering)
332 */
333/*----------------------------------------------------------------------------*/
334
335void
337 const cs_lnum_t old_to_new[]);
338
339/*----------------------------------------------------------------------------*/
340/*
341 * \brief Copy array from distant or matching interface elements to
342 * local elements.
343 *
344 * Source and destination arrays define values for all elements in the
345 * interface set (i.e. all elements listed by cs_interface_get_elt_ids()
346 * when looping over interfaces of a set.
347 *
348 * \param[in] ifs pointer to interface set structure
349 * \param[in] datatype type of data considered
350 * \param[in] stride number of values per entity (interlaced)
351 * \param[in] src_on_parent true if source array is defined on the elements
352 * defined by ifs->elt_ids, false if source array
353 * defined directly on cs_interface_set_n_elts(ifs)
354 * \param[in] src source array (size:
355 * cs_interface_set_n_elts(ifs)*stride
356 * or parent array size * stride)
357 * \param[out] dest destination array (size:
358 * cs_interface_set_n_elts(ifs)*stride)
359 */
360/*----------------------------------------------------------------------------*/
361
362void
364 cs_datatype_t datatype,
365 int stride,
366 bool src_on_parent,
367 const void *src,
368 void *dest);
369
370/*----------------------------------------------------------------------------*/
371/*
372 * \brief Copy indexed array from distant or matching interface elements to
373 * local elements.
374 *
375 * Source and destination arrays define values for all elements in the
376 * interface set (i.e. all elements listed by cs_interface_get_elt_ids()
377 * when looping over interfaces of a set.
378 *
379 * Note that when copying the same type of data to all matching elements,
380 * the source and destination index may be the same, if src_on_parent is true.
381 * To avoid requiring a separate destination index, the dest_index argument
382 * may be set to NULL, in which case it is assumed that source and destination
383 * are symmetric, and src_index is sufficient to determine sizes (whether
384 * src_on_parent is true or not).
385 *
386 * In some use cases, for example when copying values only in one direction,
387 * the copying is not symmetric, so both a source and destination buffer must
388 * be provided.
389 *
390 * \param[in] ifs pointer to interface set structure
391 * \param[in] datatype type of data considered
392 * \param[in] src_on_parent true if source array is defined on the elements
393 * defined by ifs->elt_ids, false if source array
394 * defined directly on cs_interface_set_n_elts(ifs)
395 * \param[in] src_index index for source array
396 * \param[in] dest_index index for destination array, or NULL
397 * \param[in] src source array (size:
398 * src_index[cs_interface_set_n_elts(ifs)]
399 * or parent array size)
400 * \param[out] dest destination array (size:
401 * src_index[cs_interface_set_n_elts(ifs)] or
402 * dest_index[cs_interface_set_n_elts(ifs)])
403 */
404/*----------------------------------------------------------------------------*/
405
406void
408 cs_datatype_t datatype,
409 bool src_on_parent,
410 const cs_lnum_t src_index[],
411 const cs_lnum_t dest_index[],
412 const void *src,
413 void *dest);
414
415/*----------------------------------------------------------------------------*/
416/*
417 * \brief Update values using the bitwise inclusive or operation for elements
418 * associated with an interface set.
419 *
420 * On input, the variable array should contain local contributions. On output,
421 * contributions from matching elements on parallel or periodic boundaries
422 * have been processed.
423 *
424 * Only the values of elements belonging to the interfaces are modified.
425 *
426 * \param[in] ifs pointer to a fvm_interface_set_t structure
427 * \param[in] n_elts number of elements in var buffer
428 * \param[in] stride number of values (non interlaced) by entity
429 * \param[in] interlace true if variable is interlaced (for stride > 1)
430 * \param[in] datatype type of data considered
431 * \param[in, out] var variable buffer
432 */
433/*----------------------------------------------------------------------------*/
434
435void
437 cs_lnum_t n_elts,
438 cs_lnum_t stride,
439 bool interlace,
440 cs_datatype_t datatype,
441 void *var);
442
443/*----------------------------------------------------------------------------*/
444/*
445 * \brief Update the sum of values for elements associated with an
446 * interface set.
447 *
448 * On input, the variable array should contain local contributions. On output,
449 * contributions from matching elements on parallel or periodic boundaries
450 * have been added.
451 *
452 * Only the values of elements belonging to the interfaces are modified.
453 *
454 * \param[in] ifs pointer to a fvm_interface_set_t structure
455 * \param[in] n_elts number of elements in var buffer
456 * \param[in] stride number of values (non interlaced) by entity
457 * \param[in] interlace true if variable is interlaced (for stride > 1)
458 * \param[in] datatype type of data considered
459 * \param[in, out] var variable buffer
460 */
461/*----------------------------------------------------------------------------*/
462
463void
465 cs_lnum_t n_elts,
466 cs_lnum_t stride,
467 bool interlace,
468 cs_datatype_t datatype,
469 void *var);
470
471/*----------------------------------------------------------------------------*/
472/*
473 * \brief Update the sum of values for elements associated with an
474 * interface set, allowing control over periodicity.
475 *
476 * On input, the variable array should contain local contributions. On output,
477 * contributions from matching elements on parallel or periodic boundaries
478 * have been added.
479 *
480 * Only the values of elements belonging to the interfaces are modified.
481 *
482 * \param[in] ifs pointer to a fvm_interface_set_t structure
483 * \param[in] n_elts number of elements in var buffer
484 * \param[in] stride number of values (non interlaced) by entity
485 * \param[in] interlace true if variable is interlaced (for stride > 1)
486 * \param[in] datatype type of data considered
487 * \param[in] tr_ignore if > 0, ignore periodicity with rotation;
488 * if > 1, ignore all periodic transforms
489 * \param[in, out] var variable buffer
490 */
491/*----------------------------------------------------------------------------*/
492
493void
495 cs_lnum_t n_elts,
496 cs_lnum_t stride,
497 bool interlace,
498 cs_datatype_t datatype,
499 int tr_ignore,
500 void *var);
501
502/*----------------------------------------------------------------------------*/
503/*
504 * \brief Update the minimum value of elements associated with an interface
505 * set.
506 *
507 * On input, the variable array should contain local contributions. On output,
508 * contributions from matching elements on parallel or periodic boundaries
509 * have been updated.
510 *
511 * Only the values of elements belonging to the interfaces are modified.
512 *
513 * \param[in] ifs pointer to a cs_interface_set_t structure
514 * \param[in] n_elts number of elements in var buffer
515 * \param[in] stride number of values (non interlaced) by entity
516 * \param[in] interlace true if variable is interlaced (for stride > 1)
517 * \param[in] datatype type of data considered
518 * \param[in, out] var variable buffer
519 */
520/*----------------------------------------------------------------------------*/
521
522void
524 cs_lnum_t n_elts,
525 cs_lnum_t stride,
526 bool interlace,
527 cs_datatype_t datatype,
528 void *var);
529
530/*----------------------------------------------------------------------------*/
531/*
532 * \brief Update the maximum value of elements associated with an interface
533 * set.
534 *
535 * On input, the variable array should contain local contributions. On output,
536 * contributions from matching elements on parallel or periodic boundaries
537 * have been updated.
538 *
539 * Only the values of elements belonging to the interfaces are modified.
540 *
541 * \param[in] ifs pointer to a cs_interface_set_t structure
542 * \param[in] n_elts number of elements in var buffer
543 * \param[in] stride number of values (non interlaced) by entity
544 * \param[in] interlace true if variable is interlaced (for stride > 1)
545 * \param[in] datatype type of data considered
546 * \param[in, out] var variable buffer
547 */
548/*----------------------------------------------------------------------------*/
549
550void
552 cs_lnum_t n_elts,
553 cs_lnum_t stride,
554 bool interlace,
555 cs_datatype_t datatype,
556 void *var);
557
558/*----------------------------------------------------------------------------*/
559/*
560 * \brief Update the maximum of values for elements associated with an
561 * interface set, allowing control over periodicity.
562 *
563 * On input, the variable array should contain local contributions. On output,
564 * contributions from matching elements on parallel or periodic boundaries
565 * have been added.
566 *
567 * Only the values of elements belonging to the interfaces are modified.
568 *
569 * \param[in] ifs pointer to a fvm_interface_set_t structure
570 * \param[in] n_elts number of elements in var buffer
571 * \param[in] stride number of values (non interlaced) by entity
572 * \param[in] interlace true if variable is interlaced (for stride > 1)
573 * \param[in] datatype type of data considered
574 * \param[in] tr_ignore if > 0, ignore periodicity with rotation;
575 * if > 1, ignore all periodic transforms
576 * \param[in, out] var variable buffer
577 */
578/*----------------------------------------------------------------------------*/
579
580void
582 cs_lnum_t n_elts,
583 cs_lnum_t stride,
584 bool interlace,
585 cs_datatype_t datatype,
586 int tr_ignore,
587 void *var);
588
589/*----------------------------------------------------------------------------*/
590/*
591 * \brief Add matching element id information to an interface set.
592 *
593 * This information is required by calls to cs_interface_get_match_ids(),
594 * and may be freed using cs_interface_set_free_match_ids().
595 *
596 * \param[in] ifs pointer to interface set structure
597 */
598/*----------------------------------------------------------------------------*/
599
600void
602
603/*----------------------------------------------------------------------------*/
604/*
605 * \brief Free matching element id information of an interface set.
606 *
607 * This information is used by calls to cs_interface_get_match_ids(),
608 * and may be defined using cs_interface_set_add_match_ids().
609 *
610 * \param[in] ifs pointer to interface set structure
611 */
612/*----------------------------------------------------------------------------*/
613
614void
616
617/*----------------------------------------------------------------------------*/
618/*
619 * \brief Tag mutiple elements of local interface with a given values.
620 *
621 * This is effective only on an interface matching the current rank,
622 * and when multiple (periodic) instances of a given element appear on that
623 * rank, al instances except the first are tagged with the chosen value.
624 *
625 * \param[in] itf pointer to interface structure
626 * \param[in] periodicity periodicity information (NULL if none)
627 * \param[in] tr_ignore if > 0, ignore periodicity with rotation;
628 * if > 1, ignore all periodic transforms
629 * \param[in] tag_value tag to assign
630 * \param[in, out] tag global tag array for elements
631 */
632/*----------------------------------------------------------------------------*/
633
634void
636 const fvm_periodicity_t *periodicity,
637 int tr_ignore,
638 cs_gnum_t tag_value,
639 cs_gnum_t *tag);
640/*----------------------------------------------------------------------------*/
641/*
642 * \brief Dump printout of an interface list.
643 *
644 * \param[in] ifs pointer to structure that should be dumped
645 */
646/*----------------------------------------------------------------------------*/
647
648void
650
651/*----------------------------------------------------------------------------*/
652
654
655#endif /* __CS_INTERFACE_H__ */
cs_datatype_t
Definition cs_defs.h:300
Definition cs_defs.h:542
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
Definition cs_defs.h:335
void cs_interface_tag_local_matches(const cs_interface_t *itf, const fvm_periodicity_t *periodicity, int tr_ignore, cs_gnum_t tag_value, cs_gnum_t *tag)
Definition cs_interface.cpp:6043
void cs_interface_set_copy_indexed(const cs_interface_set_t *ifs, cs_datatype_t datatype, bool src_on_parent, const cs_lnum_t src_index[], const cs_lnum_t dest_index[], const void *src, void *dest)
Copy indexed array from distant or matching interface elements to local elements.
Definition cs_interface.cpp:4195
int cs_interface_set_size(const cs_interface_set_t *ifs)
Definition cs_interface.cpp:3827
void cs_interface_set_renumber(cs_interface_set_t *ifs, const cs_lnum_t old_to_new[])
Definition cs_interface.cpp:3923
const cs_interface_t * cs_interface_set_get(const cs_interface_set_t *ifs, int interface_id)
Definition cs_interface.cpp:3875
void cs_interface_set_sum(const cs_interface_set_t *ifs, cs_lnum_t n_elts, cs_lnum_t stride, bool interlace, cs_datatype_t datatype, void *var)
Update the sum of values for elements associated with an interface set.
Definition cs_interface.cpp:4595
void cs_interface_set_max_tr(const cs_interface_set_t *ifs, cs_lnum_t n_elts, cs_lnum_t stride, bool interlace, cs_datatype_t datatype, int tr_ignore, void *var)
Update the maximum of values for elements associated with an interface set, allowing control over per...
Definition cs_interface.cpp:5592
void cs_interface_set_inclusive_or(const cs_interface_set_t *ifs, cs_lnum_t n_elts, cs_lnum_t stride, bool interlace, cs_datatype_t datatype, void *var)
Update values using the bitwise inclusive or operation for elements associated with an interface set.
Definition cs_interface.cpp:4388
const cs_lnum_t * cs_interface_get_match_ids(const cs_interface_t *itf)
Definition cs_interface.cpp:3397
cs_interface_set_t * cs_interface_set_dup_blocks(cs_interface_set_t *ifs, cs_lnum_t block_size, cs_lnum_t n_blocks)
Definition cs_interface.cpp:3697
void cs_interface_set_dump(const cs_interface_set_t *ifs)
Definition cs_interface.cpp:6103
cs_lnum_t cs_interface_size(const cs_interface_t *itf)
Definition cs_interface.cpp:3342
const cs_lnum_t * cs_interface_get_elt_ids(const cs_interface_t *itf)
Definition cs_interface.cpp:3368
void cs_interface_set_destroy(cs_interface_set_t **ifs)
Definition cs_interface.cpp:3604
int cs_interface_rank(const cs_interface_t *itf)
Definition cs_interface.cpp:3321
void cs_interface_set_free_match_ids(cs_interface_set_t *ifs)
Definition cs_interface.cpp:6008
void cs_interface_set_copy_array(const cs_interface_set_t *ifs, cs_datatype_t datatype, int stride, bool src_on_parent, const void *src, void *dest)
Copy array from distant or matching interface elements to local elements.
Definition cs_interface.cpp:4028
const cs_lnum_t * cs_interface_get_tr_index(const cs_interface_t *itf)
Definition cs_interface.cpp:3450
Definition cs_interface.h:61
void cs_interface_set_min(const cs_interface_set_t *ifs, cs_lnum_t n_elts, cs_lnum_t stride, bool interlace, cs_datatype_t datatype, void *var)
Update the minimum value of elements associated with an interface set.
Definition cs_interface.cpp:5046
void cs_interface_set_add_match_ids(cs_interface_set_t *ifs)
Definition cs_interface.cpp:5883
cs_interface_set_t * cs_interface_set_dup(const cs_interface_set_t *ifs, cs_lnum_t stride)
Definition cs_interface.cpp:3631
Definition cs_interface.h:60
cs_lnum_t cs_interface_set_n_elts(const cs_interface_set_t *ifs)
Definition cs_interface.cpp:3851
const fvm_periodicity_t * cs_interface_set_periodicity(const cs_interface_set_t *ifs)
Return pointer to the periocicity structure associated of an interface set.
Definition cs_interface.cpp:3900
cs_interface_set_t * cs_interface_set_create(cs_lnum_t n_elts, const cs_lnum_t parent_element_id[], const cs_gnum_t global_number[], const fvm_periodicity_t *periodicity, int n_periodic_lists, const int periodicity_num[], const cs_lnum_t n_periodic_couples[], const cs_gnum_t *const periodic_couples[])
Definition cs_interface.cpp:3500
cs_lnum_t cs_interface_get_tr_index_size(const cs_interface_t *itf)
Definition cs_interface.cpp:3424
void cs_interface_set_sum_tr(const cs_interface_set_t *ifs, cs_lnum_t n_elts, cs_lnum_t stride, bool interlace, cs_datatype_t datatype, int tr_ignore, void *var)
Update the sum of values for elements associated with an interface set, allowing control over periodi...
Definition cs_interface.cpp:4852
void cs_interface_set_max(const cs_interface_set_t *ifs, cs_lnum_t n_elts, cs_lnum_t stride, bool interlace, cs_datatype_t datatype, void *var)
Update the maximum value of elements associated with an interface set.
Definition cs_interface.cpp:5319
struct _fvm_periodicity_t fvm_periodicity_t
Definition fvm_periodicity.h:67
