cs_array_reduce.h File Reference
#include "mesh/cs_mesh.h"
Include dependency graph for cs_array_reduce.h:
void cs_array_reduce_sum_l (cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_real_t v[], double vsum[])
 Compute sums of an n-dimensional cs_real_t array's components.
void cs_array_reduce_wsum_l (cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_lnum_t *w_elt_list, const cs_real_t v[], const cs_real_t w[], double wsum[])
 Compute weighted sums of an n-dimensional cs_real_t array's components.
void cs_array_reduce_wsum_components_l (cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_lnum_t *w_elt_list, const cs_real_t v[], const cs_real_t w[], double wsum[], double wtot[])
 Compute weighted sums of an n-dimensional cs_real_t array's components. Output is both weighted sum and sum of weights, hence allowing for the computation of local, or global using parallel operations afterwards, mean of the array.
void cs_array_reduce_minmax_l (cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_real_t v[], cs_real_t vmin[], cs_real_t vmax[])
void cs_array_reduce_simple_stats_l (cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_real_t v[], double vmin[], double vmax[], double vsum[])
 Compute simple local stats (minima, maxima, sum) of an n-dimensional cs_real_t array's components.
void cs_array_reduce_simple_stats_l_w (cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_lnum_t *w_elt_list, const cs_real_t v[], const cs_real_t w[], double vmin[], double vmax[], double vsum[], double wsum[])
 Compute simple local stats (minima, maxima, sum, weighted sum) of an n-dimensional cs_real_t array's components for a given mesh location.
void cs_array_reduce_simple_norms_l (cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_lnum_t *w_elt_list, const cs_real_t v[], const cs_real_t w[], double vmin[], double vmax[], double vsum[], double wsum[], double asum[], double ssum[], double wssum[])
 Compute simple local stats and norms (minima, maxima, sum, weighted sum, sum of absolute values, sum of squared values and weighted sum of squared values) of an n-dimensional cs_real_t array's components.
void cs_array_scatter_reduce_norms_l (cs_lnum_t n_src_elts, const cs_lnum_t *src2v_idx, const cs_lnum_t *src2v_ids, const cs_lnum_t *filter_list, int dim, cs_lnum_t n_v_elts, const cs_real_t v[], const cs_real_t w[], double vsum[], double asum[], double ssum[])
 Compute simple local weighted norms (l1, l2) of an n-dimensional cs_real_t array's components The weight array is mandatory.
◆ cs_array_reduce_minmax_l()
void cs_array_reduce_minmax_l ( cs_lnum_t n_elts,
int dim,
const cs_lnum_t * v_elt_list,
cs_real_t vmin[],
cs_real_t vmax[] )
The maximum allowed dimension is 3. The array is interleaved.
For arrays of dimension 3, the statistics relative to the norm are also computed, and added at the end of the statistics arrays (which must be size dim+1).
The algorithm here is similar to that used for BLAS.
[in]n_eltsnumber of local elements
[in]dimlocal array dimension (max: 9)
[in]v_elt_listoptional list of parent elements on which values are defined, or NULL
[in]vpointer to array values
[out]vminresulting min array (size: dim, or 4 if dim = 3)
[out]vmaxresulting max array (size: dim, or 4 if dim = 3)
[in]v_elt_listoptional list of parent elements on which values are defined, or nullptr
◆ cs_array_reduce_simple_norms_l()
void cs_array_reduce_simple_norms_l ( cs_lnum_t n_elts,
int dim,
const cs_lnum_t * w_elt_list,
double vmin[],
double vmax[],
double vsum[],
double wsum[],
double asum[],
double ssum[],
double wssum[] )
The algorithm here is similar to that used for BLAS, but computes several quantities simultaneously for better cache behavior
parameters: n_elts <– number of local elements dim <– local array dimension (max: 3) v_elt_list <– optional list of parent elements on which values are defined, or NULL w_elt_list <– optional list of parent elements on which weights are defined, or NULL; if v_elt_list is defined (ie. non-null),then w_elt_list = v_elt_list is assumed, so this parameter is ignored v <– pointer to array values w <– pointer to weights vmin --> resulting min array (size: dim, or 4 if dim = 3) vmax --> resulting max array (same size as vmin) vsum --> resulting sum array (same size as vmin) wsum --> resulting weighted sum array (same size as vmin) asum --> resulting sum of absolute values (same size as vmin) ssum --> resulting weighted sum array (same size as vmin) wssum --> resulting weighted sum of squared values (same size as vmin)
parameters: n_elts <– number of local elements dim <– local array dimension (max: 3) v_elt_list <– optional list of parent elements on which values are defined, or nullptr w_elt_list <– optional list of parent elements on which weights are defined, or nullptr; if v_elt_list is defined (ie. non-null),then w_elt_list = v_elt_list is assumed, so this parameter is ignored v <– pointer to array values w <– pointer to weights vmin --> resulting min array (size: dim, or 4 if dim = 3) vmax --> resulting max array (same size as vmin) vsum --> resulting sum array (same size as vmin) wsum --> resulting weighted sum array (same size as vmin) asum --> resulting sum of absolute values (same size as vmin) ssum --> resulting weighted sum array (same size as vmin) wssum --> resulting weighted sum of squared values (same size as vmin)
◆ cs_array_reduce_simple_stats_l()
void cs_array_reduce_simple_stats_l ( cs_lnum_t n_elts,
int dim,
double vmin[],
double vmax[],
double vsum[] )
The maximum allowed dimension is 10. The array is interleaved.
[in]dimlocal array dimension (max: 10)
[out]vsumresulting sum array (size: dim, or 4 if dim = 3)
◆ cs_array_reduce_simple_stats_l_w()
void cs_array_reduce_simple_stats_l_w ( cs_lnum_t n_elts,
int dim,
double vmin[],
double vmax[],
double vsum[],
double wsum[] )
The maximum allowed dimension is 9 (allowing for a rank-2 tensor). The array is interleaved.
parameters: n_elts <– number of local elements dim <– local array dimension (max: 9) v_elt_list <– optional list of parent elements on which values are defined, or NULL w_elt_list <– optional list of parent elements on which weights are defined, or NULL; if v_elt_list is defined (ie. non-null),then w_elt_list = v_elt_list is assumed, so this parameter is ignored v <– pointer to array values w <– pointer to weights vmin --> resulting min array (size: dim, or 4 if dim = 3) vmax --> resulting max array (size: dim, or 4 if dim = 3) vsum --> resulting sum array (size: dim, or 4 if dim = 3) wsum --> resulting weighted sum array (size: dim, or 4 if dim = 3)
[in]w_elt_listoptional list of parent elements on which weights are defined, or nullptr; if v_elt_list is defined (ie. non-null),then w_elt_list = v_elt_list is assumed, so this parameter is ignored
[in]wpointer to weights
[out]wsumresulting weighted sum array (size: dim, or 4 if dim = 3)
◆ cs_array_reduce_sum_l()
void cs_array_reduce_sum_l ( cs_lnum_t n_elts,
int dim,
double vsum[] )
◆ cs_array_reduce_wsum_components_l()
void cs_array_reduce_wsum_components_l ( cs_lnum_t n_elts,
int dim,
double wsum[],
double wtot[] )
[in]w_elt_listoptional list of parent elements on which weights are defined, or NULL; if v_elt_list is defined (ie. non-null),then w_elt_list = v_elt_list is assumed, so this parameter is ignored
[out]wtotresulting local sum of weights array
◆ cs_array_reduce_wsum_l()
void cs_array_reduce_wsum_l ( cs_lnum_t n_elts,
int dim,
double wsum[] )
◆ cs_array_scatter_reduce_norms_l()
void cs_array_scatter_reduce_norms_l ( cs_lnum_t n_src_elts,
const cs_lnum_t * src2v_idx,
const cs_lnum_t * src2v_ids,
const cs_lnum_t * filter_list,
int dim,
cs_lnum_t n_v_elts,
double vsum[],
double asum[],
double ssum[] )
parameters: n_src_elts <– number of source elements src2v_idx <– index array between source elements and local elements src2v_ids <– list of ids of local elements filter_list <– optional list of source elements on which values are defined, or NULL dim <– local array dimension (max: 3) n_v_elts <– number of local elements in the array of values v <– pointer to array values w <– pointer to weights (size = src2v_idx[n_src_elts]) vsum --> (weighted) sum array (size: dim, or 4 if dim = 3) asum --> (weighted) sum of absolute values (same size as vsum) ssum --> (weighted) sum of squared values (same size as vsum)
parameters: n_src_elts <– number of source elements src2v_idx <– index array between source elements and local elements src2v_ids <– list of ids of local elements filter_list <– optional list of source elements on which values are defined, or nullptr dim <– local array dimension (max: 3) n_v_elts <– number of local elements in the array of values v <– pointer to array values w <– pointer to weights (size = src2v_idx[n_src_elts]) vsum --> (weighted) sum array (size: dim, or 4 if dim = 3) asum --> (weighted) sum of absolute values (same size as vsum) ssum --> (weighted) sum of squared values (same size as vsum)
