| typedef void | cs_sort_partition_s_to_elt_t(double s, void *elt, const void *input) |
| | function pointer for conversion of a double precision value in range [0, 1] to a given element.
| typedef int | cs_sort_partition_compare_t(const void *elt1, const void *elt2, const void *input) |
| | function pointer for comparison of 2 elements.
◆ cs_sort_partition_compare_t
| typedef int cs_sort_partition_compare_t(const void *elt1, const void *elt2, const void *input) |
This function is the same type as that used by qsort_r.
- Parameters
| [in] | elt1 | coordinate between 0 and 1 |
| [in] | elt2 | pointer to optional (untyped) value or structure. |
| [in] | input | pointer to optional (untyped) value or structure. |
- Returns
- < 0 if elt1 < elt2, 0 if elt1 == elt2, > 0 if elt1 > elt2
◆ cs_sort_partition_s_to_elt_t
| typedef void cs_sort_partition_s_to_elt_t(double s, void *elt, const void *input) |
- Parameters
| [in] | s | coordinate between 0 and 1 |
| [out] | elt | pointer to element |
