#include "base/cs_defs.h"#include <assert.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_array.h"#include "base/cs_base.h"#include "base/cs_1d_wall_thermal.h"#include "base/cs_field.h"#include "base/cs_field_pointer.h"#include "base/cs_gas_mix.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parall.h"#include "base/cs_physical_constants.h"#include "base/cs_prototypes.h"#include "base/cs_restart.h"#include "base/cs_thermal_model.h"#include "base/cs_time_step.h"#include "base/cs_velocity_pressure.h"#include "base/cs_wall_condensation_1d_thermal.h"#include "base/cs_wall_functions.h"#include "base/cs_wall_condensation.h"Functions | |
| cs_wall_condensation_t * | cs_get_glob_wall_condensation (void) |
| Provide writable access to _wall_cond structure. | |
| void | cs_wall_condensation_set_model (cs_wall_cond_natural_conv_model_t model) |
| Set the wall condensation model. | |
| void | cs_wall_condensation_set_onoff_state (int icondb, int icondv) |
| Set the onoff state of wall condensation modeling. | |
| void | cs_wall_condensation_create (void) |
| Create the context for wall condensation models. | |
| void | cs_wall_condensation_free (void) |
| Free all structures related to wall condensation models. | |
| void | cs_wall_condensation_initialize (void) |
| Initialize wall condensation models. | |
| void | cs_wall_condensation_volume_exchange_surf_at_cells (cs_real_t *surf) |
| Return condensing volume structures surface at each cell. | |
| void | cs_wall_condensation_reset (cs_wall_condensation_t *wall_cond, const int n_var) |
| void | cs_wall_condensation_compute (cs_real_t total_htc[]) |
| Compute the wall condensation source terms. | |
| void | cs_wall_condensation_log (void) |
| Output statistics about wall condensation source terms (for user log) | |
| void | cs_wall_condensation_source_terms (const cs_field_t *f, const cs_real_t xcpp[], const cs_real_t pvara[], cs_real_t st_exp[], cs_real_t st_imp[]) |
| Explicit and implicit sources terms from sources condensation computation. | |
| const cs_wall_condensation_t * | cs_glob_wall_condensation = &_wall_cond |
| cs_wall_condensation_t * cs_get_glob_wall_condensation | ( | void | ) |
| void cs_wall_condensation_compute | ( | cs_real_t | total_htc[] | ) |
| void cs_wall_condensation_create | ( | void | ) |
| void cs_wall_condensation_free | ( | void | ) |
| void cs_wall_condensation_initialize | ( | void | ) |
This includes building the associated meshes.
| void cs_wall_condensation_log | ( | void | ) |
| void cs_wall_condensation_reset | ( | cs_wall_condensation_t * | wall_cond, |
| const int | n_var ) |
| void cs_wall_condensation_set_model | ( | cs_wall_cond_natural_conv_model_t | model | ) |
| [in] | model | integer corresponding to the desired model |
| void cs_wall_condensation_set_onoff_state | ( | int | icondb, |
| int | icondv ) |
| [in] | icondb | integer corresponding to the onoff state (-1: off, 0: on) |
| [in] | icondv | integer corresponding to the onoff state with metal structures (-1: off, 0: on) |
| void cs_wall_condensation_source_terms | ( | const cs_field_t * | f, |
| const cs_real_t | xcpp[], | ||
| const cs_real_t | pvara[], | ||
| cs_real_t | st_exp[], | ||
| cs_real_t | st_imp[] ) |
| [in] | f | pointer to field structure |
| [in] | xcpp | array of specific heat (Cp) |
| [in] | pvara | variable value at time step beginning |
| [in,out] | st_exp | explicit source term part linear in the variable |
| [in,out] | st_imp | associated value with tsexp to be stored in the matrix |
| void cs_wall_condensation_volume_exchange_surf_at_cells | ( | cs_real_t * | surf | ) |
| [out] | surf | array of volume structure surfaces at each cell |
| const cs_wall_condensation_t* cs_glob_wall_condensation = &_wall_cond |
