1#ifndef __CS_BOUNDARY_ZONE_H__
2#define __CS_BOUNDARY_ZONE_H__
67#define CS_BOUNDARY_ZONE_WALL (1 << 0)
70#define CS_BOUNDARY_ZONE_PRIVATE (1 << 1)
168 const char *criteria,
void cs_boundary_zone_initialize(void)
Initialize boundary zone structures.
Definition cs_boundary_zone.cpp:375
void cs_boundary_zone_build_all(bool mesh_modified)
Update association of boundary zones with a mesh.
Definition cs_boundary_zone.cpp:491
const int * cs_boundary_zone_face_class_or_zone_id(void)
Get read pointer to optional boundary face class or zone ids.
Definition cs_boundary_zone.cpp:1082
Definition cs_boundary_zone.cpp:711
int * cs_boundary_zone_face_class_id(void)
Get pointer to optional boundary face class ids.
Definition cs_boundary_zone.cpp:1026
int cs_boundary_zone_define_by_func(const char *name, cs_mesh_location_select_t *func, void *input, int type_flag)
Define a new mesh location with an associated selection function.
Definition cs_boundary_zone.cpp:652
int cs_boundary_zone_n_zones(void)
Return number of boundary zones defined.
Definition cs_boundary_zone.cpp:426
int cs_boundary_zone_define(const char *name, const char *criteria, int type_flag)
Define a new boundary zone using a selection criteria string.
Definition cs_boundary_zone.cpp:608
const cs_zone_t * cs_boundary_zone_by_name_try(const char *name)
Definition cs_boundary_zone.cpp:737
void cs_boundary_zone_set_overlay(int id, bool allow_overlay)
Set overlay behavior for a given boundary zone.
Definition cs_boundary_zone.cpp:826
void cs_boundary_zone_build_private(int id)
Update association of a given private boundary zone with a mesh.
Definition cs_boundary_zone.cpp:463
void cs_boundary_zone_print_info(void)
Print boundary zones information to listing file.
Definition cs_boundary_zone.cpp:1119
void cs_boundary_zone_finalize(void)
Free all boundary zone structures.
Definition cs_boundary_zone.cpp:401
int cs_boundary_zone_id_by_name(const char *z_name)
Retrieve the boundary zone id from its zone name. If the zone name is equal to NULL or has an empty l...
Definition cs_boundary_zone.cpp:761
int cs_boundary_zone_n_zones_time_varying(void)
Return number of boundary zones which may vary in time.
Definition cs_boundary_zone.cpp:440
const cs_zone_t * cs_boundary_zone_by_id(int id)
Return a pointer to a boundary zone based on its id.
Definition cs_boundary_zone.cpp:687
void cs_boundary_zone_update_face_class_id(void)
Update boundary face output class ids if present.
Definition cs_boundary_zone.cpp:1045
void cs_boundary_zone_log_setup(void)
Log setup information relative to defined boundary zones.
Definition cs_boundary_zone.cpp:960
int cs_boundary_zone_max_class_or_zone_id(void)
Return the maximum defined face class or zone id.
Definition cs_boundary_zone.cpp:1102
int cs_boundary_zone_n_type_zones(int type_flag)
Return number of boundary zones associated with a given zone flag.
Definition cs_boundary_zone.cpp:988
void cs_boundary_zone_log_info(const cs_zone_t *z)
Print info relative to a given boundary zone to log file.
Definition cs_boundary_zone.cpp:859
void cs_boundary_zone_set_type(int id, int type_flag)
Set type flag for a given boundary zone.
Definition cs_boundary_zone.cpp:790
void cs_boundary_zone_set_time_varying(int id, bool time_varying)
Set time varying behavior for a given boundary zone.
Definition cs_boundary_zone.cpp:808
const int * cs_boundary_zone_face_zone_id(void)
Return pointer to zone id associated with each boundary face.
Definition cs_boundary_zone.cpp:845
Definition cs_defs.h:542
Definition cs_defs.h:543
void cs_mesh_location_select_t(void *input, const cs_mesh_t *m, int location_id, cs_lnum_t *n_elts, cs_lnum_t **elt_ids)
Definition cs_mesh_location.h:110
