1#ifndef __CS_MEDCOUPLING_POSTPROCESS_HXX__
2#define __CS_MEDCOUPLING_POSTPROCESS_HXX__
48typedef struct _medcoupling_slice_t cs_medcoupling_slice_t;
63cs_medcoupling_slice_t *
75cs_medcoupling_slice_t *
87cs_medcoupling_slice_t *
98 const char *selection_criteria,
112 const char *selection_criteria,
116 const int n_sectors);
126 const char *selection_criteria,
131 const int n_sectors);
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
cs_real_t cs_medcoupling_slice_scalar_integral(const char *name, const cs_real_t *scalar)
Compute integral of a scalar over a slice.
Definition cs_medcoupling_postprocess.cxx:875
cs_medcoupling_slice_t * cs_medcoupling_slice_by_id(int id)
Get pointer to a slice based on id.
Definition cs_medcoupling_postprocess.cxx:570
void cs_medcoupling_slice_destroy_all(void)
Destroy all slices.
Definition cs_medcoupling_postprocess.cxx:1058
cs_real_t * cs_medcoupling_slice_get_surfaces(const char *name)
Get list of intersection surfaces for each cell intersected.
Definition cs_medcoupling_postprocess.cxx:820
void cs_medcoupling_postprocess_add_annulus_slice(const char *name, const char *selection_criteria, const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius1, const cs_real_t radius2, const int n_sectors)
Add a slice based on an annulus.
Definition cs_medcoupling_postprocess.cxx:734
cs_real_t cs_medcoupling_slice_scalar_integral_weighted(const char *name, const cs_real_t *scalar, const cs_real_t *weight_s, const cs_real_3_t *weight_v)
Compute integral of a scalar over a slice using a scalar and/or vectorial weights....
Definition cs_medcoupling_postprocess.cxx:932
cs_lnum_t * cs_medcoupling_slice_get_elt_ids(const char *name)
Get list of ids of the elements which may be intersected.
Definition cs_medcoupling_postprocess.cxx:801
void cs_medcoupling_postprocess_add_plane_slice(const char *name, const char *selection_criteria, const cs_real_t origin[], const cs_real_t normal[], const cs_real_t length1, const cs_real_t length2)
Add a slice based on a plane.
Definition cs_medcoupling_postprocess.cxx:642
void cs_medcoupling_slice_activate_postprocess(const char *name)
Activate postprocessing of intersected cells.
Definition cs_medcoupling_postprocess.cxx:856
cs_medcoupling_slice_t * cs_medcoupling_slice_by_name_try(const char *name)
Get pointer to slice based on name. Returns nullptr if not found.
Definition cs_medcoupling_postprocess.cxx:615
cs_medcoupling_slice_t * cs_medcoupling_slice_by_name(const char *name)
Get pointer to slice based on name, raises an error if not found.
Definition cs_medcoupling_postprocess.cxx:591
cs_real_t cs_medcoupling_slice_scalar_mean_weighted(const char *name, const cs_real_t *scalar, const cs_real_t *weight_s, const cs_real_3_t *weight_v)
Compute mean of a scalar over a slice using a scalar and/or vectorial weights. If nullptr is provided...
Definition cs_medcoupling_postprocess.cxx:995
cs_real_t cs_medcoupling_slice_scalar_mean(const char *name, const cs_real_t *scalar)
Compute mean value of a scalar over a slice.
Definition cs_medcoupling_postprocess.cxx:908
cs_real_t cs_medcoupling_slice_get_total_surface(const char *name)
Get total intersection surface between a slice and volume mesh.
Definition cs_medcoupling_postprocess.cxx:839
cs_lnum_t cs_medcoupling_slice_get_n_elts(const char *name)
Get number cells that may be intersected by the slice.
Definition cs_medcoupling_postprocess.cxx:782
void cs_medcoupling_postprocess_add_disc_slice(const char *name, const char *selection_criteria, const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius, const int n_sectors)
Add a slice based on a disc.
Definition cs_medcoupling_postprocess.cxx:691
