| struct | cs_vof_parameters_t |
| VOF model parameters. Void fraction variable tracks fluid 2. More... | |
| struct | cs_cavitation_parameters_t |
| Cavitation model parameters. More... | |
Macros | |
| #define | CS_VOF_ENABLED (1 << 0) |
| #define | CS_VOF_FREE_SURFACE (1 << 1) |
| #define | CS_VOF_MERKLE_MASS_TRANSFER (1 << 2) |
Enumerations | |
| enum | cs_vof_contact_angle_t { CS_VOF_CONTACT_ANGLE_OFF , CS_VOF_CONTACT_ANGLE_STATIC , CS_VOF_CONTACT_ANGLE_DYN , CS_VOF_N_CONTACT_ANGLE_TYPES } |
| cs_vof_parameters_t * | cs_get_glob_vof_parameters (void) |
| void | cs_vof_field_create (void) |
| Create VoF fields. | |
| void | cs_vof_log_setup (void) |
| Log setup of VoF model. | |
| void | cs_vof_compute_linear_rho_mu (const cs_mesh_t *m) |
| Compute the mixture density, mixture dynamic viscosity given fluid volume fractions and the reference density and dynamic viscosity | |
| void | cs_vof_update_phys_prop (const cs_mesh_t *m) |
| Compute the mixture density, mixture dynamic viscosity and mixture mass flux given the volumetric flux, the volume fraction and the reference density and dynamic viscosity | |
| void | cs_vof_surface_tension (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, cs_real_3_t stf[]) |
| Compute the surface tension momentum source term following the CSF model of Brackbill et al. (1992). | |
| void | cs_vof_log_mass_budget (const cs_mesh_t *m, const cs_mesh_quantities_t *mq) |
| Write in main log the global mixture mass budget: | |
| void | cs_vof_deshpande_drift_flux (const cs_mesh_t *m, const cs_mesh_quantities_t *mq) |
| Compute the flux of the drift velocity | |
| void | cs_vof_drift_term (int imrgra, int nswrgp, int imligp, int iwarnp, cs_real_t epsrgp, cs_real_t climgp, cs_real_t *pvar, const cs_real_t *pvara, cs_real_t *rhs) |
| Add the explicit part of the convection/diffusion terms of a standard transport equation of a scalar field | |
| void | cs_vof_solve_void_fraction (int iterns) |
| Solve the void fraction | |
| cs_cavitation_parameters_t * | cs_get_glob_cavitation_parameters (void) |
| void | cs_cavitation_compute_source_term (const cs_real_t pressure[], const cs_real_t voidf[]) |
| Compute the vaporization source term | |
| void | cs_vof_contact_angle_set (const cs_vof_contact_angle_t choice) |
| Set the contact angle mode. | |
| const cs_vof_parameters_t * | cs_glob_vof_parameters |
| const cs_cavitation_parameters_t * | cs_glob_cavitation_parameters |
![\[m^+ = -\dfrac{C_{prod} \rho_l \min \left( p-p_V,0 \right)\alpha(1-\alpha)}
{0.5\rho_lu_\infty^2t_\infty},
\]](form_252.png)
![\[m^- = -\dfrac{C_{dest} \rho_v \max \left( p-p_V,0 \right)\alpha(1-\alpha)}
\]](form_253.png)
with
Note that the r.h.s. of the void fraction transport equation is
| [in] | pressure | Pressure array |
| [in] | voidf | Void fraction array |
| cs_cavitation_parameters_t * cs_get_glob_cavitation_parameters | ( | void | ) |
| cs_vof_parameters_t * cs_get_glob_vof_parameters | ( | void | ) |
| void cs_vof_compute_linear_rho_mu | ( | const cs_mesh_t * | m | ) |
Computation is done as follows on cells:
![\[\rho_\celli = \alpha_\celli \rho_v + (1-\alpha_\celli) \rho_l,
\]](form_235.png)
![\[\mu_\celli = \alpha_\celli \mu_v + (1-\alpha_\celli) \mu_l,
\]](form_236.png)
A similar linear formula is followed on boundary using fluid volume fraction value on the boundary.
| [in] | m | pointer to mesh structure |
\]](form_235.png)
\]](form_236.png)
| void cs_vof_contact_angle_set | ( | const cs_vof_contact_angle_t | choice | ) |
| [in] | choice | Contact angle model to set. |
| void cs_vof_deshpande_drift_flux | ( | const cs_mesh_t * | m, |
| const cs_mesh_quantities_t * | mq ) |
Using the notation:
![\[\begin{cases}
\left ( \vect u ^{n+1} . \vect S \right ) _{\face} = \Dot{m}_{\face}\\
\left ( \vect u _d^{n+1} . \vect S \right ) _{\face} = \Dot{m^d}_{\face}
\end{cases}
\]](form_241.png)
The drift flux is computed as:
![\[\Dot{m^d}_{\face} = min \left ( C_{\gamma} \dfrac{\Dot{m}_{\face}}
{\vect S_{\face}}, \underset{\face'}{max} \left [ \dfrac{\Dot{m}_{\face'}}
{\vect S_{\face'}} \right ] \right ) \left ( \vect n . \vect S \right )
_{\face}
\]](form_262.png)
Where
![\[{\vect n _{\face}} = \dfrac{\left ( \grad \alpha \right ) _{\face}}
{\norm {\left ( \grad \alpha \right ) _{\face} + \delta}},
\text{ with: }
\left ( \grad \alpha \right ) _{\face _{\celli \cellj}} = \dfrac{\left (
\grad \alpha \right ) _\celli + \left ( \grad \alpha \right ) _\cellj}{2},
\text{ and: }
\delta = 10^{-8} / \overline{\vol \celli} ^{1/3}
\]](form_263.png)
| [in] | mq | pointer to mesh quantities structure |
Using the notation:
![\[\begin{cases}
\end{cases}
\]](form_241.png)
{\vect S_{\face'}} \right ] \right ) \left ( \vect n \cdot \vect S \right )
_{\face}
\]](form_242.png)
Where
![\[\vect {n} _{\face} = \dfrac{\left ( \grad \alpha \right ) _{\face}}
\text{ with: }
\text{ and: }
\]](form_245.png)
| void cs_vof_drift_term | ( | int | imrgra, |
| int | nswrgp, | ||
| int | imligp, | ||
| int | iwarnp, | ||
| cs_real_t | epsrgp, | ||
| cs_real_t | climgp, | ||
| cs_real_t * | pvar, | ||
| const cs_real_t * | pvara, | ||
| cs_real_t * | rhs ) |
More precisely, the right hand side
![\[Rhs = Rhs - \sum_{\fij \in \Facei{\celli}} \left(
\alpha_\celli^{n+1} \left( 1 - \alpha_\cellj^{n+1} \right) \left(
\dot{m}_\fij^{d} \right)^{+} + \alpha_\cellj^{n+1} \left( 1 -
\alpha_\celli^{n+1} \right) \left( \dot{m}_\fij^{d} \right)^{-}
\right)
\]](form_246.png)
| [in] | imrgra | indicator
| [in] | nswrgp | number of reconstruction sweeps for the gradients |
| [in] | imligp | clipping gradient method
| [in] | iwarnp | verbosity |
| [in] | epsrgp | relative precision for the gradient reconstruction |
| [in] | climgp | clipping coefficient for the computation of the gradient |
| [in] | pvar | solved variable (current time step) |
| [in] | pvara | solved variable (previous time step) |
| [in,out] | rhs | right hand side |
| void cs_vof_field_create | ( | void | ) |
Create VoF fields.
| void cs_vof_log_mass_budget | ( | const cs_mesh_t * | m, |
![\[\sum_i\left(
|\Omega_i|\dfrac{\alpha_i^n - \alpha_i^{n-1}}{\Delta t} +
\sum_{j\in\Face{\celli}}\left(\rho\vect{u}\vect{S}\right)_{ij}^n
\right).
\]](form_260.png)
![\[\sum_\celli\left(
|\Omega_\celli|\dfrac{\rho_\celli^n - \rho_\celli^{n-1}}{\Delta t} +
\sum_{\cellj\in\Face{\celli}}\left(\rho\vect{u}\vect{S}\right)_{\ij}^n
\right).
\]](form_239.png)
| void cs_vof_log_setup | ( | void | ) |
| void cs_vof_solve_void_fraction | ( | int | iterns | ) |
This function solves:
![\[\dfrac{\alpha^n - \alpha^{n-1}}{\Delta t}
+ \divs \left( \alpha^n \vect{u}^n \right)
+ \divs \left( \left[ \alpha^n
\left( 1 - \alpha^{n} \right)
\right] \vect{u^r}^n \right)
= \dfrac{\Gamma_V \left( \alpha^{n-1}, p^n \right)}{\rho_v}
\]](form_247.png)
with
| void cs_vof_surface_tension | ( | const cs_mesh_t * | m, |
| const cs_mesh_quantities_t * | mq, | ||
| cs_real_3_t | stf[] ) |
| [out] | stf | surface tension momentum source term |
| void cs_vof_update_phys_prop | ( | const cs_mesh_t * | m | ) |
For the computation of mixture density, mixture dynamic viscosity, see cs_vof_compute_linear_rho_mu.
Computation of mass flux is as follows:
![\[\left( \rho\vect{u}\cdot\vect{S} \right)_\ij = \\ \left\lbrace
\begin{array}{ll}
\rho_\celli (\vect{u}\cdot\vect{S})_\ij
&\text{ if } (\vect{u}\cdot\vect{S})_\ij>0, \\
\rho_\cellj (\vect{u}\cdot\vect{S})_\ij
&\text{ otherwise },
\end{array} \right.
\]](form_237.png)
![\[\left( \rho\vect{u}\cdot\vect{S} \right)_\ib = \\ \left\lbrace
\begin{array}{ll}
\rho_\celli (\vect{u}\cdot\vect{S})_\ib
&\text{ if } (\vect{u}\cdot\vect{S})_\ib>0, \\
\rho_b (\vect{u}\cdot\vect{S})_\ib
&\text{ otherwise }.
\end{array} \right.
\]](form_238.png)
\begin{array}{ll}
\end{array} \right.
\]](form_237.png)
\begin{array}{ll}
\end{array} \right.
\]](form_238.png)
extern |
extern |
