cs_numbering.h
1#ifndef __CS_NUMBERING_H__
2#define __CS_NUMBERING_H__
5 * Numbering information for vectorization or multithreading
31 * Local headers
34#include "base/cs_defs.h"
35#include "base/cs_base.h"
36#include "base/cs_log.h"
43 * Macro definitions
45
46/* SIMD unit length */
47/*------------------*/
48
49#if defined(__NEC__) && defined(__ve__) /* For NEC Aurora series */
50
51# define CS_NUMBERING_SIMD_SIZE 256
52
53#elif defined(SX) && defined(_SX) /* For NEC SX series (at least SX-9) */
54
55# define CS_NUMBERING_SIMD_SIZE 256
56
57#elif defined(__AVX512F__) /* For Intel with AVX 512 */
58
59# define CS_NUMBERING_SIMD_SIZE 64
60
61#elif defined(HAVE_CUDA) /* For CUDA devices (warp size) */
62
63# define CS_NUMBERING_SIMD_SIZE 32
64
65#else
66
67# define CS_NUMBERING_SIMD_SIZE 4 /* Most current platforms */
68
69#endif
70
71/*============================================================================
72 * Type definitions
73 *============================================================================*/
74
75/* Renumbering types */
76
77typedef enum {
78
79 CS_NUMBERING_DEFAULT, /* Default numbering */
80 CS_NUMBERING_VECTORIZE, /* Numbered for vectorization */
81 CS_NUMBERING_THREADS /* Numbered for threads */
82
84
85/* Renumbering structure */
86
87typedef struct {
88
89 cs_numbering_type_t type; /* Numbering type */
90
91 int vector_size; /* Vector size if vectorized, 1 otherwise */
92
93 int n_threads; /* Number of threads */
94 int n_groups; /* Number of associated groups */
95
96 int n_no_adj_halo_groups; /* number of groups for which only non-ghost
97 entities are adjacent */
98
99 cs_lnum_t n_no_adj_halo_elts; /* Number of elements not adjacent to
100 halo elements */
101
102 cs_lnum_t *group_index; /* For thread t and group g, the start and
103 past-the-end ids for entities in a given
104 group and thread are respectively:
105 group_index[t*n_groups*2 + g] and
106 group_index[t*n_groups*2 + g + 1].
107 (size: n_groups * n_threads * 2) */
108
110
111/*=============================================================================
112 * Global variable definitions
113 *============================================================================*/
114
115/* Names for numbering types */
116
117extern const char *cs_numbering_type_name[];
118
119/*============================================================================
120 * Public function prototypes for Fortran API
121 *============================================================================*/
122
123/*=============================================================================
124 * Public function prototypes
125 *============================================================================*/
126
127/*----------------------------------------------------------------------------*/
135/*----------------------------------------------------------------------------*/
136
139
140/*----------------------------------------------------------------------------*/
150/*----------------------------------------------------------------------------*/
151
154 int vector_size);
155
156/*----------------------------------------------------------------------------*/
171/*----------------------------------------------------------------------------*/
172
174cs_numbering_create_threaded(int n_threads,
175 int n_groups,
176 cs_lnum_t group_index[]);
177
178/*----------------------------------------------------------------------------*/
185/*----------------------------------------------------------------------------*/
186
187void
189
190/*----------------------------------------------------------------------------*/
198/*----------------------------------------------------------------------------*/
199
200void
202 const char *description,
203 const cs_numbering_t *numbering);
204
205/*----------------------------------------------------------------------------*/
211/*----------------------------------------------------------------------------*/
212
213void
214cs_numbering_dump(const cs_numbering_t *numbering);
215
216/*----------------------------------------------------------------------------*/
217
219
220#endif /* __CS_NUMBERING_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_log_t
Definition cs_log.h:48
const char * cs_numbering_type_name[]
Definition cs_numbering.cpp:73
cs_numbering_t * cs_numbering_create_threaded(int n_threads, int n_groups, cs_lnum_t group_index[])
Create a default numbering information structure in case of threading.
Definition cs_numbering.cpp:598
cs_numbering_t * cs_numbering_create_vectorized(cs_lnum_t n_elts, int vector_size)
Create a default numbering information structure in case of vectorization.
Definition cs_numbering.cpp:556
void cs_numbering_log_info(cs_log_t log, const char *description, const cs_numbering_t *numbering)
Log information relative to a cs_numbering_t structure.
Definition cs_numbering.cpp:656
cs_numbering_t * cs_numbering_create_default(cs_lnum_t n_elts)
Create a default numbering information structure.
Definition cs_numbering.cpp:520
void cs_numbering_destroy(cs_numbering_t **numbering)
Destroy a numbering information structure.
Definition cs_numbering.cpp:635
cs_numbering_type_t
Definition cs_numbering.h:77
@ CS_NUMBERING_THREADS
Definition cs_numbering.h:81
@ CS_NUMBERING_VECTORIZE
Definition cs_numbering.h:80
@ CS_NUMBERING_DEFAULT
Definition cs_numbering.h:79
void cs_numbering_dump(const cs_numbering_t *numbering)
Dump a cs_numbering_t structure.
Definition cs_numbering.cpp:741
Definition cs_numbering.h:87
cs_lnum_t * group_index
Definition cs_numbering.h:102
Definition cs_numbering.h:96
int vector_size
Definition cs_numbering.h:91
Definition cs_numbering.h:89
int n_threads
Definition cs_numbering.h:93
int n_groups
Definition cs_numbering.h:94
Definition cs_numbering.h:99
