cs_rank_neighbors.h
1#ifndef __CS_RANK_NEIGHBORS_H__
2#define __CS_RANK_NEIGHBORS_H__
5 * Management of parallel rank neighbors.
30#if defined(HAVE_MPI)
31#include <mpi.h>
32#endif
35 * Local headers
38#include "base/cs_defs.h"
39#include "base/cs_block_dist.h"
45/*=============================================================================
46 * Macro definitions
48
50 * Type definitions
52
53/* Exchange algorithm choice */
54
62
63#if defined(HAVE_MPI)
64
65/* Rank neighbors structure */
66
67typedef struct {
68
69 int size;
70 int *rank;
71
72} cs_rank_neighbors_t;
73
74#endif
75
76/*=============================================================================
77 * Global variables
78 *============================================================================*/
79
80extern const char *cs_rank_neighbors_exchange_name[];
81
82/*=============================================================================
83 * Public function prototypes
84 *============================================================================*/
85
86#if defined(HAVE_MPI)
87
88/*----------------------------------------------------------------------------*/
97/*----------------------------------------------------------------------------*/
98
99cs_rank_neighbors_t *
100cs_rank_neighbors_create(size_t n_elts,
101 const int elt_rank[]);
102
103/*----------------------------------------------------------------------------*/
109/*----------------------------------------------------------------------------*/
110
111void
112cs_rank_neighbors_destroy(cs_rank_neighbors_t **n);
113
114/*----------------------------------------------------------------------------*/
128/*----------------------------------------------------------------------------*/
129
130void
131cs_rank_neighbors_to_index(const cs_rank_neighbors_t *n,
132 size_t n_elts,
133 const int elt_rank[],
134 int *elt_rank_index);
135
136/*----------------------------------------------------------------------------*/
146/*----------------------------------------------------------------------------*/
147
148void
149cs_rank_neighbors_symmetrize(cs_rank_neighbors_t *n,
150 MPI_Comm comm);
151
152/*----------------------------------------------------------------------------*/
164/*----------------------------------------------------------------------------*/
165
166void
167cs_rank_neighbors_count(const cs_rank_neighbors_t *n,
168 size_t n_elts,
169 const int *elt_rank_index,
170 cs_lnum_t *elt_rank_count);
171
172/*----------------------------------------------------------------------------*/
185/*----------------------------------------------------------------------------*/
186
187void
188cs_rank_neighbors_sync_count(const cs_rank_neighbors_t *n_send,
189 cs_rank_neighbors_t **n_recv,
190 const cs_lnum_t *send_count,
191 cs_lnum_t **recv_count,
192 MPI_Comm comm);
193
194/*----------------------------------------------------------------------------*/
209/*----------------------------------------------------------------------------*/
210
211void
212cs_rank_neighbors_sync_count_m(const cs_rank_neighbors_t *n_send,
213 cs_rank_neighbors_t **n_recv,
214 const cs_lnum_t *send_count,
215 cs_lnum_t **recv_count,
216 cs_rank_neighbors_exchange_t exchange_type,
217 MPI_Comm comm);
218
219#endif /* defined(HAVE_MPI) */
220
227/*----------------------------------------------------------------------------*/
228
231
232/*----------------------------------------------------------------------------*/
238/*----------------------------------------------------------------------------*/
239
240void
242
243/*----------------------------------------------------------------------------*/
244
246
247#endif /* __CS_RANK_NEIGHBORS_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
Definition cs_defs.h:335
@ t
Definition cs_field_pointer.h:94
void cs_rank_neighbors_set_exchange_type(cs_rank_neighbors_exchange_t t)
Set current type of rank neighbors collective algorithm choice.
Definition cs_rank_neighbors.cpp:1025
const char * cs_rank_neighbors_exchange_name[]
cs_rank_neighbors_exchange_t cs_rank_neighbors_get_exchange_type(void)
Get current type of rank neighbors collective algorithm choice.
Definition cs_rank_neighbors.cpp:1011
Definition cs_rank_neighbors.h:55
@ CS_RANK_NEIGHBORS_PEX
Definition cs_rank_neighbors.h:57
@ CS_RANK_NEIGHBORS_NBX
Definition cs_rank_neighbors.h:58
@ CS_RANK_NEIGHBORS_CRYSTAL_ROUTER
Definition cs_rank_neighbors.h:59
