Variables definition initialization, according to calculation type selected by the user.
More...
| subroutine | fldvar () |
| subroutine | add_variable_field (name, label, dim, ivar) |
| | add field defining a general solved variable, with default options
| subroutine | add_user_scalar_fields () |
| | add fields defining user solved scalar variables, with default options
| subroutine | add_model_scalar_field (name, label, iscal) |
| | add field defining a non-user solved scalar variable, with default options
| subroutine | add_model_field (name, label, dim, iscal) |
| | add field defining a non-user solved variable, with default options
| subroutine | add_variable_field_indexes (f_id, ivar) |
| | add field indexes associated with a new non-user solved scalar variable, with default options
| subroutine | add_model_field_indexes (f_id, iscal) |
| subroutine | map_variable_field_try (name, ivar) |
| | Map field defining a general solved variable to Fortran id.
| subroutine | fldvar_check_nvar |
| | Check nvarmx is sufficient for the required number of variables.
| subroutine | init_var_cal_opt (id) |
| | Initialize the given variable calculation option structure with legacy values (iniini) allowing to later test user modification.
| subroutine | fldvar_check_nscapp |
| | Check nscamx is sufficient for the required number of model scalars.
| integer(c_int) function | cs_add_variable_field_indexes (f_id) |
| | add field indexes associated with a new non-user solved variable, with default options
| integer(c_int) function | cs_c_add_model_field_indexes (f_id) |
| subroutine | cs_c_add_model_thermal_field_indexes (f_id) |
| | add field indexes associated with a new solved thermal variable, with default options
◆ add_model_field()
| subroutine add_model_field |
character(len=*), intent(in) | name, |
character(len=*), intent(in) | label, |
integer, intent(in) | dim, |
integer, intent(out) | iscal ) |
It is recommended not to define variable names of more than 16 characters, to get a clear execution log (some advanced writing levels take into account only the first 16 characters).
- Parameters
| [in] | name | field name |
| [in] | label | field default label, or empty |
| [in] | dim | field dimension |
| [out] | iscal | variable number for defined field |
◆ add_model_field_indexes()
| subroutine add_model_field_indexes |
integer, intent(in) | f_id, |
- Parameters
| [in] | f_id | field id |
| [out] | iscal | scalar id for defined field |
◆ add_model_scalar_field()
| subroutine add_model_scalar_field |
- Parameters
| [out] | iscal | scalar number for defined field |
◆ add_user_scalar_fields()
| subroutine add_user_scalar_fields |
◆ add_variable_field()
| subroutine add_variable_field |
integer, intent(out) | ivar ) |
- Parameters
| [out] | ivar | variable number for defined field |
◆ add_variable_field_indexes()
| subroutine add_variable_field_indexes |
- Parameters
◆ cs_add_variable_field_indexes()
| integer(c_int) function cs_add_variable_field_indexes |
integer(c_int), value | f_id | ) |
- Parameters
- Returns
- variable number for defined field
◆ cs_c_add_model_field_indexes()
| integer(c_int) function cs_c_add_model_field_indexes |
- Parameters
- Returns
- scalar number for defined field
◆ cs_c_add_model_thermal_field_indexes()
| subroutine cs_c_add_model_thermal_field_indexes |
- Parameters
◆ fldvar()
◆ fldvar_check_nscapp()
| subroutine fldvar_check_nscapp |
◆ fldvar_check_nvar()
| subroutine fldvar_check_nvar |
◆ init_var_cal_opt()
| subroutine init_var_cal_opt |
integer | id | ) |
◆ map_variable_field_try()
| subroutine map_variable_field_try |
If field is not available, value is at 0
- Parameters
| [out] | ivar | variable id, or 0 |
