Main time loop. More...
#include "base/cs_defs.h"#include <float.h>#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include "base/cs_1d_wall_thermal.h"#include "base/cs_1d_wall_thermal_check.h"#include "base/cs_ale.h"#include "base/cs_array.h"#include "atmo/cs_at_data_assim.h"#include "atmo/cs_atmo.h"#include "base/cs_boundary_conditions.h"#include "base/cs_boundary_conditions_set_coeffs.h"#include "cdo/cs_cdo_main.h"#include "cfbl/cs_cf_boundary_conditions.h"#include "base/cs_control.h"#include "base/cs_coupling.h"#include "cdo/cs_domain_op.h"#include "cdo/cs_domain_setup.h"#include "base/cs_field_pointer.h"#include "base/cs_gas_mix.h"#include "gui/cs_gui.h"#include "base/cs_ibm.h"#include "base/cs_initialize_fields.h"#include "lagr/cs_lagr.h"#include "lagr/cs_lagr_lec.h"#include "turb/cs_les_balance.h"#include "turb/cs_les_inflow.h"#include "base/cs_log_iteration.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_save.h"#include "base/cs_mobile_structures.h"#include "base/cs_parall.h"#include "base/cs_parameters.h"#include "pprt/cs_physical_model.h"#include "base/cs_physical_properties_default.h"#include "base/cs_porosity_from_scan.h"#include "base/cs_porous_model.h"#include "base/cs_post.h"#include "base/cs_post_default.h"#include "base/cs_prototypes.h"#include "rayt/cs_rad_transfer.h"#include "rayt/cs_rad_transfer_restart.h"#include "base/cs_resource.h"#include "base/cs_restart.h"#include "base/cs_restart_default.h"#include "base/cs_restart_main_and_aux.h"#include "base/cs_restart_map.h"#include "base/cs_runaway_check.h"#include "base/cs_sat_coupling.h"#include "base/cs_solve_all.h"#include "base/cs_time_moment.h"#include "base/cs_time_step.h"#include "base/cs_timer_stats.h"#include "base/cs_turbomachinery.h"#include "turb/cs_turbulence_bc.h"#include "turb/cs_turbulence_htles.h"#include "turb/cs_turbulence_model.h"#include "base/cs_vof.h"#include "base/cs_volume_mass_injection.h"#include "base/cs_wall_condensation.h"#include "base/cs_wall_condensation_1d_thermal.h"#include "base/cs_time_stepping.h"Functions | |
| void | cs_f_boundary_conditions_init (void) |
| void | cs_f_init_chemistry_reacnum (void) |
| void | cs_f_atmsol (void) |
| void | cs_f_user_extra_operations_wrapper (cs_real_t dt[]) |
| void | cs_f_finalize_meteo (void) |
| void | cs_f_finalize_imbrication (void) |
| void | cs_f_finalize_chemistry (void) |
| void | cs_f_finalize_steady_laminar_flamelet_library (void) |
| void | cs_time_stepping (void) |
| Main time loop. | |
| void | cs_time_stepping_write_checkpoint (bool checkpoint_mesh) |
| Output a checkpoint. | |
Main time loop.
Main time loop.
| void cs_f_atmsol | ( | void | ) |
| void cs_f_boundary_conditions_init | ( | void | ) |
| void cs_f_finalize_chemistry | ( | void | ) |
| void cs_f_finalize_imbrication | ( | void | ) |
| void cs_f_finalize_meteo | ( | void | ) |
| void cs_f_finalize_steady_laminar_flamelet_library | ( | void | ) |
| void cs_f_init_chemistry_reacnum | ( | void | ) |
| void cs_f_user_extra_operations_wrapper | ( | cs_real_t | dt[] | ) |
| void cs_time_stepping | ( | void | ) |
Main time loop.
| void cs_time_stepping_write_checkpoint | ( | bool | checkpoint_mesh | ) |
If needed, the mesh is also output in the checkpoint directory, exect if this function is called for checkpoint serialized in memory (which is a special case for FMI exchange).
| [in] | checkpoint_mesh | also save mesh in checkpoint directory |
