#include "base/cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdarg.h>#include <stdlib.h>#include <string.h>#include <math.h>#include <float.h>#include <ple_locator.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "fvm/fvm_nodal.h"#include "fvm/fvm_nodal_extract.h"#include "fvm/fvm_point_location.h"#include "base/cs_base.h"#include "base/cs_boundary_conditions_set_coeffs.h"#include "base/cs_boundary_zone.h"#include "base/cs_coupling.h"#include "cdo/cs_domain.h"#include "base/cs_field.h"#include "base/cs_field_pointer.h"#include "base/cs_field_default.h"#include "base/cs_field_operator.h"#include "base/cs_file_csv_parser.h"#include "mesh/cs_geom.h"#include "base/cs_halo.h"#include "base/cs_io.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_connect.h"#include "mesh/cs_mesh_location.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parall.h"#include "base/cs_porous_model.h"#include "base/cs_equation_iterative_solve.h"#include "base/cs_physical_constants.h"#include "base/cs_post.h"#include "base/cs_timer.h"#include "base/cs_volume_zone.h"#include "base/cs_porosity_from_scan.h"Functions | |
| void | cs_porosity_from_scan_set_file_name (const char *file_name) |
| Set the file name of points for the computation of the porosity from scan. | |
| void | cs_porosity_from_scan_set_output_name (const char *output_name) |
| Set the output name for the FVM writer of scan points. | |
| void | cs_porosity_from_scan_add_source (const cs_real_t source[3], bool transform) |
| Add a scanner source point. | |
| void | cs_ibm_add_sources_by_file_name (const char *file_name) |
| Add the scanner sources from csv file to fill fluid space. | |
| void | cs_compute_porosity_from_scan (void) |
| Computes the porosity which is equal to one from a source, radiating sphericaly, and is 0 when touching points of the scan. | |
| void | cs_porous_model_restart_write (void) |
| Write the restart file of the ibm module. | |
| void | cs_porous_model_restart_read (void) |
| Read the restart file of the ibm module. | |
| void cs_compute_porosity_from_scan | ( | void | ) |
Compute the porosity which is equal to one from a source, radiating sphericaly, and is 0 when touching points of the scan.
This function solves the following transport equation on
![\[ \dfrac{\partial \varia}{\partial t} + \divs \left( \varia \vect{e}_r \right)
- \divs \left( \vect{e}_r \right) \varia = 0
\]](form_212.png)
where
The boundary conditions on
![\[ \dfrac{\partial \varia}{\partial n} = 0 \textrm{everywhere}
\]](form_216.png)
Remarks:
| void cs_ibm_add_sources_by_file_name | ( | const char * | file_name | ) |
| [in] | csv | file containing the (x,y,z) coordinates of each scanner |
| [in] | source | source vector |
| [in] | transform | flag to apply the transformation matrix to the source |
| void cs_porosity_from_scan_set_file_name | ( | const char * | file_name | ) |
| [in] | file_name | name of the file. |
| void cs_porosity_from_scan_set_output_name | ( | const char * | output_name | ) |
| [in] | output_name | name of the output (a suffix will be added) |
| void cs_porous_model_restart_read | ( | void | ) |
| void cs_porous_model_restart_write | ( | void | ) |
