fvm_nodal_extract.h
1#ifndef __FVM_NODAL_EXTRACT_H__
2#define __FVM_NODAL_EXTRACT_H__
5 * Main structure for a nodal representation associated with a mesh
30#include "base/cs_defs.h"
33 * Local headers
36#include "fvm/fvm_defs.h"
37#include "fvm/fvm_nodal.h"
38
43/*=============================================================================
44 * Macro definitions
46
48 * Type definitions
50
51/*----------------------------------------------------------------------------
52 * Structure defining a mesh in nodal definition
53 *----------------------------------------------------------------------------*/
54
55
56/*=============================================================================
57 * Static global variables
58 *============================================================================*/
59
60
61/*=============================================================================
62 * Public function prototypes
63 *============================================================================*/
64
65/*----------------------------------------------------------------------------
66 * Copy global vertex numbers to an array.
67 *
68 * parameters:
69 * this_nodal <-- pointer to nodal mesh structure
70 * g_vtx_num --> global vertex numbers (pre-allocated)
71 *----------------------------------------------------------------------------*/
72
73void
74fvm_nodal_get_global_vertex_num(const fvm_nodal_t *this_nodal,
75 cs_gnum_t *g_vtx_num);
76
77/*----------------------------------------------------------------------------
78 * Copy global element numbers of a given element type to an array.
79 *
80 * Note that if the mesh contains multiple sections of the same element type,
81 * the global element numbers are continued from one section to the next,
82 * so to the user, all is as if the sections were concatenated.
83 *
84 * parameters:
85 * this_nodal <-- pointer to nodal mesh structure
86 * element_type <-- type of elements to deal with
87 * g_elt_num <-> pointer to global_element_num array (pre-allocated)
88 *
89 * returns:
90 *----------------------------------------------------------------------------*/
91
92void
93fvm_nodal_get_global_element_num(const fvm_nodal_t *this_nodal,
94 fvm_element_t element_type,
95 cs_gnum_t *g_elt_num);
96
97/*----------------------------------------------------------------------------
98 * Copy vertex coordinates to an array.
99 *
100 * parameters:
101 * this_nodal <-- pointer to nodal mesh structure
102 * interlace <-- indicates if destination array is interlaced
103 * vertex_coords --> vertices coordinates (pre-allocated)
104 *----------------------------------------------------------------------------*/
105
106void
107fvm_nodal_get_vertex_coords(const fvm_nodal_t *this_nodal,
108 cs_interlace_t interlace,
109 cs_coord_t *vertex_coords);
110
111/*----------------------------------------------------------------------------
112 * Copy element centers to an array.
113 *
114 * Note that if the mesh contains multiple cell element sections of, the
115 * cell_centers array spans all sections, so to the user, all is as if the
116 * sections were concatenated.
117 *
118 * parameters:
119 * this_nodal <-- pointer to nodal mesh structure
120 * interlace <-- indicates if destination array is interlaced
121 * entity_dim <-- dimension of entities we want to count (0 to 3)
122 * cell_centers --> cell centers coordinates (pre-allocated)
123 *----------------------------------------------------------------------------*/
124
125void
126fvm_nodal_get_element_centers(const fvm_nodal_t *this_nodal,
127 cs_interlace_t interlace,
128 int entity_dim,
129 cs_coord_t *cell_centers);
130
131/*----------------------------------------------------------------------------
132 * Copy element -> vertex connectivity of a given element type to an array.
133 *
134 * Note that if the mesh contains multiple sections of the same element type,
135 * the connectivity spans all sections, so to the user, all is as if the
136 * sections were concatenated.
137 *
138 * Return local connectivity for sections of a given element_type.
139 *
140 * parameters:
141 * this_nodal <-- pointer to nodal mesh structure
142 * element_type <-- type of elements of the section to deal with
143 * connectivity <-> pointer to connectvity (pre-allocated)
144 *----------------------------------------------------------------------------*/
145
146void
147fvm_nodal_get_strided_connect(const fvm_nodal_t *this_nodal,
148 fvm_element_t element_type,
149 cs_lnum_t *connectivity);
150
151/*----------------------------------------------------------------------------
152 * Build inverse vertex -> element connectivity.
153 *
154 * The user is responsible for freeing the returned arrays.
155 * The size of element_index[] should be n_vertices + 1, where n_vertices
156 * is the value returned by fvm_nodal_get_n_entities(this_nodal, entity_dim).
157 * The size of element_id[] should be element_index[n_vertices].
158 *
159 * Note that if the mesh contains multiple cell element sections of, the
160 * cell_centers array spans all sections, so to the user, all is as if the
161 * sections were concatenated.
162 *
163 * Note also that both the vertex -> element index and connectivity arrays
164 * returned use 0 to n numbering.
165 *
166 * parameters:
167 * this_nodal <-- pointer to nodal mesh structure
168 * entity_dim <-- dimension of entities we want to count (1 to 3)
169 * element_index --> vertex -> element connectivity index (O to n-1)
170 * element_id --> vertex -> element connectivity (0 to n-1)
171 *----------------------------------------------------------------------------*/
172
173void
174fvm_nodal_get_vertex_elements(const fvm_nodal_t *this_nodal,
175 int entity_dim,
176 cs_lnum_t **element_index,
177 cs_lnum_t **element_id);
178
179/*----------------------------------------------------------------------------
180 * Compute extents of a nodal mesh representation
181 *
182 * parameters:
183 * this_nodal <-- pointer to mesh representation structure
184 * tolerance <-- addition to local extents of each element:
185 * extent = base_extent * (1 + tolerance)
186 * extents <-> extents associated with mesh:
187 * x_min, y_min, ..., x_max, y_max, ... (size: 2*dim)
188 *----------------------------------------------------------------------------*/
189
190void
191fvm_nodal_extents(const fvm_nodal_t *this_nodal,
192 double tolerance,
193 double extents[]);
194
195/*----------------------------------------------------------------------------*/
196
198
199#endif /* __FVM_NODAL_EXTRACT_H__ */
Definition cs_defs.h:542
double cs_coord_t
Definition cs_defs.h:340
cs_interlace_t
Definition cs_defs.h:514
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
Definition cs_defs.h:335
fvm_element_t
Definition fvm_defs.h:48
void fvm_nodal_get_global_vertex_num(const fvm_nodal_t *this_nodal, cs_gnum_t *g_vtx_num)
Definition fvm_nodal_extract.cpp:857
void fvm_nodal_get_global_element_num(const fvm_nodal_t *this_nodal, fvm_element_t element_type, cs_gnum_t *g_elt_num)
Definition fvm_nodal_extract.cpp:899
void fvm_nodal_get_vertex_elements(const fvm_nodal_t *this_nodal, int entity_dim, cs_lnum_t **element_index, cs_lnum_t **element_id)
Definition fvm_nodal_extract.cpp:1250
void fvm_nodal_get_strided_connect(const fvm_nodal_t *this_nodal, fvm_element_t element_type, cs_lnum_t *connectivity)
Definition fvm_nodal_extract.cpp:1184
void fvm_nodal_extents(const fvm_nodal_t *this_nodal, double tolerance, double extents[])
Definition fvm_nodal_extract.cpp:1423
void fvm_nodal_get_element_centers(const fvm_nodal_t *this_nodal, cs_interlace_t interlace, int entity_dim, cs_coord_t *cell_centers)
Definition fvm_nodal_extract.cpp:1038
void fvm_nodal_get_vertex_coords(const fvm_nodal_t *this_nodal, cs_interlace_t interlace, cs_coord_t *vertex_coords)
Definition fvm_nodal_extract.cpp:971
