cs_calcium.h File Reference
#include "base/cs_base.h"
Include dependency graph for cs_calcium.h:
int cs_calcium_read_int (int rank_id, int *iteration, const char *var_name, int n_val_max, int *n_val_read, int val[])
int cs_calcium_read_double (int rank_id, int *iteration, const char *var_name, int n_val_max, int *n_val_read, double val[])
int cs_calcium_write_int (int rank_id, int iteration, const char *var_name, int n_val, const int val[])
int cs_calcium_write_double (int rank_id, int iteration, const char *var_name, int n_val, const double val[])
void cs_calcium_set_verbosity (int n_echo)
◆ cs_calcium_read_double()
int cs_calcium_read_double ( int rank_id,
int * iteration,
const char * var_name,
int n_val_max,
int * n_val_read,
double val[] )
◆ cs_calcium_read_int()
int cs_calcium_read_int ( int rank_id,
int * iteration,
int n_val_max,
int * n_val_read,
int val[] )
◆ cs_calcium_set_verbosity()
void cs_calcium_set_verbosity ( int n_echo)
◆ cs_calcium_write_double()
int cs_calcium_write_double ( int rank_id,
int iteration,
int n_val,
const double val[] )
◆ cs_calcium_write_int()
int cs_calcium_write_int ( int rank_id,
int iteration,
int n_val,
const int val[] )
