#include "base/cs_defs.h"#include <assert.h>#include <stdio.h>#include <string.h>#include "bft/bft_printf.h"#include "base/cs_mem.h"#include "base/cs_order.h"Functions | |
| int | cs_order_gnum_test (const cs_lnum_t list[], const cs_gnum_t number[], size_t nb_ent) |
| Test if an array of global numbers is ordered. | |
| cs_lnum_t * | cs_order_gnum (const cs_lnum_t list[], const cs_gnum_t number[], size_t nb_ent) |
| Return an ordering table associated with an array of global numbers. | |
| cs_lnum_t * | cs_order_gnum_s (const cs_lnum_t list[], const cs_gnum_t number[], size_t stride, size_t nb_ent) |
| Return a lexicographical ordering table associated with a strided array of global numbers. | |
| cs_lnum_t * | cs_order_gnum_i (const cs_lnum_t list[], const cs_gnum_t number[], const cs_lnum_t index[], size_t nb_ent) |
| Return a lexicographical ordering table associated with an indexed array of global numbers. | |
| void | cs_order_gnum_allocated (const cs_lnum_t list[], const cs_gnum_t number[], cs_lnum_t order[], size_t nb_ent) |
| Compute an ordering table associated with an array of global numbers. | |
| void | cs_order_gnum_allocated_s (const cs_lnum_t list[], const cs_gnum_t number[], size_t stride, cs_lnum_t order[], size_t nb_ent) |
| Compute a lexicographical ordering table associated with an array of strided global numbers. | |
| void | cs_order_gnum_allocated_i (const cs_lnum_t list[], const cs_gnum_t number[], const cs_lnum_t index[], cs_lnum_t order[], size_t nb_ent) |
| Compute a lexicographical ordering table associated with an indexed array of global numbers. | |
| void | cs_order_lnum_allocated (const cs_lnum_t list[], const cs_lnum_t number[], cs_lnum_t order[], size_t nb_ent) |
| Compute an ordering table associated with an array of local numbers. | |
| void | cs_order_lnum_allocated_s (const cs_lnum_t list[], const cs_lnum_t number[], size_t stride, cs_lnum_t order[], const size_t nb_ent) |
| Compute a lexicographical ordering table associated with an array of strided local numbers. | |
| void | cs_order_real_allocated (const cs_lnum_t list[], const cs_real_t val[], cs_lnum_t order[], size_t nb_ent) |
| Compute an ordering table associated with an array of local values. | |
| cs_lnum_t * | cs_order_renumbering (const cs_lnum_t order[], size_t nb_ent) |
| Build local renumbering array based on ordering of entities. | |
| void | cs_order_reorder_data (cs_lnum_t n_elts, size_t elt_size, const cs_lnum_t order[], void *data) |
| Reorder data based on ordering array. | |
| void | cs_order_single_gnum (size_t n_ent, const cs_gnum_t base, const cs_gnum_t number[], size_t *n_single, cs_gnum_t *single[]) |
| Build a sorted array containing a single occurence of each global number in a given array. | |
| [in] | list | optional list (0 to n-1 numbering) of selected entities (or null if all nb_ent are selected). This list may contain element numbers in any order |
| [in] | number | array of all entity numbers (number of entity i given by number[i] or number[list[i]]) if list exists (if nullptr, a default 0 to n-1 numbering is considered) |
| [in] | nb_ent | number of entities considered |
| void cs_order_gnum_allocated | ( | const cs_lnum_t | list[], |
| const cs_gnum_t | number[], | ||
| cs_lnum_t | order[], | ||
| size_t | nb_ent ) |
| [out] | order | pointer to pre-allocated ordering table |
| void cs_order_gnum_allocated_i | ( | const cs_lnum_t | list[], |
| const cs_lnum_t | index[], | ||
| size_t | nb_ent ) |
| [in] | number | array of all entity numbers (numbers of entity i start at index[i] or _index[i] (reduced index) if list exists). If list = nullptr, a default 0 to n-1 numbering is considered) |
| [in] | index | number of values to compare for each entity (from 0) |
| void cs_order_gnum_allocated_s | ( | const cs_lnum_t | list[], |
| size_t | stride, | ||
| size_t | nb_ent ) |
| [in] | number | array of all entity numbers (numbers of entity i start at number[i*stride] or number[list[i]*stride]) if list exists (if nullptr, a default 0 to n-1 numbering is considered) |
| [in] | stride | stride of number array (number of values to compare) |
| cs_lnum_t * cs_order_gnum_i | ( | const cs_lnum_t | list[], |
| size_t | nb_ent ) |
| [in] | index | number of values to compare for each entity |
| cs_lnum_t * cs_order_gnum_s | ( | const cs_lnum_t | list[], |
| size_t | nb_ent ) |
| [in] | number | array of all entity numbers (number of entity i given by number[i] or number[list[i]]) if list exists |
| void cs_order_lnum_allocated | ( | const cs_lnum_t | list[], |
| const cs_lnum_t | number[], | ||
| size_t | nb_ent ) |
| void cs_order_lnum_allocated_s | ( | const cs_lnum_t | list[], |
| const size_t | nb_ent ) |
| void cs_order_real_allocated | ( | const cs_lnum_t | list[], |
| const cs_real_t | val[], | ||
| size_t | nb_ent ) |
| [in] | val | array of all entity values (value of entity i given by value[i] or value[list[i]]) if list exists (if nullptr, a default 0 to n-1 numbering is considered) |
| [in] | order | 0 to n-1 ordering of entities by increasing attribute |
| void cs_order_reorder_data | ( | cs_lnum_t | n_elts, |
| size_t | elt_size, | ||
| const cs_lnum_t | order[], | ||
| void * | data ) |
| [in] | elt_size | element size |
| [in] | order | reordering array |
| [in,out] | data | data |
| void cs_order_single_gnum | ( | size_t | n_ent, |
| const cs_gnum_t | base, | ||
| size_t * | n_single, | ||
| cs_gnum_t * | single[] ) |
Global numbers under a given "base" value are extruded.
The caller is responsible for freeing the returned array.
| [in] | n_ent | size of input array |
| [in] | base | base id; numbers lower than this are dropped |
| [in] | number | array containing of all referenced entity numbers |
| [out] | n_single | array number of single occurences >= base |
| [out] | single | sorted array of unique numbers >= base |
