#include "base/cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_mem.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_connect.h"#include "base/cs_parall.h"#include "base/cs_prototypes.h"#include "base/cs_selector.h"#include "base/cs_timer.h"#include "fvm/fvm_defs.h"#include "fvm/fvm_nodal_from_desc.h"#include "cs_medcoupling_mesh.hxx"#include "base/cs_paramedmem_remapper.h"Functions | |
| cs_paramedmem_remapper_t * | cs_paramedmem_remapper_create (char *name, const char *sel_criteria, char *file_name, char *mesh_name, cs_real_t center[3], cs_real_t radius) |
| Creates a new cs_paramedmem_remapper_t instance. | |
| cs_paramedmem_remapper_t * | cs_paramedmem_remapper_by_name_try (const char *name) |
| get a remapper by its name | |
| cs_real_t * | cs_paramedmem_remap_field_one_time (cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int dt, int it) |
| Remaps a field from the med file to the local mesh for a given time. | |
| cs_real_t * | cs_paramedmem_remap_field (cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int time_choice, double tval) |
| Interpolate a given field on the local mesh for a given time. | |
| void | cs_paramedmem_remapper_translate (cs_paramedmem_remapper_t *r, cs_real_t translation[3]) |
| translate the mesh using a given vector | |
| void | cs_paramedmem_remapper_rotate (cs_paramedmem_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle) |
| Rotate the mesh using a center point, axis and angle. | |
| void | cs_paramedmem_remapper_destroy_all (void) |
| Destroy all remappers. | |
| cs_real_t * cs_paramedmem_remap_field | ( | cs_paramedmem_remapper_t * | r, |
| char * | field_name, | ||
| cs_real_t | default_val, | ||
| int | time_choice, | ||
| double | tval ) |
| [in] | r | pointer to cs_paramedmem_remapper_t struct |
| [in] | field_name | name of the field to remap from the file |
| [in] | default_val | default value for unmapped elements |
| [in] | time_choice | Choice of the time interpolation. 0: Value of field interpolated at t=tval from the med file. 1: Returns field values for the first time step in the file. tval is then ignored. 2: Returns field values for the last time step in the file. tval is then ignored. |
| [in] | tval | requested time instant. If time choice is 0 and tval outside of the file time bounds, return value will be at the the first time step (if tval < tmin) or last time step (if tval > tmax) |
| cs_real_t * cs_paramedmem_remap_field_one_time | ( | cs_paramedmem_remapper_t * | r, |
| int | dt, | ||
| int | it ) |
| [in] | dt | time value to use from the file |
| [in] | it | time iteration to use from the file |
| cs_paramedmem_remapper_t * cs_paramedmem_remapper_by_name_try | ( | const char * | name | ) |
| [in] | name | name of the remapper |
| cs_paramedmem_remapper_t * cs_paramedmem_remapper_create | ( | char * | name, |
| const char * | sel_criteria, | ||
| char * | file_name, | ||
| char * | mesh_name, | ||
| cs_real_t | center[3], | ||
| cs_real_t | radius ) |
| [in] | sel_criteria | cells selection criteria |
| [in] | file_name | med file name |
| [in] | mesh_name | name of the mesh in the med file |
| [in] | center | center of bounding sphere |
| [in] | radius | radius of bounding sphere |
| void cs_paramedmem_remapper_destroy_all | ( | void | ) |
| void cs_paramedmem_remapper_rotate | ( | cs_paramedmem_remapper_t * | r, |
| cs_real_t | invariant[3], | ||
| cs_real_t | axis[3], | ||
| cs_real_t | angle ) |
| [in] | r | pointer to the cs_paramedmem_remapper_t struct |
| [in] | invariant | coordinates of the invariant point |
| [in] | axis | rotation axis vector |
| [in] | angle | rotation angle in radians |
| void cs_paramedmem_remapper_translate | ( | cs_paramedmem_remapper_t * | r, |
| cs_real_t | translation[3] ) |
| [in] | translation | translation vector |
