file | condli.f90 |
| Translation of the boundary conditions given by cs_user_boundary_conditions in a form that fits to the solver.
file | cs_1d_wall_thermal.cpp |
file | cs_1d_wall_thermal.h [code] |
file | cs_1d_wall_thermal_check.cpp |
file | cs_1d_wall_thermal_check.h [code] |
file | cs_ale.cpp |
file | cs_ale.h [code] |
file | cs_all_to_all.cpp |
file | cs_all_to_all.h [code] |
file | cs_array.cpp |
file | cs_array.h [code] |
file | cs_array_cuda.h [code] |
file | cs_array_reduce.cpp |
file | cs_array_reduce.h [code] |
file | cs_assert.h [code] |
file | cs_ast_coupling.cpp |
file | cs_ast_coupling.h [code] |
file | cs_base.cpp |
file | cs_base.h [code] |
file | cs_base_accel.cpp |
file | cs_base_accel.h [code] |
file | cs_base_cuda.h [code] |
file | cs_base_fortran.c |
file | cs_base_fortran.h [code] |
file | cs_base_headers.h [code] |
file | cs_block_dist.cpp |
file | cs_block_dist.h [code] |
file | cs_block_to_part.cpp |
file | cs_block_to_part.h [code] |
file | cs_boundary.cpp |
| Handle the "physical" boundary conditions attached to a computational domain.
file | cs_boundary.h [code] |
file | cs_boundary_conditions.cpp |
file | cs_boundary_conditions.h [code] |
file | cs_boundary_conditions_check.cpp |
file | cs_boundary_conditions_check.h [code] |
file | cs_boundary_conditions_coupling.cpp |
file | cs_boundary_conditions_coupling.h [code] |
file | cs_boundary_conditions_priv.h [code] |
file | cs_boundary_conditions_set_coeffs.cpp |
file | cs_boundary_conditions_set_coeffs.h [code] |
file | cs_boundary_conditions_set_coeffs_symmetry.cpp |
file | cs_boundary_conditions_set_coeffs_symmetry.h [code] |
file | cs_boundary_conditions_set_coeffs_turb.cpp |
file | cs_boundary_conditions_set_coeffs_turb.h [code] |
file | cs_boundary_conditions_type.cpp |
file | cs_boundary_conditions_type.h [code] |
file | cs_boundary_zone.cpp |
file | cs_boundary_zone.h [code] |
file | cs_c_bindings.f90 |
| Definition of C function and subroutine bindings.
file | cs_calcium.cpp |
file | cs_calcium.h [code] |
file | cs_compute_thermo_pressure_density.cpp |
file | cs_compute_thermo_pressure_density.h [code] |
file | cs_control.cpp |
file | cs_control.h [code] |
file | cs_coolprop.cxx |
file | cs_coolprop.hxx [code] |
file | cs_coupling.cpp |
file | cs_coupling.h [code] |
file | cs_crystal_router.cpp |
file | cs_crystal_router.h [code] |
file | cs_cuda_contrib.h [code] |
file | cs_debug.h [code] |
file | cs_defs.cpp |
file | cs_defs.h [code] |
file | cs_dilatable_scalar_diff_st.cpp |
file | cs_dilatable_scalar_diff_st.h [code] |
| Weakly compressible algorithm (semi-analytic): Computation of scalar diffusion terms.
file | cs_dispatch.h [code] |
file | cs_drift_convective_flux.cpp |
file | cs_drift_convective_flux.h [code] |
file | cs_eos.cxx |
file | cs_eos.hxx [code] |
file | cs_equation_iterative_solve.cpp |
| This file gathers functions that solve advection diffusion equations with source terms for one time step for a scalar, vector or tensor variable.
file | cs_equation_iterative_solve.h [code] |
file | cs_execution_context.cpp |
file | cs_execution_context.h [code] |
file | cs_ext_library_info.c |
file | cs_ext_library_info.h [code] |
file | cs_ext_neighborhood.cpp |
file | cs_ext_neighborhood.h [code] |
file | cs_fan.cpp |
file | cs_fan.h [code] |
file | cs_field.cpp |
file | cs_field.h [code] |
file | cs_field_default.cpp |
file | cs_field_default.h [code] |
file | cs_field_operator.cpp |
file | cs_field_operator.h [code] |
file | cs_field_pointer.cpp |
file | cs_field_pointer.h [code] |
file | cs_file.cpp |
file | cs_file.h [code] |
file | cs_file_csv_parser.cpp |
file | cs_file_csv_parser.h [code] |
file | cs_flag_check.cpp |
file | cs_flag_check.h [code] |
file | cs_fp_exception.cpp |
file | cs_fp_exception.h [code] |
file | cs_function.cpp |
| Function objects management.
file | cs_function.h [code] |
file | cs_function_default.cpp |
file | cs_function_default.h [code] |
file | cs_gas_mix.cpp |
file | cs_gas_mix.h [code] |
file | cs_halo.cpp |
file | cs_halo.h [code] |
file | cs_halo_cuda.h [code] |
file | cs_halo_perio.cpp |
file | cs_halo_perio.h [code] |
file | cs_head_losses.cpp |
file | cs_head_losses.h [code] |
file | cs_headers.h [code] |
file | cs_ht_convert.cpp |
file | cs_ht_convert.h [code] |
file | cs_ibm.cpp |
file | cs_ibm.h [code] |
file | cs_initialize_fields.cpp |
| Various field initializations.
file | cs_initialize_fields.h [code] |
file | cs_interface.cpp |
file | cs_interface.h [code] |
file | cs_internal_coupling.cpp |
file | cs_internal_coupling.h [code] |
file | cs_interpolate.cpp |
file | cs_interpolate.h [code] |
file | cs_io.cpp |
file | cs_io.h [code] |
file | cs_log.cpp |
file | cs_log.h [code] |
file | cs_log_iteration.cpp |
| Log field and other array statistics at relevant time steps.
file | cs_log_iteration.h [code] |
file | cs_log_setup.cpp |
| Setup info at the end of the setup stage.
file | cs_log_setup.h [code] |
file | cs_map.cpp |
file | cs_map.h [code] |
file | cs_mass_source_terms.cpp |
file | cs_mass_source_terms.h [code] |
file | cs_math.cpp |
file | cs_math.h [code] |
file | cs_measures_util.cpp |
file | cs_measures_util.h [code] |
file | cs_medcoupling_intersector.cxx |
file | cs_medcoupling_intersector.h [code] |
file | cs_medcoupling_mesh.cxx |
file | cs_medcoupling_mesh.hxx [code] |
file | cs_medcoupling_postprocess.cxx |
file | cs_medcoupling_postprocess.h [code] |
file | cs_medcoupling_remapper.cxx |
file | cs_medcoupling_remapper.h [code] |
file | cs_medcoupling_utils.cxx |
file | cs_medcoupling_utils.h [code] |
file | cs_mem.cpp |
file | cs_mem.h [code] |
file | cs_mem_cuda_priv.h [code] |
file | cs_mobile_structures.cpp |
file | cs_mobile_structures.h [code] |
file | cs_notebook.cpp |
file | cs_notebook.h [code] |
file | cs_numbering.cpp |
file | cs_numbering.h [code] |
file | cs_opts.cpp |
file | cs_opts.h [code] |
file | cs_order.cpp |
file | cs_order.h [code] |
file | cs_parall.cpp |
file | cs_parall.h [code] |
file | cs_param_types.cpp |
file | cs_param_types.h [code] |
file | cs_paramedmem_coupling.cxx |
file | cs_paramedmem_coupling.h [code] |
file | cs_paramedmem_remapper.cxx |
file | cs_paramedmem_remapper.h [code] |
file | cs_parameters.cpp |
file | cs_parameters.h [code] |
file | cs_parameters_check.cpp |
file | cs_parameters_check.h [code] |
file | cs_part_to_block.cpp |
file | cs_part_to_block.h [code] |
file | cs_physical_constants.cpp |
file | cs_physical_constants.h [code] |
file | cs_physical_properties.cpp |
file | cs_physical_properties.h [code] |
file | cs_physical_properties_default.cpp |
file | cs_physical_properties_default.h [code] |
file | cs_porosity_from_scan.cpp |
file | cs_porosity_from_scan.h [code] |
file | cs_porous_model.cpp |
| Porous model management.
file | cs_porous_model.h [code] |
file | cs_post.cpp |
file | cs_post.h [code] |
file | cs_post_default.cpp |
file | cs_post_default.h [code] |
file | cs_post_util.cpp |
file | cs_post_util.h [code] |
file | cs_preprocess.cpp |
file | cs_preprocess.h [code] |
file | cs_preprocessor_data.cpp |
file | cs_preprocessor_data.h [code] |
file | cs_pressure_correction.cpp |
file | cs_pressure_correction.h [code] |
file | cs_probe.cpp |
| Probes and profiles management.
file | cs_probe.h [code] |
file | cs_prototypes.h [code] |
file | cs_random.cpp |
file | cs_random.h [code] |
file | cs_range_set.cpp |
| Operations related to handling of an owning rank for distributed entities.
file | cs_range_set.h [code] |
file | cs_rank_neighbors.cpp |
file | cs_rank_neighbors.h [code] |
file | cs_renumber.cpp |
file | cs_renumber.h [code] |
file | cs_resource.cpp |
| Resource allocation management (available time).
file | cs_resource.h [code] |
file | cs_restart.cpp |
file | cs_restart.h [code] |
file | cs_restart_default.cpp |
file | cs_restart_default.h [code] |
file | cs_restart_main_and_aux.cpp |
file | cs_restart_main_and_aux.h [code] |
file | cs_restart_map.cpp |
file | cs_restart_map.h [code] |
file | cs_rotation.cpp |
file | cs_rotation.h [code] |
file | cs_runaway_check.cpp |
| Runaway (diverging) computation detection.
file | cs_runaway_check.h [code] |
file | cs_sat_coupling.cpp |
file | cs_sat_coupling.h [code] |
file | cs_scalar_clipping.cpp |
file | cs_scalar_clipping.h [code] |
file | cs_search.cpp |
file | cs_search.h [code] |
file | cs_selector.cpp |
file | cs_selector.h [code] |
file | cs_selector_f2c.f90 |
file | cs_setup.cpp |
file | cs_setup.h [code] |
file | cs_solid_zone.cpp |
file | cs_solid_zone.h [code] |
file | cs_solve_all.cpp |
file | cs_solve_all.h [code] |
file | cs_solve_equation.cpp |
file | cs_solve_equation.h [code] |
file | cs_solve_navier_stokes.cpp |
file | cs_solve_navier_stokes.h [code] |
file | cs_solve_transported_variables.cpp |
file | cs_solve_transported_variables.h [code] |
file | cs_sort.cpp |
file | cs_sort.h [code] |
file | cs_sort_partition.cpp |
file | cs_sort_partition.h [code] |
file | cs_syr_coupling.cpp |
file | cs_syr_coupling.h [code] |
file | cs_sys_coupling.cpp |
file | cs_sys_coupling.h [code] |
file | cs_system_info.cxx |
file | cs_system_info.h [code] |
file | cs_thermal_model.cpp |
file | cs_thermal_model.h [code] |
file | cs_theta_scheme.cpp |
file | cs_theta_scheme.h [code] |
file | cs_time_control.cpp |
file | cs_time_control.h [code] |
file | cs_time_moment.cpp |
file | cs_time_moment.h [code] |
file | cs_time_plot.cpp |
file | cs_time_plot.h [code] |
file | cs_time_step.cpp |
file | cs_time_step.h [code] |
file | cs_time_step_compute.cpp |
file | cs_time_step_compute.h [code] |
file | cs_time_stepping.cpp |
file | cs_time_stepping.h [code] |
file | cs_time_table.cpp |
file | cs_time_table.h [code] |
file | cs_timer.cpp |
file | cs_timer.h [code] |
file | cs_timer_stats.cpp |
file | cs_timer_stats.h [code] |
file | cs_tree.cpp |
file | cs_tree.h [code] |
file | cs_turbomachinery.cpp |
file | cs_turbomachinery.h [code] |
file | cs_utilities.cpp |
file | cs_utilities.h [code] |
file | cs_velocity_pressure.cpp |
file | cs_velocity_pressure.h [code] |
file | cs_vof.cpp |
file | cs_vof.h [code] |
file | cs_volume_mass_injection.cpp |
file | cs_volume_mass_injection.h [code] |
file | cs_volume_zone.cpp |
file | cs_volume_zone.h [code] |
file | cs_wall_condensation.cpp |
file | cs_wall_condensation.h [code] |
file | cs_wall_condensation_1d_thermal.cpp |
file | cs_wall_condensation_1d_thermal.h [code] |
file | cs_wall_distance.cpp |
file | cs_wall_distance.h [code] |
file | cs_wall_functions.cpp |
file | cs_wall_functions.h [code] |
file | cs_xdef_eval_at_zone.cpp |
file | cs_xdef_eval_at_zone.h [code] |
file | cs_zone.h [code] |
file | csclli.f90 |
file | csinit.f90 |
file | csopli.f90 |
file | csprnt.f90 |
file | cstnum.f90 |
| Module for numerical constants.
file | cstphy.f90 |
| Module for physical constants.
file | dimens.f90 |
| Module for dimensions.
file | entsor.f90 |
| Module for input/output.
file | field.f90 |
| Module for field-related operations.
file | field_operator.f90 |
| Module for field-based algebraic operations.
file | findpt.f90 |
| This subroutine looks for the nearest element to the position (xx, yy, zz) among the element of xyzcen array.
file | fldprp.f90 |
| Properties definition initialization, according to calculation type selected by the user.
file | fldvar.f90 |
| Variables definition initialization, according to calculation type selected by the user.
file | impini.f90 |
file | iniini.f90 |
| Commons default initialization before handing over the user.
file | majgeo.f90 |
file | mesh.f90 |
| Module for mesh-related arrays.
file | numvar.f90 |
| Module for variable numbering.
file | optcal.f90 |
| Module for calculation options.
file | parall.f90 |
| Module for basic MPI and OpenMP parallelism-related values.
file | paramx.f90 |
| Module for definition of general parameters.
file | period.f90 |
| Module for periodicity flags.
file | pointe.f90 |
| Module for pointer variables.
