1#ifndef __CS_PARAMETERS_CHECK_H__
2#define __CS_PARAMETERS_CHECK_H__
81 const char *section_desc,
84 __attribute__((format(printf, 3, 4)));
90 const char *section_desc,
108 const char *section_desc);
137 const char *section_desc,
138 const char *param_name,
160 const char *section_desc,
161 const char *param_name,
184 const char *section_desc,
185 const char *param_name,
188 const int *enum_values,
189 const char *enum_names[]);
210 const char *section_desc,
211 const char *param_name,
214 const int *enum_values,
215 const char *enum_names[]);
232 const char *section_desc,
233 const char *param_name,
252 const char *section_desc,
253 const char *param_name,
271 const char *section_desc,
272 const char *param_name,
290 const char *section_desc,
291 const char *param_name,
311 const char *section_desc,
312 const char *param_name,
334 const char *section_desc,
335 const char *param_name,
338 const double *enum_values,
339 const char *enum_names[]);
356 const char *section_desc,
357 const char *param_name,
376 const char *section_desc,
377 const char *param_name,
Definition: cs_defs.h:542
Definition: cs_defs.h:543
void cs_parameters_is_not_equal_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int fbd_value)
Check that a given integer keyword is not equal to a specified value.
Definition: cs_parameters_check.cpp:539
void cs_parameters_error_footer(cs_parameter_error_behavior_t err_behavior)
Print footer for a given parameters error message type.
Definition: cs_parameters_check.cpp:257
void cs_parameters_is_equal_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int std_value)
Check that a given integer keyword is equal to a specified value.
Definition: cs_parameters_check.cpp:496
void cs_parameters_error_barrier(void)
Abort if the the parameter errors count is nonzero.
Definition: cs_parameters_check.cpp:809
void cs_parameters_is_in_range_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int range_l, int range_u)
Check that a given integer keyword has values in a specified range.
Definition: cs_parameters_check.cpp:280
Definition: cs_parameters_check.h:52
@ CS_WARNING
Definition: cs_parameters_check.h:54
@ CS_ABORT_DELAYED
Definition: cs_parameters_check.h:55
@ CS_ABORT_IMMEDIATE
Definition: cs_parameters_check.h:57
void cs_parameters_is_positive_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value)
Check that a given integer keyword is strictly positive.
Definition: cs_parameters_check.cpp:573
void cs_parameters_is_in_list_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int enum_size, const int *enum_values, const char *enum_names[])
Definition: cs_parameters_check.cpp:357
void cs_parameters_error(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *format,...)
Print general parameters error or warning info.
Definition: cs_parameters_check.cpp:190
void cs_parameters_is_in_list_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, int enum_size, const double *enum_values, const char *enum_names[])
Check that a given double keyword has values in a specified list.
Definition: cs_parameters_check.cpp:681
void cs_parameters_is_not_in_list_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int enum_size, const int *enum_values, const char *enum_names[])
Check that a given integer keyword does not have values in a specified list.
Definition: cs_parameters_check.cpp:426
void cs_parameters_is_equal_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double std_value)
Check that a given double keyword is equal to a specified value.
Definition: cs_parameters_check.cpp:738
void cs_parameters_is_greater_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double ib_value)
Check that a given double keyword is greater than a specified value.
Definition: cs_parameters_check.cpp:781
void cs_parameters_is_not_in_range_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int range_l, int range_u)
Check that a given integer keyword has not values in a specified range.
Definition: cs_parameters_check.cpp:318
void cs_parameters_check(void)
Check computation parameters after user modification.
Definition: cs_parameters_check.cpp:833
void cs_parameters_is_in_range_double(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double range_l, double range_u)
Check that a given double keyword has values in a specified range.
Definition: cs_parameters_check.cpp:643
void cs_parameters_is_greater_int(cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int ib_value)
Check that a given int keyword is greater than a specified value.
Definition: cs_parameters_check.cpp:607
void cs_parameters_error_header(cs_parameter_error_behavior_t err_behavior, const char *section_desc)
Print header for a given parameters error message type.
Definition: cs_parameters_check.cpp:220
