8.3
cs_parameters.h
1#ifndef __CS_PARAMETERS_H__
2#define __CS_PARAMETERS_H__
5 * General parameters management.
34#include <stdarg.h>
37 * Local headers
38 *----------------------------------------------------------------------------*/
40#include "cs_defs.h"
41#include "cs_equation_param.h"
42#include "cs_field.h"
43#include "cs_tree.h"
45/*----------------------------------------------------------------------------*/
46
48
49/*=============================================================================
50 * Macro definitions
52
53/*============================================================================
54 * Type definitions
55 *============================================================================*/
56
57/*----------------------------------------------------------------------------
58 * Structure of variable calculation options
59 * (now an alias of cs_equation_param_t)
60 *----------------------------------------------------------------------------*/
61
63
64/*----------------------------------------------------------------------------
65 * Structure of the solving info
66 *----------------------------------------------------------------------------*/
67
68typedef struct {
69
70 int n_it;
71 double rhs_norm;
72 double res_norm;
73 double derive;
74 double l2residual;
75
77
78/*----------------------------------------------------------------------------
79 * Boundary condition types
80 *----------------------------------------------------------------------------*/
81
82enum {
83
88
92 CS_ESICF = 7,
96 CS_EPHCF = 10,
98 CS_EQHCF = 11,
102 CS_FREE_INLET = 14,
109
110/*----------------------------------------------------------------------------
111 * flag for computing the drift mass flux:
112 * (for coal classes for instance, only the first
113 * scalar of a class compute the drift flux of the class
114 * and the other scalars use it without recomputing it)
115 *----------------------------------------------------------------------------*/
116
117enum {
118
129
131
132/*----------------------------------------------------------------------------
133 * Space discretisation options descriptor
134 *----------------------------------------------------------------------------*/
135
136typedef struct {
137
138 int imvisf; /* face viscosity field interpolation
139 - 1: harmonic
140 - 0: arithmetic (default) */
141
142 int imrgra; /* type of gradient reconstruction
143 - 0: iterative process
144 - 1: standard least square method
145 - 2: least square method with extended
146 neighborhood
147 - 3: least square method with reduced extended
148 neighborhood
149 - 4: Green-Gauss using least squares face
150 values interpolation */
151
152 int iflxmw; /* method to compute interior mass flux due to ALE
153 mesh velocity
154 - 1: based on cell center mesh velocity
155 - 0: based on nodes displacement */
156
157 int itbrrb; /* accurate treatment of the wall temperature
158 - 1: true
159 - 0: false (default) */
160
162
163/*----------------------------------------------------------------------------
164 * Time scheme descriptor
165 *----------------------------------------------------------------------------*/
166
167typedef struct {
168
169 int time_order; /* global time order of the time stepping */
170
171 int istmpf; /* time order of the mass flux scheme */
172
173 int isno2t; /* time scheme activated for the source
174 terms of the momentum, apart from
175 convection and diffusion */
176
177 int isto2t; /* time scheme activated for the source
178 terms of turbulent equations */
179
180 double thetsn; /* value of \f$theta_S\f$ for Navier-Stokes
181 source terms */
182
183 double thetst; /* value of \f$theta\f$ for turbulence
184 explicit source terms */
185
186 double thetvi; /* value of \f$theta\f$ for total viscosity */
187
188 double thetcp; /* value of \f$theta\f$ for specific heat */
189
190 int iccvfg; /* calculation with a fixed velocity field
191 - 1: true (default)
192 - 0: false */
194
195/*----------------------------------------------------------------------------
196 * Auxiliary checkpoint/restart file parameters
197 *----------------------------------------------------------------------------*/
198
199typedef struct {
200
201 int read_auxiliary; /* Activate reading of auxiliary restart file */
202 int write_auxiliary; /* Activate output of auxiliary restart file */
203
205
206/*============================================================================
207 * Static global variables
208 *============================================================================*/
209
210/* Pointer to space discretisation options structure */
211
213
214/* Pointer to time scheme options structure */
215
217
218/* Pointer to auxiliary checkpoint/restart file parameters */
219
221
222/*============================================================================
223 * Global variables
224 *============================================================================*/
225
228extern cs_tree_node_t *cs_glob_tree;
229
230/*=============================================================================
231 * Public function prototypes
232 *============================================================================*/
233
234/*----------------------------------------------------------------------------*/
245/*----------------------------------------------------------------------------*/
246
247static inline int
249{
250 int iscvr = 0, f_id = 0;
251 int kscavr = cs_field_key_id("first_moment_id");
252 int keysca = cs_field_key_id("scalar_id");
253
254 if (kscavr >= 0) {
255 f_id = cs_field_get_key_int(f, kscavr);
256 if (f_id >= 0)
257 iscvr = cs_field_get_key_int(cs_field_by_id(f_id), keysca);
258 }
259
260 return iscvr;
261}
262
263/*----------------------------------------------------------------------------*/
271/*----------------------------------------------------------------------------*/
272
275
276/*----------------------------------------------------------------------------*/
284/*----------------------------------------------------------------------------*/
285
288
289/*----------------------------------------------------------------------------*/
296/*----------------------------------------------------------------------------*/
297
298void
300
301/*----------------------------------------------------------------------------*/
308/*----------------------------------------------------------------------------*/
309
310void
312
313/*----------------------------------------------------------------------------*/
319/*----------------------------------------------------------------------------*/
320
321void
323
324/*----------------------------------------------------------------------------*/
325/*
326 * \brief Define a user variable.
327 *
328 * Solved variables are always defined on cells.
329 *
330 * \param[in] name name of variable and associated field
331 * \param[in] dim variable dimension
332 */
333/*----------------------------------------------------------------------------*/
334
335void
336cs_parameters_add_variable(const char *name,
337 int dim);
338
339/*----------------------------------------------------------------------------*/
348/*----------------------------------------------------------------------------*/
349
350void
352 const char *variable_name);
353
354/*----------------------------------------------------------------------------*/
362/*----------------------------------------------------------------------------*/
363
364void
365cs_parameters_add_property(const char *name,
366 int dim,
367 int location_id);
368
369/*----------------------------------------------------------------------------*/
378/*----------------------------------------------------------------------------*/
379
380int
382
383/*----------------------------------------------------------------------------*/
392/*----------------------------------------------------------------------------*/
393
394int
396
397/*----------------------------------------------------------------------------*/
401/*----------------------------------------------------------------------------*/
402
403void
405
406/*----------------------------------------------------------------------------*/
410/*----------------------------------------------------------------------------*/
411
412void
414
415/*----------------------------------------------------------------------------*/
419/*----------------------------------------------------------------------------*/
420
421void
423
424/*----------------------------------------------------------------------------*/
425/*
426 * \brief Define a boundary values field for a variable field.
427 *
428 * \param[in, out] f pointer to field structure
429 *
430 * \return pointer to boundary values field, or NULL if not applicable
431 */
432/*----------------------------------------------------------------------------*/
433
436
437/*----------------------------------------------------------------------------*/
438/*
439 * \brief Define a boundary values field for temperature, if applicable.
440 *
441 * When a volume temperature variable field already exists, this amounts
442 * to calling \ref cs_parameters_add_boundary_values for that field.
443 * When such a variable does not exist but we have an Enthalpy variables,
444 * an associated temperature boundary field is returned.
445 *
446 * \return pointer to boundary values field, or NULL if not applicable
447 */
448/*----------------------------------------------------------------------------*/
449
452
453/*----------------------------------------------------------------------------*/
459/*----------------------------------------------------------------------------*/
460
461bool
463
464/*----------------------------------------------------------------------------*/
468/*----------------------------------------------------------------------------*/
469
470void
472
473/*----------------------------------------------------------------------------*/
480/*----------------------------------------------------------------------------*/
481
482void
484
485/*----------------------------------------------------------------------------*/
489/*----------------------------------------------------------------------------*/
490
491void
493
494/*----------------------------------------------------------------------------*/
501/*----------------------------------------------------------------------------*/
502
505
506/*----------------------------------------------------------------------------*/
510/*----------------------------------------------------------------------------*/
511
512void
514
515/*----------------------------------------------------------------------------*/
519/*----------------------------------------------------------------------------*/
520
521void
523
524/*----------------------------------------------------------------------------*/
525
527
528#endif /* __CS_PARAMETERS_H__ */
Definition: cs_defs.h:542
Definition: cs_defs.h:543
Definition: cs_field.cpp:3275
Definition: cs_field.cpp:2465
Definition: cs_field.cpp:2781
void cs_parameters_read_restart_info(void)
Read general restart info.
Definition: cs_parameters.cpp:1184
void cs_parameters_create_added_properties(void)
Create previously added user properties.
Definition: cs_parameters.cpp:1574
cs_equation_param_t cs_var_cal_opt_t
Definition: cs_parameters.h:62
int cs_parameters_n_added_properties(void)
Return the number of defined user properties not added yet.
Definition: cs_parameters.cpp:1334
void cs_parameters_output_complete(void)
Complete general output options definitions.
Definition: cs_parameters.cpp:2748
void cs_parameters_define_auxiliary_fields(void)
Create properties definied directly in C.
Definition: cs_parameters.cpp:1424
void cs_parameters_add_variable(const char *name, int dim)
Definition: cs_parameters.cpp:1207
void cs_parameters_add_property(const char *name, int dim, int location_id)
Define a user property.
Definition: cs_parameters.cpp:1285
cs_field_t * cs_parameters_add_boundary_temperature(void)
Definition: cs_parameters.cpp:1734
void cs_parameters_create_added_variables(void)
Create previously added user variables.
Definition: cs_parameters.cpp:1346
void cs_space_disc_log_setup(void)
Print the space discretization structure to setup.log.
Definition: cs_parameters.cpp:2914
cs_equation_param_t cs_parameters_equation_param_default(void)
Return a local equation param structure, with default options.
Definition: cs_parameters.cpp:2828
void cs_parameters_set_init_state_on(int idx)
Set init state to 1. This is necessary for fortran mapping and should be changed in the future.
Definition: cs_parameters.cpp:1008
void cs_parameters_add_variable_variance(const char *name, const char *variable_name)
Define a user variable which is a variance of another variable.
Definition: cs_parameters.cpp:1248
int cs_parameters_n_added_variables(void)
Return the number of defined user variables not added yet.
Definition: cs_parameters.cpp:1320
void cs_parameters_define_field_keys(void)
Define general field keys.
Definition: cs_parameters.cpp:1026
static int cs_parameters_iscavr(cs_field_t *f)
For a given field, returns the scalar number of the fluctuating field if given field is a variance.
Definition: cs_parameters.h:248
const cs_space_disc_t * cs_glob_space_disc
bool cs_parameters_need_extended_neighborhood(void)
Check if extended neighborhood is needed.
Definition: cs_parameters.cpp:1820
@ CS_DRIFT_SCALAR_ON
Definition: cs_parameters.h:119
@ CS_DRIFT_SCALAR_THERMOPHORESIS
Definition: cs_parameters.h:121
@ CS_DRIFT_SCALAR_IMPOSED_MASS_FLUX
Definition: cs_parameters.h:125
@ CS_DRIFT_SCALAR_NO_MASS_AGGREGATION
Definition: cs_parameters.h:128
@ CS_DRIFT_SCALAR_ADD_DRIFT_FLUX
Definition: cs_parameters.h:120
@ CS_DRIFT_SCALAR_TURBOPHORESIS
Definition: cs_parameters.h:122
@ CS_DRIFT_SCALAR_CENTRIFUGALFORCE
Definition: cs_parameters.h:124
@ CS_DRIFT_SCALAR_ELECTROPHORESIS
Definition: cs_parameters.h:123
@ CS_DRIFT_SCALAR_ZERO_BNDY_FLUX_AT_WALLS
Definition: cs_parameters.h:127
Definition: cs_parameters.h:126
const cs_time_scheme_t * cs_glob_time_scheme
void cs_parameters_global_complete(void)
Complete global parameters.
Definition: cs_parameters.cpp:1872
@ CS_OUTLET
Definition: cs_parameters.h:86
@ CS_COUPLED_FD
Definition: cs_parameters.h:101
@ CS_EPHCF
Definition: cs_parameters.h:96
@ CS_INLET
Definition: cs_parameters.h:85
@ CS_COUPLED
Definition: cs_parameters.h:100
@ CS_ESICF
Definition: cs_parameters.h:92
@ CS_INDEF
Definition: cs_parameters.h:84
@ CS_CONVECTIVE_INLET
Definition: cs_parameters.h:105
@ CS_ROUGHWALL
Definition: cs_parameters.h:90
@ CS_SOPCF
Definition: cs_parameters.h:95
@ CS_SSPCF
Definition: cs_parameters.h:94
@ CS_FREE_INLET
Definition: cs_parameters.h:102
@ CS_EQHCF
Definition: cs_parameters.h:98
@ CS_SMOOTHWALL
Definition: cs_parameters.h:89
@ CS_SYMMETRY
Definition: cs_parameters.h:87
@ CS_FREE_SURFACE
Definition: cs_parameters.h:104
void cs_time_scheme_log_setup(void)
Print the time scheme structure to setup.log.
Definition: cs_parameters.cpp:2840
cs_time_scheme_t * cs_get_glob_time_scheme(void)
Provide access to cs_glob_time_scheme.
Definition: cs_parameters.cpp:993
cs_space_disc_t * cs_get_glob_space_disc(void)
Provide access to cs_glob_space_disc.
Definition: cs_parameters.cpp:977
cs_field_t * cs_parameters_add_boundary_values(cs_field_t *f)
Definition: cs_parameters.cpp:1624
void cs_parameters_eqp_complete(void)
Complete general equation parameter definitions.
Definition: cs_parameters.cpp:2059
cs_restart_auxiliary_t * cs_glob_restart_auxiliary
cs_tree_node_t * cs_glob_tree
Definition: cs_field.h:131
Additional checkpoint/restart files.
Definition: cs_parameters.h:199
int read_auxiliary
Definition: cs_parameters.h:201
int write_auxiliary
Definition: cs_parameters.h:202
Definition: cs_parameters.h:68
int n_it
Definition: cs_parameters.h:70
double rhs_norm
Definition: cs_parameters.h:71
double res_norm
Definition: cs_parameters.h:72
double derive
Definition: cs_parameters.h:73
double l2residual
Definition: cs_parameters.h:74
Space discretisation options descriptor.
Definition: cs_parameters.h:136
int iflxmw
Definition: cs_parameters.h:152
int imrgra
Definition: cs_parameters.h:142
int itbrrb
Definition: cs_parameters.h:157
int imvisf
Definition: cs_parameters.h:138
Time scheme descriptor.
Definition: cs_parameters.h:167
int isno2t
Definition: cs_parameters.h:173
double thetvi
Definition: cs_parameters.h:186
int istmpf
Definition: cs_parameters.h:171
double thetsn
Definition: cs_parameters.h:180
int time_order
Definition: cs_parameters.h:169
int isto2t
Definition: cs_parameters.h:177
int iccvfg
Definition: cs_parameters.h:190
double thetst
Definition: cs_parameters.h:183
double thetcp
Definition: cs_parameters.h:188
