#include "cs_defs.h"#include <assert.h>#include <ctype.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_log.h"#include "cs_map.h"#include "cs_mesh_location.h"#include "cs_parall.h"#include "cs_field.h"
Include dependency graph for cs_field.cpp:Functions | |
| void | cs_field_bc_coeffs_init (cs_field_bc_coeffs_t *bc_coeffs) |
| void | cs_field_bc_coeffs_shallow_copy (const cs_field_bc_coeffs_t *ref, cs_field_bc_coeffs_t *copy) |
| Shallow copy of boundary condition coefficients. More... | |
| void | cs_field_bc_coeffs_free_copy (const cs_field_bc_coeffs_t *ref, cs_field_bc_coeffs_t *copy) |
| Free copy of boundary condition coefficients. More... | |
| int | cs_field_n_fields (void) |
| Return the number of defined fields. More... | |
| cs_field_t * | cs_field_create (const char *name, int type_flag, int location_id, int dim, bool has_previous) |
| Create a field descriptor. More... | |
| cs_field_t * | cs_field_create_by_composite_name (const char *name_prefix, const char *name_suffix, int type_flag, int location_id, int dim, bool has_previous) |
| cs_field_t * | cs_field_find_or_create (const char *name, int type_flag, int location_id, int dim, bool has_previous) |
| Return a field matching a given name and attributes, creating it if necessary. More... | |
| void | cs_field_set_n_time_vals (cs_field_t *f, int n_time_vals) |
| Change the number of time values managed by a field. More... | |
| void | cs_field_allocate_values (cs_field_t *f) |
| Allocate arrays for field values. More... | |
| void | cs_field_map_values (cs_field_t *f, cs_real_t *val, cs_real_t *val_pre) |
| Map existing value arrays to field descriptor. More... | |
| void | cs_field_allocate_bc_coeffs (cs_field_t *f, bool have_flux_bc, bool have_mom_bc, bool have_conv_bc, bool have_exch_bc) |
| Allocate boundary condition coefficients arrays. More... | |
| void | cs_field_init_bc_coeffs (cs_field_t *f) |
| Initialize boundary condition coefficients arrays. More... | |
| void | cs_field_allocate_gradient (cs_field_t *f) |
| Allocate arrays for field gradient. More... | |
| void | cs_field_set_values (cs_field_t *f, cs_real_t c) |
| Set current field values to the given constant. More... | |
| void | cs_field_current_to_previous (cs_field_t *f) |
| Copy current field values to previous values if applicable. More... | |
| void | cs_field_destroy_all (void) |
| Destroy all defined fields. More... | |
| void | cs_field_allocate_or_map_all (void) |
| Allocate arrays for all defined fields based on their location. More... | |
| cs_field_t * | cs_field_by_id (int id) |
| Return a pointer to a field based on its id. More... | |
| cs_field_t * | cs_field_by_name (const char *name) |
| Return a pointer to a field based on its name. More... | |
| cs_field_t * | cs_field_by_name_try (const char *name) |
| Return a pointer to a field based on its name if present. More... | |
| cs_field_t * | cs_field_by_composite_name (const char *name_prefix, const char *name_suffix) |
| Return a pointer to a field based on a composite name. More... | |
| cs_field_t * | cs_field_by_composite_name_try (const char *name_prefix, const char *name_suffix) |
| Return a pointer to a field based on a composite name if present. More... | |
| cs_field_t * | cs_field_by_double_composite_name_try (const char *name_part_1, const char *name_part_2, const char *name_part_3) |
| Return pointer to a field based on a double composite name if present. More... | |
| int | cs_field_id_by_name (const char *name) |
| Return the id of a defined field based on its name. More... | |
| void | cs_field_component_id_by_name (const char *name, int *f_id, int *c_id) |
| Return the id of a defined field and an associated component based on a component name. More... | |
| int | cs_field_key_id (const char *name) |
| Return an id associated with a given key name. More... | |
| int | cs_field_key_id_try (const char *name) |
| Return an id associated with a given key name if present. More... | |
| int | cs_field_define_key_int (const char *name, int default_value, int type_flag) |
| Define a key for an integer value by its name and return an associated id. More... | |
| int | cs_field_define_key_double (const char *name, double default_value, int type_flag) |
| Define a key for an floating point value by its name and return an associated id. More... | |
| int | cs_field_define_key_str (const char *name, const char *default_value, int type_flag) |
| Define a key for a string value by its name and return an associated id. More... | |
| int | cs_field_define_key_struct (const char *name, const void *default_value, cs_field_log_key_struct_t *log_func, cs_field_log_key_struct_t *log_func_default, cs_field_clear_key_struct_t *clear_func, size_t size, int type_flag) |
| Define a key for a structure value by its name and return an associated id. More... | |
| int | cs_field_define_sub_key (const char *name, int parent_id) |
| Define a sub key. More... | |
| void | cs_field_destroy_all_keys (void) |
| Destroy all defined field keys and associated values. More... | |
| int | cs_field_key_flag (int key_id) |
| Get the type flag associated with a given key id. More... | |
| void | cs_field_key_disable_setup_log (int key_id) |
| Disable logging setup values associated with a given key. More... | |
| bool | cs_field_is_key_set (const cs_field_t *f, int key_id) |
| Query if a given key has been set for a field. More... | |
| bool | cs_field_is_key_locked (const cs_field_t *f, int key_id) |
| Query if a given key has been locked for a field. More... | |
| int | cs_field_lock_key (cs_field_t *f, int key_id) |
| Lock a field relative to a given key. More... | |
| int | cs_field_set_key_int (cs_field_t *f, int key_id, int value) |
| Assign a integer value for a given key to a field. More... | |
| int | cs_field_get_key_int (const cs_field_t *f, int key_id) |
| Return a integer value for a given key associated with a field. More... | |
| int | cs_field_set_key_int_bits (cs_field_t *f, int key_id, int mask) |
| Set integer bits matching a mask to 1 for a given key for a field. More... | |
| int | cs_field_clear_key_int_bits (cs_field_t *f, int key_id, int mask) |
| Set integer bits matching a mask to 0 for a given key for a field. More... | |
| int | cs_field_set_key_double (cs_field_t *f, int key_id, double value) |
| Assign a floating point value for a given key to a field. More... | |
| double | cs_field_get_key_double (const cs_field_t *f, int key_id) |
| Return a floating point value for a given key associated with a field. More... | |
| int | cs_field_set_key_str (cs_field_t *f, int key_id, const char *str) |
| Assign a character string for a given key to a field. More... | |
| const char * | cs_field_get_key_str (const cs_field_t *f, int key_id) |
| Return a string for a given key associated with a field. More... | |
| int | cs_field_set_key_struct (cs_field_t *f, int key_id, void *s) |
| Assign a simple structure for a given key to a field. More... | |
| const void * | cs_field_get_key_struct (const cs_field_t *f, const int key_id, void *s) |
| Return a structure for a given key associated with a field. More... | |
| void * | cs_field_get_key_struct_ptr (cs_field_t *f, int key_id) |
| Return a pointer to a simple structure for a given key to a field. More... | |
| const void * | cs_field_get_key_struct_const_ptr (const cs_field_t *f, int key_id) |
| Return a read-only pointer to a simple structure for a given key to a field. More... | |
| void | cs_field_log_defs (void) |
| Print info relative to all field definitions to log file. More... | |
| void | cs_field_log_info (const cs_field_t *f, int log_keywords) |
| Print info relative to a given field to log file. More... | |
| void | cs_field_log_fields (int log_keywords) |
| Print info relative to all defined fields to log file. More... | |
| void | cs_field_log_key_defs (void) |
| Print info relative to all key definitions to log file. More... | |
| void | cs_field_log_key_vals (int key_id, bool log_defaults) |
| Print info relative to a given field key to log file. More... | |
| void | cs_field_log_all_key_vals (bool log_defaults) |
| Print info relative to all given field keys to log file. More... | |
| void | cs_field_define_keys_base (void) |
| Define base keys. More... | |
| const char * | cs_field_get_label (const cs_field_t *f) |
| Return a label associated with a field. More... | |
| void cs_field_allocate_bc_coeffs | ( | cs_field_t * | f, |
| bool | have_flux_bc, | ||
| bool | have_mom_bc, | ||
| bool | have_conv_bc, | ||
| bool | have_exch_bc | ||
For fields on location CS_MESH_LOCATION_CELLS, boundary conditions are located on CS_MESH_LOCATION_BOUNDARY_FACES.
Boundary condition coefficients are not currently supported for other locations (though support could be added by mapping a boundary->location indirection array in the cs_mesh_location_t structure).
For multidimensional fields with coupled components, implicit b and bf coefficient arrays are arrays of block matrices, not vectors, so the number of entries for each boundary face is dim*dim instead of dim.
| [in] | have_flux_bc | if true, flux bc coefficients (af and bf) are added |
| [in] | have_mom_bc | if true, div BC coefficients (ad and bd) are added |
| [in] | have_conv_bc | if true, convection BC coefficients (ac and bc) are added |
| [in] | have_exch_bc | if true, exchange boundary coefficients (hint and hext) are added |
| void cs_field_allocate_gradient | ( | cs_field_t * | f | ) |
| void cs_field_allocate_or_map_all | ( | void | ) |
Location sized must thus be known.
Fields that do not own their data should all have been mapped at this stage, and are checked.
| void cs_field_allocate_values | ( | cs_field_t * | f | ) |
| void cs_field_bc_coeffs_free_copy | ( | const cs_field_bc_coeffs_t * | ref, |
| cs_field_bc_coeffs_t * | copy | ||
| [in] | ref | reference bc coefficients |
| [in,out] | copy | shallow copy of bc coefficients |
| void cs_field_bc_coeffs_init | ( | cs_field_bc_coeffs_t * | bc_coeffs | ) |
| void cs_field_bc_coeffs_shallow_copy | ( | const cs_field_bc_coeffs_t * | ref, |
| [in] | ref | source bc coefficients |
| cs_field_t * cs_field_by_composite_name | ( | const char * | name_prefix, |
| const char * | name_suffix | ||
The name is expected to be of the form <name_prefix>_<name_suffix>.
| [in] | name_prefix | first part of field name |
| [in] | name_suffix | second part of field name |
| cs_field_t * cs_field_by_composite_name_try | ( | const char * | name_prefix, |
The name is expected to be of the form <name_prefix>_<name_suffix>. If no field of the given name is defined, a null pointer is returned.
| cs_field_t * cs_field_by_double_composite_name_try | ( | const char * | name_part_1, |
| const char * | name_part_2, | ||
| const char * | name_part_3 | ||
If no field of the given name is defined, nullptr is returned.
Contrary to cs_field_by_composite_name_try, this function does not automatically add '_' characters between component names. This allows adding different separators, such as ':'.
| [in] | name_part_1 | first part of field name |
| [in] | name_part_2 | second part of field name |
| [in] | name_part_3 | second part of field name |
| cs_field_t * cs_field_by_id | ( | int | id | ) |
This function requires that a field of the given id is defined.
| [in] | id | field id |
| cs_field_t * cs_field_by_name | ( | const char * | name | ) |
This function requires that a field of the given name is defined.
| [in] | name | field name |
| cs_field_t * cs_field_by_name_try | ( | const char * | name | ) |
| int cs_field_clear_key_int_bits | ( | cs_field_t * | f, |
| int | key_id, | ||
| int | mask | ||
If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned. If the field category is not compatible with the key (as defined by its type flag), CS_FIELD_INVALID_CATEGORY is returned. If the data type does not match, CS_FIELD_INVALID_TYPE is returned. If the key value has been locked, CS_FIELD_LOCKED is returned.
| [in] | f | pointer to field structure |
| [in] | key_id | id of associated key |
| [in] | mask | mask associated with key |
| void cs_field_component_id_by_name | ( | const char * | name, |
| int * | f_id, | ||
| int * | c_id | ||
If no field with the given name exists, -1 is returned.
| [in] | name | field or field+component name |
| [out] | f_id | field id, or -1 if no match was found |
| [out] | c_id | component id, or -1 for all components |
| cs_field_t * cs_field_create | ( | const char * | name, |
| int | type_flag, | ||
| int | location_id, | ||
| int | dim, | ||
| bool | has_previous | ||
| [in] | type_flag | mask of field property and category values |
| [in] | location_id | id of associated location |
| [in] | dim | field dimension (number of components) |
| [in] | has_previous | maintain values at the previous time step ? |
| cs_field_t * cs_field_create_by_composite_name | ( | const char * | name_prefix, |
| const char * | name_suffix, | ||
| int | dim, | ||
| void cs_field_current_to_previous | ( | cs_field_t * | f | ) |
For fields with only one time value, or values not allocated yet, this is a no-op.
| int cs_field_define_key_double | ( | const char * | name, |
| double | default_value, | ||
| int | type_flag | ||
If the key has already been defined, its previous default value is replaced by the current value, and its id is returned.
| [in] | name | key name |
| [in] | default_value | default value associated with key |
| [in] | type_flag | mask associated with field types with which the key may be associated, or 0 |
| int cs_field_define_key_int | ( | const char * | name, |
| int | default_value, | ||
| int cs_field_define_key_str | ( | const char * | name, |
| const char * | default_value, | ||
| int cs_field_define_key_struct | ( | const char * | name, |
| const void * | default_value, | ||
| cs_field_log_key_struct_t * | log_func, | ||
| cs_field_log_key_struct_t * | log_func_default, | ||
| cs_field_clear_key_struct_t * | clear_func, | ||
| size_t | size, | ||
| [in] | default_value | pointer to default value associated with key |
| [in] | log_func | pointer to logging function |
| [in] | log_func_default | pointer to default logging function |
| [in] | clear_func | pointer to substructures free function |
| [in] | size | sizeof structure |
| void cs_field_define_keys_base | ( | void | ) |
Define base keys.
Keys defined by this function are: "label" (string) "log" (integer) "post_vis" (integer) "coupled" (integer, restricted to CS_FIELD_VARIABLE) "moment_id" (integer, restricted to CS_FIELD_ACCUMULATOR | CS_FIELD_POSTPROCESS);
| int cs_field_define_sub_key | ( | const char * | name, |
| int | parent_id | ||
Define a sub key.
The sub key is the same type as the parent key.
For a given field, when querying a sub key's value and that value has not been set, the query will return the value of the parent key.
| [in] | parent_id | parent key id |
| void cs_field_destroy_all | ( | void | ) |
| void cs_field_destroy_all_keys | ( | void | ) |
| cs_field_t * cs_field_find_or_create | ( | const char * | name, |
| int | dim, | ||
If a field with the same name but different attributes is present, this is considered an error.
The default number of time values associated with a field created through this function is 1. To modify it, use cs_field_set_n_time_vals.
| double cs_field_get_key_double | ( | const cs_field_t * | f, |
| int | key_id | ||
If the key id is not valid, or the value type or field category is not compatible, a fatal error is provoked.
| int cs_field_get_key_int | ( | const cs_field_t * | f, |
| int | key_id | ||
| const char * cs_field_get_key_str | ( | const cs_field_t * | f, |
| int | key_id | ||
| const void * cs_field_get_key_struct | ( | const cs_field_t * | f, |
| const int | key_id, | ||
| void * | s | ||
| [out] | s | structure associated with key |
| const void * cs_field_get_key_struct_const_ptr | ( | const cs_field_t * | f, |
| int | key_id | ||
If the key id is not valid, the value type or field category is not compatible, a fatal error is provoked.
| void * cs_field_get_key_struct_ptr | ( | cs_field_t * | f, |
| int | key_id | ||
If the key id is not valid, the value type or field category is not compatible, or the structure has been locked, a fatal error is provoked.
Note that using this function marks the field's value for this structure as set, and if no values have been set yet, the structure is set to default values.
| const char * cs_field_get_label | ( | const cs_field_t * | f | ) |
If the "label" key has been set for this field, its associated string is returned. Otherwise, the field's name is returned.
| int cs_field_id_by_name | ( | const char * | name | ) |
| void cs_field_init_bc_coeffs | ( | cs_field_t * | f | ) |
| bool cs_field_is_key_locked | ( | const cs_field_t * | f, |
| int | key_id | ||
If the key id is not valid, or the field category is not compatible, a fatal error is provoked.
| bool cs_field_is_key_set | ( | const cs_field_t * | f, |
| int | key_id | ||
| void cs_field_key_disable_setup_log | ( | int | key_id | ) |
This is useful when a key is used not for setup purposes, but to track values associated with a field, such as convergence or performance data.
| int cs_field_key_flag | ( | int | key_id | ) |
If the key has not been defined previously, -1 is returned.
| int cs_field_key_id | ( | const char * | name | ) |
The key must have been defined previously.
| int cs_field_key_id_try | ( | const char * | name | ) |
| int cs_field_lock_key | ( | cs_field_t * | f, |
| int | key_id | ||
| void cs_field_log_all_key_vals | ( | bool | log_defaults | ) |
| [in] | log_defaults | if true, log default field values in addition to defined field values |
| void cs_field_log_defs | ( | void | ) |
| void cs_field_log_fields | ( | int | log_keywords | ) |
| [in] | log_keywords | log level for keywords (0: do not log, 1: log non-default values, 2: log all) |
| void cs_field_log_info | ( | const cs_field_t * | f, |
| int | log_keywords | ||
| void cs_field_log_key_defs | ( | void | ) |
| void cs_field_log_key_vals | ( | int | key_id, |
| bool | log_defaults | ||
| void cs_field_map_values | ( | cs_field_t * | f, |
| cs_real_t * | val, | ||
| cs_real_t * | val_pre | ||
| [in] | val | pointer to array of values |
| [in] | val_pre | pointer to array of previous values, or nullptr |
| int cs_field_n_fields | ( | void | ) |
| int cs_field_set_key_double | ( | cs_field_t * | f, |
| int | key_id, | ||
| double | value | ||
| [in] | value | value associated with key |
| int cs_field_set_key_int | ( | cs_field_t * | f, |
| int | key_id, | ||
| int | value | ||
| int cs_field_set_key_int_bits | ( | cs_field_t * | f, |
| int | key_id, | ||
| int | mask | ||
| int cs_field_set_key_str | ( | cs_field_t * | f, |
| int | key_id, | ||
| const char * | str | ||
| [in] | str | string associated with key |
| int cs_field_set_key_struct | ( | cs_field_t * | f, |
| int | key_id, | ||
| void * | s | ||
| [in] | s | structure associated with key |
| void cs_field_set_n_time_vals | ( | cs_field_t * | f, |
| int | n_time_vals | ||
The minimum will never be below 1, as the current time is always handled.
| [in] | n_time_vals | number of time values to maintain |
| void cs_field_set_values | ( | cs_field_t * | f, |
| cs_real_t | c | ||
| [in] | c | assigned value |
