8.3
bft_printf.h
1#ifndef __BFT_PRINTF_H__
2#define __BFT_PRINTF_H__
5 * Base user-definable printf() wrapper or replacement
30#include "cs_defs.h"
32/*----------------------------------------------------------------------------*/
35 * Standard C library headers
38#include <stdarg.h>
40/*----------------------------------------------------------------------------
41 * Local headers
42 *----------------------------------------------------------------------------*/
44/*-----------------------------------------------------------------------------*/
45
49 * Public types
51
52/* Function pointers for printf() and fflush(stdout) type functions */
53
54typedef int (bft_printf_proxy_t) (const char *const format,
55 va_list arg_ptr);
56
57typedef int (bft_printf_flush_proxy_t) (void);
58
59/*============================================================================
60 * Public function prototypes
61 *============================================================================*/
62
63/*
64 * Replacement for printf() with modifiable behavior.
65 *
66 * This function calls vprintf() by default, or a function with similar
67 * arguments indicated by bft_printf_proxy_set().
68 *
69 * parameters:
70 * format: <-- format string, as printf() and family.
71 * ... : <-- variable arguments based on format string.
72 *
73 * returns:
74 * number of characters printed, not counting the trailing '\0' used
75 * to end output strings
76 */
77
78#if defined(__GNUC__)
79
80int
81bft_printf(const char *const format,
82 ...)
83 __attribute__((format(printf, 1, 2)));
84
85#else
86
87int
88bft_printf(const char *const format,
89 ...);
90
91#endif
92
93/*
94 * Flush for output of bft_printf() with modifiable behavior.
95 *
96 * This function calls fflush(stdout) if bft_printf()'s default behavior is
97 * used. If bft_printf's behavior is modified with bft_printf_proxy_set(),
98 * bft_printf_flush()'s behavior may have to be also adjusted with
99 * bft_printf_flush_proxy_set().
100 *
101 * returns:
102 * using the default behavior, the return value is that of
103 * fflush(stdout): O upon successful completion, EOF otherwise
104 * (with errno set to indicate the error).
105 */
106
107int
108bft_printf_flush(void);
109
110/*
111 * Returns function associated with the bft_printf() function.
112 *
113 * returns:
114 * pointer to the vprintf() or replacement function.
115 */
116
119
120/*
121 * Associates a vprintf() type function with the bft_printf() function.
122 *
123 * parameters:
124 * fct: <-- pointer to a vprintf() type function.
125 */
126
127void
129
130/*
131 * Returns function associated with bft_printf_flush().
132 *
133 * returns:
134 * pointer to the bft_printf_flush() proxy.
135 */
136
139
140/*
141 * Associates a proxy function with bft_printf_flush().
142 *
143 * warning:
144 * bft_printf() is called by the default bft_error() error handler
145 * (so as to ensure that the error text appears at the end of the
146 * program output), so a bft_print_flush replacement must not itself
147 * call (directly or indirectly) bft_error() if the default error
148 * handler is used.
149 *
150 * parameter:
151 * fct <-- pointer to a function similar to {return fflush(stdout)}.
152 */
153
154void
156
157/*----------------------------------------------------------------------------*/
158
160
161#endif /* __BFT_PRINTF_H__ */
void bft_printf_flush_proxy_set(bft_printf_flush_proxy_t *const fct)
Definition: bft_printf.cpp:224
bft_printf_proxy_t * bft_printf_proxy_get(void)
Definition: bft_printf.cpp:181
void bft_printf_proxy_set(bft_printf_proxy_t *const fct)
Definition: bft_printf.cpp:193
Definition: bft_printf.cpp:140
int() bft_printf_flush_proxy_t(void)
Function pointer for fflush(stdout) type functions.
Definition: bft_printf.h:57
int bft_printf_flush(void)
Definition: bft_printf.cpp:169
bft_printf_flush_proxy_t * bft_printf_flush_proxy_get(void)
Definition: bft_printf.cpp:205
int() bft_printf_proxy_t(const char *const format, va_list arg_ptr)
Function pointer for printf() type functions.
Definition: bft_printf.h:54
Definition: cs_defs.h:542
Definition: cs_defs.h:543
