Function objects management. More...
#include "cs_defs.h"#include <assert.h>#include <stdarg.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_error.h"#include "bft_mem.h"#include "cs_base.h"#include "cs_log.h"#include "cs_mesh.h"#include "cs_mesh_location.h"#include "cs_mesh_quantities.h"#include "cs_time_step.h"#include "cs_function.h"
Include dependency graph for cs_function.cpp:Functions | |
| cs_function_t * | cs_function_define_by_func (const char *name, int location_id, int dim, bool is_intensive, cs_datatype_t datatype, cs_eval_at_location_t *data_func, void *data_input) |
| Define a function whose data values will be computed using the provided evaluation function. More... | |
| cs_function_t * | cs_function_define_by_analytic_func (const char *name, int location_id, int dim, bool is_intensive, cs_analytic_func_t *data_func, void *data_input) |
| Define a function whose data values will be computed using the provided "degree of freedom" type evaluation function. More... | |
| cs_function_t * | cs_function_define_by_dof_func (const char *name, int location_id, int dim, bool is_intensive, cs_dof_func_t *data_func, void *data_input) |
| void | cs_function_destroy_all (void) |
| Destroy all functions management metadata. More... | |
| int | cs_function_n_functions (void) |
| Return the number of defined functions. More... | |
| cs_function_t * | cs_function_by_id (int id) |
| Return a pointer to a function object based on its id. More... | |
| cs_function_t * | cs_function_by_name (const char *name) |
| Return a pointer to a function object based on its name. More... | |
| cs_function_t * | cs_function_by_name_try (const char *name) |
| Return a pointer to a function object based on its name if present. More... | |
| void | cs_function_set_label (cs_function_t *f, const char *label) |
| Assig a label to a function object. More... | |
| void | cs_function_log_defs (void) |
| Log function definition setup information. More... | |
| void | cs_function_log_all_settings (void) |
| Print info relative to all given function object settings to log file. More... | |
| void | cs_function_evaluate (const cs_function_t *f, const cs_time_step_t *ts, int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *vals) |
| Evaluate function values. More... | |
Function objects can have various roles. Their main use is to unify handling of expression evaluations for mesh-location based data that can be re-evaluated on the fly (rather than requiring persistent storage such as field data), mostly for logging and post-processing.
| cs_function_t * cs_function_by_id | ( | int | id | ) |
This function requires that a function of the given id is defined.
| [in] | id | function id |
| cs_function_t * cs_function_by_name | ( | const char * | name | ) |
This function requires that a function of the given name is defined.
| [in] | name | function name |
| cs_function_t * cs_function_by_name_try | ( | const char * | name | ) |
If no function of the given name is defined, nullptr is returned.
| cs_function_t * cs_function_define_by_analytic_func | ( | const char * | name, |
| int | location_id, | ||
| int | dim, | ||
| bool | is_intensive, | ||
| cs_analytic_func_t * | data_func, | ||
| void * | data_input | ||
The provided function and optional associated input is of the same form as and may be shared with some boundary condition or property definitions.
| [in] | name | name of associated function |
| [in] | dim | dimension associated with element data |
| [in] | is_intensive | is the function intensive? |
| [in] | data_func | function used to define data values |
| [in] | data_input | pointer to optional (untyped) value or structure to be used by data_func |
| cs_function_t * cs_function_define_by_dof_func | ( | const char * | name, |
| int | dim, | ||
| cs_dof_func_t * | data_func, | ||
| cs_function_t * cs_function_define_by_func | ( | const char * | name, |
| int | dim, | ||
| cs_eval_at_location_t * | data_func, | ||
If of dimension > 1, the evaluated values are always interleaved.
| [in] | datatype | associated data values type |
| void cs_function_destroy_all | ( | void | ) |
| void cs_function_evaluate | ( | const cs_function_t * | f, |
| cs_lnum_t | n_elts, | ||
| void * | vals | ||
If the matching values are multidimensional, they must be interleaved. The output values are assumed to use a dense storage (i.e. of size n_elts *
for the associated data type, in the same order as elt_ids if present.)
| [in] | f | pointer to associated function handle |
| [in] | location_id | base associated mesh location id |
| [in] | n_elts | number of associated elements |
| [in] | elt_ids | ids of associated elements, or nullptr if no filtering is required |
| [in,out] | vals | pointer to output values (size: n_elts*dimension) |
| void cs_function_log_all_settings | ( | void | ) |
| void cs_function_log_defs | ( | void | ) |
| int cs_function_n_functions | ( | void | ) |
| void cs_function_set_label | ( | cs_function_t * | f, |
| const char * | label | ||
| [in,out] | f | pointer to associated function handle |
| [in] | label | associated label |
