#include "cs_defs.h"#include <assert.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "cs_log.h"#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_array.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_math.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_physical_constants.h"#include "cs_physical_model.h"#include "cs_post.h"#include "cs_thermal_model.h"#include "cs_velocity_pressure.h"#include "cs_gas_mix.h"
Include dependency graph for cs_gas_mix.cpp:Functions | |
| int | cs_gas_mix_get_field_key (void) |
| Get the field key for gas mix properties. More... | |
| void | cs_gas_mix_add_species (int f_id) |
| Add a species field to the gas mix (set of fields). More... | |
| void | cs_gas_mix_add_species_with_properties (int f_id, cs_real_t mol_mass, cs_real_t cp, cs_real_t vol_diff, cs_real_t mu_a, cs_real_t mu_b, cs_real_t lambda_a, cs_real_t lambda_b, cs_real_t mu_ref, cs_real_t lambda_ref, cs_real_t tref_mu, cs_real_t tref_lambda, cs_real_t s_mu, cs_real_t s_lambda) |
| void | cs_gas_mix_add_property_fields (void) |
| Add property fields specific to a gas mix. More... | |
| void | cs_gas_mix_physical_properties (void) |
| Fills physical properties which are variable in time for the gas mixtures modelling with or without steam inside the fluid domain. In presence of steam, this one is deduced from the noncondensable gases transported as scalars (by means of the mass fraction of each species). More... | |
| void | cs_gas_mix_finalize (void) |
| Free array mapping gas mix species ids to field ids. More... | |
| void | cs_gas_mix_initialization (void) |
| Initialization of calculation variables for gas mixture modelling in presence of the steam gas or another gas used as variable deduced and not solved. More... | |
| static cs_gas_mix_species_prop_t | _gas_mix_species_prop |
| const cs_gas_mix_t * | cs_glob_gas_mix = &_gas_mix |
Base gas mix data.
| void cs_gas_mix_add_property_fields | ( | void | ) |
| void cs_gas_mix_add_species | ( | int | f_id | ) |
| [in] | f_id | field id of an already created scalar model field |
| void cs_gas_mix_add_species_with_properties | ( | int | f_id, |
| cs_real_t | mol_mass, | ||
| cs_real_t | cp, | ||
| cs_real_t | vol_diff, | ||
| cs_real_t | mu_a, | ||
| cs_real_t | mu_b, | ||
| cs_real_t | lambda_a, | ||
| cs_real_t | lambda_b, | ||
| cs_real_t | mu_ref, | ||
| cs_real_t | lambda_ref, | ||
| cs_real_t | tref_mu, | ||
| cs_real_t | tref_lambda, | ||
| cs_real_t | s_mu, | ||
| cs_real_t | s_lambda | ||
| [in] | f_id | id of field representing species mixture fraction. |
| [in] | mol_mass | molar mass |
| [in] | cp | specific heat |
| [in] | col_diff | volume diffusion |
| [in] | mu_a | dynamic viscosity a |
| [in] | mu_b | dynamic viscosity b |
| [in] | lambda_a | thermal conductivity a |
| [in] | lambda_b | thermal conductivity b |
| [in] | mu_ref | reference viscosity (Sutherland) |
| [in] | lambda_ref | reference conductivity (Sutherland) |
| [in] | tref_mu | reference temperature for viscosity |
| [in] | tref_lambda | reference temperature for conductivity |
| [in] | s_mu | Sutherland temperature for viscosity |
| [in] | s_lambda | Sutherland temperature for conductivity |
| void cs_gas_mix_finalize | ( | void | ) |
| int cs_gas_mix_get_field_key | ( | void | ) |
| void cs_gas_mix_initialization | ( | void | ) |
| void cs_gas_mix_physical_properties | ( | void | ) |
static |
| const cs_gas_mix_t* cs_glob_gas_mix = &_gas_mix |
