| Enumerator |
| dt | local time step
| p | pressure
| pgr | granular pressure
| pfr | frictional pressure
| vel | velocity
| k | turbulent kinetic energy
| eps | turbulent dissipation
| rij | Reynolds stress tensor
| phi | for model
| f_bar | for model
| alp_bl | for or EBRSM model
| omg | for SST model
| nusa | for Spalart- Allmaras
| hybrid_blend | Blending factor for DDES
| mesh_u | mesh velocity
| void_f | void fraction
| vol_f | volume fraction
| h | enthalpy
| t | temperature
| t_b | temperature (at boundary faces)
| e_tot | total energy
| h_tot | total enthalpy
| rho | density (at cells)
| rho_b | density (at boundary faces)
| cp | isobaric specific heat
| cv | isochoric specific heat
| mu | molecular viscosity
| mu_t | turbulent dynamic viscosity
| lambda | Thermal conductivity
| th_diff | Dynamic thermal diffusivity
| poro | porosity
| if_poro | internal faces porosity
| t_poro | tensorial porosity
| t_kelvin | temperature, in Kelvin
| vism | mesh viscosity
| volume_f | homogeneous model volume fraction
| mass_f | homogeneous model mass fraction
| energy_f | homogeneous model energy fraction
| pot_t | potential temperature
| ntdrp | total number of droplets
| chemistry | chemistry species (indexed)
| fm | mixture fraction
| fp2m | mixture fraction variance
| fsm | soot mass fraction
| npm | soot precursor number
| ygfm | fresh gas fraction
| yfm | mass fraction
| yfp2m | mass fraction variance
| coyfp | mass fraction covariance
| np | particles per kg for coal class
| xch | reactive coal mass fraction for coal class
| xck | coke mass fraction for coal class
| xwt | water mass fraction for coal class
| h2 | mass enthalpy for coal class (permeatic case)
| f1m | mean value light volatiles for coal class
| f2m | mean value heavy volatiles for coal class
| f4m | oxydant 2 mass fraction
| f5m | oxydant 3 mass fraction
| f6m | water from coal drying mass fraction
| f7m | carbon from coal oxidyzed by O2 mass fraction
| f8m | carbon from coal gasified by CO2 mass fraction
| f9m | carbon from coal gasified by H2O mass fraction
| fvp2m | f1f2 variance
| yco2 | CO2 fraction
| yhcn | HCN fraction
| yno | NO fraction
| ynh3 | NH3 enthalpy
| hox | Ox enthalpy
| potr | Electric potential, real part
| poti | Electric potential, imaginary part
| potva | Vector potential
| ycoel | Constituent mass fraction
| joulp | Joule power
| radsc | radiation source
| elech | electric charge
| curre | current real
| curim | current imaginary
| laplf | laplace forces
| magfl | magnetic field
| elefl | electric field
| rad_energy | Radiative energy
| rad_q | Radiative flux
| radiance | (spectral) radiance field
| rad_est | Radiative flux explicit source term
| rad_ist | Radiative flux implicit source term
| rad_abs | Radiative absorption
| rad_emi | Radiative emission
| rad_cak | Radiative absorption coefficient
| qinci | Radiative incident radiative flux density
| qinsp | Spectral radiative incident flux
| xlam | Wall thermal conductivity
| epa | Wall thickness
| emissivity | Wall emissivity
| fnet | Boundary radiative flux
| fconv | Boundary radiative convective flux
| hconv | radiative exchange coefficient
| fup | Spectral upward radiative flux
| fdown | Spectral downward radiative flux
| rad_ck_up | Spectral upward Radiative absorption coefficient
| rad_ck_down | Spectral downward Radiative absorption coefficient
| mol_mass | gas mix molar max
| head | hydraulic head
| humid | Humidity
| ym_w | Mass fraction of dry air in humid air
| t_l_pack | Injected liquid water temperature
| yh_l_pack | Injected liquid water enthalpy
| y_l_pack | Mass of liquid per unit volume of cell
| thermal_diff_h | Humid air thermal diffusivity
| thermal_diff_l | Injected liquid water thermal diffusivity
| pack_zone_id | Id of the packing zone
| yf_ncond | non-condensable mass fraction
| qp | Turbulent Kinetic Energy q2
| qfp | Covariance q12
| qfpxx | XX component of qfp
| qfpxy | XY component of qfp
| qfpxz | XZ component of qfp
| qfpyx | YX component of qfp
| qfpyy | YY component of qfp
| qfpyz | YZ component of qfp
| qfpzx | ZX component of qfp
| qfpzy | ZY component of qfp
| qfpzz | ZZ component of qfp
| gamma | Interfacial mass transfer
| ia | Interfacial area
| x2 | x2 for droplets
| d32 | Sauter diameter
| drag | Phases drag
| ad_mass | Added mass
| wlubr | Wall lubrication
| th_diff_t | Turbulent thermal diffusivity
| drho_dp | drho over dp
| drho_dh | drho over dh
| tau12_t | turbulent tau12
| lift | Lift coefficient
| disp_t | Turbulent dispersion
| surf_tens | Surface tension
| sl_corr | Free surface correction weight for GLIM
| fi | field_a vol_f weight for GLIM
| fj | field_b vol_f weight for GLIM
| drift_vel | Particles drift velocity
| yplus | Wall distance: y+
| vel_mean | Mean velocity (for dispersed phases)
| vel_rel | Relative velocity (for dispersed phases)
| dt_dp | dtemp/dpress derivative
| kindiff | Particles kinetic diffusivity
| coldiff | Particles collisional diffusivity
| elast | Particles restitution coefficient
| c_alpha | Weighting coefficient for GEMMA model
| add_var | User added variables
| user | |
| CS_FIELD_N_POINTERS | |
