8.3
cs_post.h
1#ifndef __CS_POST_H__
2#define __CS_POST_H__
5 * Post-processing management
30#include "cs_defs.h"
33 * Standard C library headers
37 * Local headers
38 *----------------------------------------------------------------------------*/
40#include "fvm_nodal.h"
41#include "fvm_writer.h"
43#include "cs_base.h"
44#include "cs_function.h"
45#include "cs_interpolate.h"
46#include "cs_probe.h"
47#include "cs_time_step.h"
48#include "cs_time_control.h"
49
50/*----------------------------------------------------------------------------*/
51
53
54/*============================================================================
55 * Macro definitions
57
58/* Output type masks */
59
60#define CS_POST_ON_LOCATION (1 << 0) /* postprocess variables
61 on their base location
62 (volume for variables) */
63#define CS_POST_BOUNDARY_NR (1 << 1) /* postprocess boundary
64 without reconstruction */
65
66#define CS_POST_MONITOR (1 << 2) /* monitor variables */
68/* Default writer ids and filters */
70#define CS_POST_WRITER_ALL_ASSOCIATED 0
72#define CS_POST_WRITER_DEFAULT -1
73#define CS_POST_WRITER_ERRORS -2
74#define CS_POST_WRITER_PARTICLES -3
75#define CS_POST_WRITER_TRAJECTORIES -4
76#define CS_POST_WRITER_PROBES -5
77#define CS_POST_WRITER_PROFILES -6
78#define CS_POST_WRITER_HISTOGRAMS -7
80/* Default mesh ids */
82#define CS_POST_MESH_VOLUME -1
83#define CS_POST_MESH_BOUNDARY -2
84#define CS_POST_MESH_PARTICLES -3
85#define CS_POST_MESH_TRAJECTORIES -4
86#define CS_POST_MESH_PROBES -5
88/* Additional categories (no associated default mesh) */
89
90#define CS_POST_MESH_SURFACE -1001 /* surface (boundary and/or
91 interior) mesh */
92
93/*============================================================================
94 * Local type definitions
95 *============================================================================*/
96
97/* Datatype enumeration (deprecated; cs_datatype_t preferred) */
101#define CS_POST_TYPE_int CS_INT_TYPE
102#define CS_POST_TYPE_cs_real_t CS_REAL_TYPE
103#define CS_POST_TYPE_float CS_FLOAT
104#define CS_POST_TYPE_double CS_DOUBLE
105
106/*----------------------------------------------------------------------------
107 * Function pointer to elements selection definition.
108 *
109 * Each function of this sort may be used to select a given type of element,
110 * usually cells, interior faces, boundary faces, or particles.
111 *
112 * If non-empty and not containing all elements, a list of elements of the
113 * main mesh should be allocated (using BFT_MALLOC) and defined by this
114 * function when called. This list's lifecycle is then managed by the
115 * postprocessing subsystem.
116 *
117 * Note: if the input pointer is non-null, it must point to valid data
118 * when the selection function is called, so either:
119 * - that value or structure should not be temporary (i.e. local);
120 * - post-processing output must be ensured using cs_post_write_meshes()
121 * with a fixed-mesh writer before the data pointed to goes out of scope;
122 *
123 * parameters:
124 * input <-> pointer to optional (untyped) value or structure.
125 * n_elts --> number of selected elements.
126 * elt_list --> list of selected elements (0 to n-1 numbering).
127 *----------------------------------------------------------------------------*/
128
129typedef void
130(cs_post_elt_select_t) (void *input,
131 cs_lnum_t *n_elts,
132 cs_lnum_t **elt_list);
133
134/*----------------------------------------------------------------------------
135 * Function pointer associated with a specific post-processing output.
136 *
137 * Such functions are registered using the cs_post_add_time_dep_vars(),
138 * and all registered functions are automatically called by
139 * cs_post_write_vars().
140 *
141 * Note: if the input pointer is non-null, it must point to valid data
142 * when the output function is called, so either:
143 * - that value or structure should not be temporary (i.e. local);
144 * - post-processing output must be ensured using cs_post_write_var()
145 * or similar before the data pointed to goes out of scope.
146 *
147 * parameters:
148 * input <-> pointer to optional (untyped) value or structure.
149 * ts <-- time step status structure, or NULL
150 *----------------------------------------------------------------------------*/
151
152typedef void
153(cs_post_time_dep_output_t) (void *input,
154 const cs_time_step_t *ts);
155
156/*----------------------------------------------------------------------------
157 * Function pointer associated with a specific post-processing output
158 * on multiple meshes.
159 *
160 * Such functions are registered using the cs_post_add_time_mesh_dep_vars(),
161 * and all registered functions are automatically called by
162 * cs_post_write_vars().
163 *
164 * Note: if the input pointer is non-null, it must point to valid data
165 * when the output function is called, so either:
166 * - that value or structure should not be temporary (i.e. local);
167 * - post-processing output must be ensured using cs_post_write_var()
168 * or similar before the data pointed to goes out of scope.
169 *
170 * parameters:
171 * input <-> pointer to optional (untyped) value or structure.
172 * mesh_id <-- id of the output mesh for the current call
173 * cat_id <-- category id of the output mesh for the current call
174 * ent_flag <-- indicate global presence of cells (ent_flag[0]), interior
175 * faces (ent_flag[1]), boundary faces (ent_flag[2]),
176 * particles (ent_flag[3]) or probes (ent_flag[4])
177 * n_cells <-- local number of cells of post_mesh
178 * n_i_faces <-- local number of interior faces of post_mesh
179 * n_b_faces <-- local number of boundary faces of post_mesh
180 * cell_ids <-- list of cells (0 to n-1) of post-processing mesh
181 * i_face_ids <-- list of interior faces (0 to n-1) of post-processing mesh
182 * b_face_ids <-- list of boundary faces (0 to n-1) of post-processing mesh
183 * ts <-- time step status structure, or NULL
184 *----------------------------------------------------------------------------*/
185
186typedef void
187(cs_post_time_mesh_dep_output_t) (void *input,
188 int mesh_id,
189 int cat_id,
190 int ent_flag[5],
191 cs_lnum_t n_cells,
192 cs_lnum_t n_i_faces,
193 cs_lnum_t n_b_faces,
194 const cs_lnum_t cell_ids[],
195 const cs_lnum_t i_face_ids[],
196 const cs_lnum_t b_face_ids[],
197 const cs_time_step_t *ts);
198
199/*=============================================================================
200 * Global variables
201 *============================================================================*/
202
203/*============================================================================
204 * Public function prototypes
205 *============================================================================*/
206
207/*----------------------------------------------------------------------------*/
208/*
209 * \brief Define a writer; this objects manages a case's name, directory,
210 * and format, as well as associated mesh's time dependency, and the
211 * default output interval for associated variables.
212 *
213 * This function must be called before the time loop. If a writer with a
214 * given id is defined multiple times, the last definition supersedes the
215 * previous ones.
216 *
217 * Current reserved ids are the following: CS_POST_WRITER_DEFAULT
218 * for main/default output, CS_POST_WRITER_ERRORS for error visualization,
219 * CS_POST_WRITER_PROBES for main probes, CS_POST_WRITER_PARTICLES for
220 * particles, CS_POST_WRITER_TRAJECTORIES for trajectories. Other negative
221 * ids may be dynamically reserved by the code depending on options.
222 * Positive ids identify user-defined writers.
223 *
224 * \warning depending on the chosen format, the \em case_name may be
225 * shortened (maximum number of characters: 32 for \em MED, 19 for \em EnSight,
226 * or modified automatically (white-space or forbidden characters will be
227 * replaced by "_").
228 *
229 * The \c \b format_name argument is used to choose the output format, and the
230 * following values are allowed (assuming the matching
231 * support was built):
232 *
233 * - \c \b EnSight \c \b Gold (\c \b EnSight also accepted)
234 * - \c \b MED
235 * - \c \b CGNS
236 * - \c \b CCM (only for the full volume and boundary meshes)
237 * - \c \b Catalyst (in-situ visualization)
238 * - \c \b MEDCoupling (in-memory structure, to be used from other code)
239 * - \c \b plot (comma or whitespace separated 2d plot files)
240 * - \c \b time_plot (comma or whitespace separated time plot files)
241 *
242 * The format name is case-sensitive, so \c \b ensight or \c \b cgns are also valid.
243 *
244 * The optional \c \b fmt_opts character string contains a list of options related
245 * to the format, separated by spaces or commas; these options include:
246 *
247 * - \c \b binary for a binary format version (default)
248 * - \c \b big_endian to force outputs to be in \c \b big-endian mode
249 * (for \c \b EnSight).
250 * - \c \b text for a text format version (for \c \b EnSight).
251 * - \c \b adf for ADF file type (for \c \b CGNS).
252 * - \c \b hdf5 for HDF5 file type (for \c \b CGNS, normally the default if
253 * HDF5 support is available).
254 * - \c \b discard_polygons to prevent from exporting faces with more than
255 * four edges (which may not be recognized by some post-processing
256 * tools); such faces will therefore not appear in the post-processing
257 * mesh.
258 * - \c \b discard_polyhedra to prevent from exporting elements which are
259 * neither tetrahedra, prisms, pyramids nor hexahedra (which may not
260 * be recognized by some post-processing tools); such elements will
261 * therefore not appear in the post-processing mesh.
262 * - \c \b divide_polygons to divide faces with more than four edges into
263 * triangles, so that any post-processing tool can recognize them.
264 * - \c \b divide_polyhedra} to divide elements which are neither tetrahedra,
265 * prisms, pyramids nor hexahedra into simpler elements (tetrahedra and
266 * pyramids), so that any post-processing tool can recognize them.
267 * - \c \b separate_meshes to multiple meshes and associated fields to
268 * separate outputs.
269 *
270 * Note that the white-spaces in the beginning or in the end of the
271 * character strings given as arguments here are suppressed automatically.
272 *
273 * \param[in] writer_id id of writer to create. (< 0 reserved,
274 * > 0 for user); eveb for reserved ids,
275 * the matching writer's options
276 * may be redifined by calls to this function
277 * \param[in] case_name associated case name
278 * \param[in] dir_name associated directory name
279 * \param[in] fmt_name associated format name
280 * \param[in] fmt_opts associated format options string
281 * \param[in] time_dep \ref FVM_WRITER_FIXED_MESH if mesh definitions
282 * are fixed, \ref FVM_WRITER_TRANSIENT_COORDS if
283 * coordinates change,
284 * \ref FVM_WRITER_TRANSIENT_CONNECT if
285 * connectivity changes
286 * \param[in] output_at_start force output at calculation start if true
287 * \param[in] output_at_end force output at calculation end if true
288 * \param[in] interval_n default output interval in time-steps, or < 0
289 * \param[in] interval_t default output interval in seconds, or < 0
290 * (has priority over interval_n)
291 */
292/*----------------------------------------------------------------------------*/
293
294void
295cs_post_define_writer(int writer_id,
296 const char *case_name,
297 const char *dir_name,
298 const char *fmt_name,
299 const char *fmt_opts,
300 fvm_writer_time_dep_t time_dep,
301 bool output_at_start,
302 bool output_at_end,
303 int interval_n,
304 double interval_t);
305
306/*----------------------------------------------------------------------------*/
307/*
308 * \brief Define a volume post-processing mesh.
309 *
310 * \param[in] mesh_id id of mesh to define
311 * (< 0 reserved, > 0 for user)
312 * \param[in] mesh_name associated mesh name
313 * \param[in] cell_criteria selection criteria for cells
314 * \param[in] add_groups if true, add group information if present
315 * \param[in] auto_variables if true, automatic output of main variables
316 * \param[in] n_writers number of associated writers
317 * \param[in] writer_ids ids of associated writers
318 */
319/*----------------------------------------------------------------------------*/
320
321void
323 const char *mesh_name,
324 const char *cell_criteria,
325 bool add_groups,
326 bool auto_variables,
327 int n_writers,
328 const int writer_ids[]);
329
330/*----------------------------------------------------------------------------*/
331/*
332 * \brief Define a volume post-processing mesh using a selection function.
333 *
334 * The selection may be updated over time steps if both the time_varying
335 * flag is set to true and the mesh is only associated with writers defined
336 * with the FVM_WRITER_TRANSIENT_CONNECT option.
337 *
338 * Note: if the cell_select_input pointer is non-null, it must point
339 * to valid data when the selection function is called, so either:
340 * - that value or structure should not be temporary (i.e. local);
341 * - post-processing output must be ensured using cs_post_write_meshes()
342 * with a fixed-mesh writer before the data pointed to goes out of scope;
343 *
344 * \param[in] mesh_id id of mesh to define
345 * (< 0 reserved, > 0 for user)
346 * \param[in] mesh_name associated mesh name
347 * \param[in] cell_select_func pointer to cells selection function
348 * \param[in] cell_select_input pointer to optional input data for the cell
349 * selection function, or NULL
350 * \param[in] time_varying if true, try to redefine mesh at each
351 * output time
352 * \param[in] add_groups if true, add group information if present
353 * \param[in] auto_variables if true, automatic output of main variables
354 * \param[in] n_writers number of associated writers
355 * \param[in] writer_ids ids of associated writers
356 */
357/*----------------------------------------------------------------------------*/
358
359void
361 const char *mesh_name,
362 cs_post_elt_select_t *cell_select_func,
363 void *cell_select_input,
364 bool time_varying,
365 bool add_groups,
366 bool auto_variables,
367 int n_writers,
368 const int writer_ids[]);
369
370/*----------------------------------------------------------------------------*/
371/*
372 * \brief Define a surface post-processing mesh.
373 *
374 * \param[in] mesh_id id of mesh to define
375 * (< 0 reserved, > 0 for user)
376 * \param[in] mesh_name associated mesh name
377 * \param[in] i_face_criteria selection criteria for interior faces
378 * \param[in] b_face_criteria selection criteria for boundary faces
379 * \param[in] add_groups if true, add group information if present
380 * \param[in] auto_variables if true, automatic output of main variables
381 * \param[in] n_writers number of associated writers
382 * \param[in] writer_ids ids of associated writers
383 */
384/*----------------------------------------------------------------------------*/
385
386void
388 const char *mesh_name,
389 const char *i_face_criteria,
390 const char *b_face_criteria,
391 bool add_groups,
392 bool auto_variables,
393 int n_writers,
394 const int writer_ids[]);
395
396/*----------------------------------------------------------------------------*/
397/*
398 * \brief Define a surface post-processing mesh using selection functions.
399 *
400 * The selection may be updated over time steps if both the time_varying
401 * flag is set to true and the mesh is only associated with writers defined
402 * with the FVM_WRITER_TRANSIENT_CONNECT option.
403 *
404 * Note: if i_face_select_input or b_face_select_input pointer is non-null,
405 * it must point to valid data when the selection function is called,
406 * so either:
407 * - that value or structure should not be temporary (i.e. local);
408 * - post-processing output must be ensured using cs_post_write_meshes()
409 * with a fixed-mesh writer before the data pointed to goes out of scope;
410 *
411 * \param[in] mesh_id id of mesh to define
412 * (< 0 reserved, > 0 for user)
413 * \param[in] mesh_name associated mesh name
414 * \param[in] i_face_select_func pointer to interior faces selection function
415 * \param[in] b_face_select_func pointer to boundary faces selection function
416 * \param[in] i_face_select_input pointer to optional input data for the
417 * interior faces selection function, or NULL
418 * \param[in] b_face_select_input pointer to optional input data for the
419 * boundary faces selection function, or NULL
420 * \param[in] time_varying if true, try to redefine mesh at each
421 * output time
422 * \param[in] add_groups if true, add group information if present
423 * \param[in] auto_variables if true, automatic output of main variables
424 * \param[in] n_writers number of associated writers
425 * \param[in] writer_ids ids of associated writers
426 */
427/*----------------------------------------------------------------------------*/
428
429void
431 const char *mesh_name,
432 cs_post_elt_select_t *i_face_select_func,
433 cs_post_elt_select_t *b_face_select_func,
434 void *i_face_select_input,
435 void *b_face_select_input,
436 bool time_varying,
437 bool add_groups,
438 bool auto_variables,
439 int n_writers,
440 const int writer_ids[]);
441
442/*----------------------------------------------------------------------------*/
443/*
444 * \brief Define a volume or surface post-processing mesh by associated
445 * mesh location id.
446 *
447 * \param[in] mesh_id id of mesh to define
448 * (< 0 reserved, > 0 for user)
449 * \param[in] mesh_name associated mesh name
450 * \param[in] location_id associated mesh location id
451 * \param[in] add_groups if true, add group information if present
452 * \param[in] auto_variables if true, automatic output of main variables
453 * \param[in] n_writers number of associated writers
454 * \param[in] writer_ids ids of associated writers
455 */
456/*----------------------------------------------------------------------------*/
457
458void
460 const char *mesh_name,
461 int location_id,
462 bool add_groups,
463 bool auto_variables,
464 int n_writers,
465 const int writer_ids[]);
466
467/*----------------------------------------------------------------------------*/
468/*
469 * \brief Define a particles post-processing mesh.
470 *
471 * Such a mesh is always time-varying, and will only be output by writers
472 * defined with the FVM_WRITER_TRANSIENT_CONNECT option.
473 *
474 * If the trajectory_mode argument is set to true, this logic is reversed,
475 * and output will only occur for writers defined with the
476 * FVM_WRITER_FIXED_MESH option. In this case, a submesh consisting of
477 * trajectory segments for the current time step will be added to
478 * the output at each output time step.
479 *
480 * \param[in] mesh_id id of mesh to define
481 * (< 0 reserved, > 0 for user)
482 * \param[in] mesh_name associated mesh name
483 * \param[in] cell_criteria selection criteria for cells containing
484 * particles, or NULL.
485 * \param[in] density fraction of the particles in the selected area
486 * which should be output (0 < density <= 1)
487 * \param[in] trajectory if true, activate trajectory mode
488 * \param[in] auto_variables if true, automatic output of main variables
489 * \param[in] n_writers number of associated writers
490 * \param[in] writer_ids ids of associated writers
491 */
492/*----------------------------------------------------------------------------*/
493
494void
496 const char *mesh_name,
497 const char *cell_criteria,
498 double density,
499 bool trajectory,
500 bool auto_variables,
501 int n_writers,
502 const int writer_ids[]);
503
504/*----------------------------------------------------------------------------*/
505/*
506 * \brief Define a particles post-processing mesh using a selection function.
507 *
508 * The selection may be updated over time steps.
509 *
510 * Such a mesh is always time-varying, and will only be output by writers
511 * defined with the FVM_WRITER_TRANSIENT_CONNECT option.
512 *
513 * If the trajectory_mode argument is set to true, this logic is reversed,
514 * and output will only occur for writers defined with the
515 * FVM_WRITER_FIXED_MESH option. In this case, a submesh consisting of
516 * trajectory segments for the current time step will be added to
517 * the output at each output time step.
518 *
519 * Note: if the p_select_input pointer is non-null, it must point
520 * to valid data when the selection function is called, so
521 * that value or structure should not be temporary (i.e. local);
522 *
523 * \param[in] mesh_id id of mesh to define
524 * (< 0 reserved, > 0 for user)
525 * \param[in] mesh_name associated mesh name
526 * \param[in] p_select_func pointer to particles selection function
527 * \param[in] p_select_input pointer to optional input data for the particles
528 * selection function, or NULL
529 * \param[in] trajectory if true, activate trajectory mode
530 * \param[in] auto_variables if true, automatic output of main variables
531 * \param[in] n_writers number of associated writers
532 * \param[in] writer_ids ids of associated writers
533 */
534/*----------------------------------------------------------------------------*/
535
536void
538 const char *mesh_name,
539 cs_post_elt_select_t *p_select_func,
540 void *p_select_input,
541 bool trajectory,
542 bool auto_variables,
543 int n_writers,
544 const int writer_ids[]);
545
546/*----------------------------------------------------------------------------*/
547/*
548 * \brief Create a post-processing mesh associated with an existing exportable
549 * mesh representation.
550 *
551 * If the exportable mesh is not intended to be used elsewhere, one can choose
552 * to transfer its property to the post-processing mesh, which will then
553 * manage its lifecycle based on its own requirements.
554 *
555 * If the exportable mesh must still be shared, one must be careful to
556 * maintain consistency between this mesh and the post-processing output.
557 *
558 * The mesh in exportable dimension may be of a lower dimension than
559 * its parent mesh, if it has been projected. In this case, a
560 * dim_shift value of 1 indicates that parent cells are mapped to
561 * exportable faces, and faces to edges, while a dim_shift value of 2
562 * would indicate that parent cells are mapped to edges.
563 * This is important when variables values are exported.
564 *
565 * \param[in] mesh_id id of mesh to define
566 * (< 0 reserved, > 0 for user)
567 * \param[in] exp_mesh mesh in exportable representation
568 * (i.e. fvm_nodal_t)
569 * \param[in] dim_shift nonzero if exp_mesh has been projected
570 * \param[in] transfer if true, ownership of exp_mesh is transferred
571 * to the post-processing mesh
572 * \param[in] auto_variables if true, automatic output of main variables
573 * \param[in] n_writers number of associated writers
574 * \param[in] writer_ids ids of associated writers
575 */
576/*----------------------------------------------------------------------------*/
577
578void
580 fvm_nodal_t *exp_mesh,
581 int dim_shift,
582 bool transfer,
583 bool auto_variables,
584 int n_writers,
585 const int writer_ids[]);
586
587/*----------------------------------------------------------------------------*/
588/*
589 * \brief Create a mesh based upon the extraction of edges from an existing mesh.
590 *
591 * The newly created edges have no link to their parent elements, so
592 * no variable referencing parent elements may be output to this mesh,
593 * whose main use is to visualize "true" face edges when polygonal faces
594 * are subdivided by the writer. In this way, even highly non-convex
595 * faces may be visualized correctly if their edges are overlaid on
596 * the surface mesh with subdivided polygons.
597 *
598 * \param[in] mesh_id id of edges mesh to create
599 * (< 0 reserved, > 0 for user)
600 * \param[in] base_mesh_id id of existing mesh (< 0 reserved, > 0 for user)
601 * \param[in] n_writers number of associated writers
602 * \param[in] writer_ids ids of associated writers
603 */
604/*----------------------------------------------------------------------------*/
605
606void
607cs_post_define_edges_mesh(int mesh_id,
608 int base_mesh_id,
609 int n_writers,
610 const int writer_ids[]);
611
612/*----------------------------------------------------------------------------*/
613/*
614 * \brief Set restriction of a postprocessing mesh to element centers
615 *
616 * This allow simply using element centers instead of full representations.
617 *
618 * This function must be called during the postprocessing output definition
619 * stage, before any output actually occurs.
620 *
621 * If called with a non-existing mesh or writer id, or if the writer was not
622 * previously associated, no setting is changed, and this function
623 * returns silently.
624 *
625 * \param[in] mesh_id id of mesh to define
626 * (< 0 reserved, > 0 for user)
627 * \param[in] centers_only true if only element centers sould be output,
628 * false fo normal connectivity.
629 */
630/*----------------------------------------------------------------------------*/
631
632void
634 bool centers_only);
635
636/*----------------------------------------------------------------------------*/
637/*
638 * \brief Associate a writer to a postprocessing mesh.
639 *
640 * This function must be called during the postprocessing output definition
641 * stage, before any output actually occurs.
642 *
643 * If called with a non-existing mesh or writer id, or if the writer is
644 * already associated, no setting is changed, and this function
645 * returns silently.
646 *
647 * \param[in] mesh_id id of mesh to define
648 * (< 0 reserved, > 0 for user)
649 * \param[in] writer_id id of writer to associate
650 */
651/*----------------------------------------------------------------------------*/
652
653void
655 int writer_id);
656
657/*----------------------------------------------------------------------------*/
658/*
659 * \brief De-associate a writer from a postprocessing mesh.
660 *
661 * This function must be called during the postprocessing output definition
662 * stage, before any output actually occurs.
663 *
664 * If called with a non-existing mesh or writer id, or if the writer was not
665 * previously associated, no setting is changed, and this function
666 * returns silently.
667 *
668 * \param[in] mesh_id id of mesh to define
669 * (< 0 reserved, > 0 for user)
670 * \param[in] writer_id id of writer to associate
671 */
672/*----------------------------------------------------------------------------*/
673
674void
676 int writer_id);
677
678/*----------------------------------------------------------------------------*/
679/*
680 * \brief Associate a field to a writer and postprocessing mesh combination.
681 *
682 * This function must be called during the postprocessing output definition
683 * stage, before any output actually occurs.
684 *
685 * If the field should already be output automatically based on the mesh
686 * category and field output keywords, it will not be added.
687 *
688 * \param[in] mesh_id id of associated mesh
689 * \param[in] writer_id id of specified associated writer,
690 * or \ref CS_POST_WRITER_ALL_ASSOCIATED for all
691 * \param[in] field_id id of field to attach
692 * \param[in] comp_id id of field component (-1 for all)
693 */
694/*----------------------------------------------------------------------------*/
695
696void
697cs_post_mesh_attach_field(int mesh_id,
698 int writer_id,
699 int field_id,
700 int comp_id);
701
702/*----------------------------------------------------------------------------*/
703/*
704 * \brief Get a postprocessing meshes entity presence flag.
705 *
706 * This flag is an array of 5 integers, indicating the presence of elements
707 * of given types on at least one subdomain (i.e. rank):
708 * 0: presence of cells
709 * 1: presence of interior faces
710 * 2: presence of boundary faces
711 * 3: presence of particles
712 * 4: presence of probes
713 *
714 * \param[in] mesh_id postprocessing mesh id
715 *
716 * \return pointer to entity presence flag
717 */
718/*----------------------------------------------------------------------------*/
719
720const int *
721cs_post_mesh_get_ent_flag(int mesh_id);
722
723/*----------------------------------------------------------------------------*/
724/*
725 * \brief Get a postprocessing mesh's number of cells
726 *
727 * \param[in] mesh_id postprocessing mesh id
728 *
729 * \return number of cells of postprocessing mesh.
730 */
731/*----------------------------------------------------------------------------*/
732
734cs_post_mesh_get_n_cells(int mesh_id);
735
736/*----------------------------------------------------------------------------*/
737/*
738 * \brief Get a postprocessing mesh's list of cells
739 *
740 * The array of cell ids must be of at least size
741 * cs_post_mesh_get_n_cells(mesh_id).
742 *
743 * \param[in] mesh_id postprocessing mesh id
744 * \param[out] cell_ids array of associated cell ids (0 to n-1 numbering,
745 * relative to main mesh)
746 */
747/*----------------------------------------------------------------------------*/
748
749void
750cs_post_mesh_get_cell_ids(int mesh_id,
751 cs_lnum_t *cell_ids);
752
753/*----------------------------------------------------------------------------*/
754/*
755 * \brief Get a postprocessing mesh's number of interior faces
756 *
757 * \param[in] mesh_id postprocessing mesh id
758 *
759 * \return number of cells of postprocessing mesh.
760 */
761/*----------------------------------------------------------------------------*/
762
764cs_post_mesh_get_n_i_faces(int mesh_id);
765
766/*----------------------------------------------------------------------------*/
767/*
768 * \brief Get a postprocessing mesh's list of boundary faces.
769 *
770 * The array of boundary face ids must be of at least size
771 * cs_post_mesh_get_n_b_faces(mesh_id).
772 *
773 * \param[in] mesh_id postprocessing mesh id
774 * \param[out] i_face_ids array of associated interior faces ids
775 * (0 to n-1 numbering, relative to main mesh)
776 */
777/*----------------------------------------------------------------------------*/
778
779void
781 cs_lnum_t i_face_ids[]);
782
783/*----------------------------------------------------------------------------*/
784/*
785 * \brief Get a postprocessing mesh's number of boundary faces
786 *
787 * \param[in] mesh_id postprocessing mesh id
788 *
789 * \return number of cells of postprocessing mesh.
790 */
791/*----------------------------------------------------------------------------*/
792
794cs_post_mesh_get_n_b_faces(int mesh_id);
795
796/*----------------------------------------------------------------------------*/
797/*
798 * \brief Get a postprocessing mesh's list of boundary faces.
799 *
800 * The array of boundary face ids must be of at least size
801 * cs_post_mesh_get_n_b_faces(mesh_id).
802 *
803 * \param[in] mesh_id postprocessing mesh id
804 * \param[out] b_face_ids array of associated boundary faces ids
805 * (0 to n-1 numbering, relative to main mesh)
806 */
807/*----------------------------------------------------------------------------*/
808
809void
811 cs_lnum_t b_face_ids[]);
812
813/*----------------------------------------------------------------------------*/
814/*
815 * \brief Get a postprocessing mesh's number of vertices
816 *
817 * \param[in] mesh_id postprocessing mesh id
818 *
819 * \return number of vertices of postprocessing mesh.
820 */
821/*----------------------------------------------------------------------------*/
822
824cs_post_mesh_get_n_vertices(int mesh_id);
825
826/*----------------------------------------------------------------------------*/
827/*
828 * \brief Get a postprocessing mesh's list of vertices
829 *
830 * The array of vertex ids must be of at least size
831 * cs_post_mesh_get_n_vertices(mesh_id).
832 *
833 * \param[in] mesh_id postprocessing mesh id
834 * \param[out] vertex_ids array of associated vertex ids (0 to n-1 numbering,
835 * relative to main mesh)
836 */
837/*----------------------------------------------------------------------------*/
838
839void
841 cs_lnum_t *vertex_ids);
842
843/*----------------------------------------------------------------------------*/
844/*
845 * \brief Set whether postprocessing mesh's parallel domain should be output.
846 *
847 * \param[in] mesh_id postprocessing mesh id
848 * \param[in] post_domain true if parallel domain should be output,
849 * false otherwise.
850 */
851/*----------------------------------------------------------------------------*/
852
853void
855 bool post_domain);
856
857/*----------------------------------------------------------------------------*/
858/*
859 * \brief Remove a post-processing mesh.
860 *
861 * No further post-processing output will be allowed on this mesh,
862 * so the associated structures may be freed.
863 *
864 * A post-processing mesh that has been associated with a time-varying
865 * writer may not be removed.
866 *
867 * \param[in] mesh_id postprocessing mesh id
868 */
869/*----------------------------------------------------------------------------*/
870
871void
872cs_post_free_mesh(int mesh_id);
873
874/*----------------------------------------------------------------------------*/
875/*
876 * \brief Check for the existence of a writer of the given id.
877 *
878 * \param[in] writer_id writer id to check
879 *
880 * \return true if writer with this id exists, false otherwise
881 */
882/*----------------------------------------------------------------------------*/
883
884bool
885cs_post_writer_exists(int writer_id);
886
887/*----------------------------------------------------------------------------*/
888/*
889 * \brief Check for the existence of a post-processing mesh of the given id.
890 *
891 * \param[in] mesh_id mesh id to check
892 *
893 * \return true if mesh with this id exists, false otherwise
894 */
895/*----------------------------------------------------------------------------*/
896
897bool
898cs_post_mesh_exists(int mesh_id);
899
900/*----------------------------------------------------------------------------*/
901/*
902 * \brief Find next mesh with a given category id
903 *
904 * \param[in] cat_id mesh category id filter
905 * \param[in] start_mesh_id O at start, then previously returned mesh id
906 *
907 * \return id of next mesh matching catogory, or 0 if none is found
908 */
909/*----------------------------------------------------------------------------*/
910
911int
913 int start_mesh_id);
914
915/*----------------------------------------------------------------------------*/
916/*
917 * \brief Return the default writer format name
918 *
919 * \return name of the default writer format
920 */
921/*----------------------------------------------------------------------------*/
922
923const char *
925
926/*----------------------------------------------------------------------------*/
927/*
928 * \brief Return the default writer format options
929 *
930 * \return default writer format options string
931 */
932/*----------------------------------------------------------------------------*/
933
934const char *
936
937/*----------------------------------------------------------------------------*/
938/*
939 * \brief Return the next "reservable" (i.e. non-user) writer id available.
940 *
941 * \return the smallest negative integer present, -1
942 */
943/*----------------------------------------------------------------------------*/
944
945int
947
948/*----------------------------------------------------------------------------*/
949/*
950 * \brief Return the next "reservable" (i.e. non-user) mesh id available.
951 *
952 * \return the smallest negative integer present, -1
953 */
954/*----------------------------------------------------------------------------*/
955
956int
958
959/*----------------------------------------------------------------------------*/
960/*
961 * \brief Update "active" or "inactive" flag of writers based on the time step.
962 *
963 * Writers are activated if their output interval is a divisor of the
964 * current time step, or if their optional time step and value output lists
965 * contain matches for the current time step.
966 *
967 * \param[in] ts time step status structure
968 */
969/*----------------------------------------------------------------------------*/
970
971void
973
974/*----------------------------------------------------------------------------*/
975/*
976 * \brief Query if a given writer is currently active.
977 *
978 * \param[in] writer_id writer id
979 *
980 * \return true if writer is active at this time step, false otherwise
981 */
982/*----------------------------------------------------------------------------*/
983
984bool
985cs_post_writer_is_active(int writer_id);
986
987/*----------------------------------------------------------------------------*/
988/*
989 * \brief Force the "active" or "inactive" flag for a specific writer or for all
990 * writers for the current time step.
991 *
992 * \param[in] writer_id writer id, or 0 for all writers
993 * \param[in] activate false to deactivate, true to activate
994 */
995/*----------------------------------------------------------------------------*/
996
997void
998cs_post_activate_writer(int writer_id,
999 bool activate);
1000
1001/*----------------------------------------------------------------------------*/
1002/*
1003 * \brief Force the "active" or "inactive" flag for a specific writer or for all
1004 * writers for the current time step.
1005 *
1006 * This is ignored for writers which are currently disabled.
1007 *
1008 * \param[in] writer_id writer id, or 0 for all writers
1009 * \param[in] activate false to deactivate, true to activate
1010 */
1011/*----------------------------------------------------------------------------*/
1012
1013void
1015 bool activate);
1016
1017/*----------------------------------------------------------------------------*/
1018/*
1019 * \brief Disable specific writer or all writers not currently active until
1020 * \ref cs_post_enable_writer or \ref cs_post_activate_writer
1021 * is called for those writers.
1022 *
1023 * For each call to this function for a given writer, the same number
1024 * of calls to \ref cs_post_enable_writer or a single call to
1025 * \ref cs_post_activate_writer is required to re-enable the writer.
1026 *
1027 * This is useful to disable output even of fixed meshes in preprocessing
1028 * stages.
1029 *
1030 * \param[in] writer_id writer id, or 0 for all writers
1031 */
1032/*----------------------------------------------------------------------------*/
1033
1034void
1035cs_post_disable_writer(int writer_id);
1036
1037/*----------------------------------------------------------------------------*/
1038/*
1039 * \brief Enable a specific writer or all writers currently disabled by
1040 * previous calls to \ref cs_post_disable_writer.
1041 *
1042 * For each previous call to \ref cs_post_disable_writer for a given writer,
1043 * a call to this function (or a single call to \ref cs_post_activate_writer)
1044 * is required to re-enable the writer.
1045 *
1046 * This is useful to disable output even of fixed meshes in preprocessing
1047 * stages.
1048 *
1049 * \param[in] writer_id writer id, or 0 for all writers
1050 */
1051/*----------------------------------------------------------------------------*/
1052
1053void
1054cs_post_enable_writer(int writer_id);
1055
1056/*----------------------------------------------------------------------------*/
1057/*
1058 * \brief Return a pointer to the FVM writer associated to a writer_id.
1059 *
1060 * \param[in] writer_id associated writer id
1061 *
1062 * \return a pointer to a fvm_writer_t structure
1063 */
1064/*----------------------------------------------------------------------------*/
1065
1066fvm_writer_t *
1067cs_post_get_writer(int writer_id);
1068
1069/*----------------------------------------------------------------------------*/
1070/*
1071 * \brief Return a pointer to the time control associated to a writer_id.
1072 *
1073 * \param[in] writer_id associated writer id
1074 *
1075 * \return a pointer to a cs_time_control_t structure
1076 */
1077/*----------------------------------------------------------------------------*/
1078
1080cs_post_get_time_control(int writer_id);
1081
1082/*----------------------------------------------------------------------------*/
1083/*
1084 * \brief Return time dependency associated to a writer_id.
1085 *
1086 * \param[in] writer_id associated writer id
1087 *
1088 * \return associated writer's time dependency
1089 */
1090/*----------------------------------------------------------------------------*/
1091
1093cs_post_get_writer_time_dep(int writer_id);
1094
1095/*----------------------------------------------------------------------------*/
1096/*
1097 * \brief Add an activation time step for a specific writer or for all writers.
1098 *
1099 * If a negative value is provided, a previously added activation time
1100 * step matching that absolute value will be removed, if present.
1101 *
1102 * \param[in] writer_id writer id, or 0 for all writers
1103 * \param[in] nt time step value to add (or remove)
1104 */
1105/*----------------------------------------------------------------------------*/
1106
1107void
1108cs_post_add_writer_t_step(int writer_id,
1109 int nt);
1110
1111/*----------------------------------------------------------------------------*/
1112/*
1113 * \brief Add an activation time value for a specific writer or for all writers.
1114 *
1115 * If a negative value is provided, a previously added activation time
1116 * step matching that absolute value will be removed, if present.
1117 *
1118 * \param[in] writer_id writer id, or 0 for all writers
1119 * \param[in] t time value to add (or remove)
1120 */
1121/*----------------------------------------------------------------------------*/
1122
1123void
1124cs_post_add_writer_t_value(int writer_id,
1125 double t);
1126
1127/*----------------------------------------------------------------------------*/
1128/*
1129 * \brief Output post-processing meshes using associated writers.
1130 *
1131 * If the time step structure argument passed is NULL, a time-independent
1132 * output will be assumed.
1133 *
1134 * \param[in] ts time step status structure, or NULL
1135 */
1136/*----------------------------------------------------------------------------*/
1137
1138void
1140
1141/*----------------------------------------------------------------------------*/
1142/*
1143 * \brief Output a variable defined at cells or faces of a post-processing mesh
1144 * using associated writers.
1145 *
1146 * \param[in] mesh_id id of associated mesh
1147 * \param[in] writer_id id of specified associated writer,
1148 * or \ref CS_POST_WRITER_ALL_ASSOCIATED for all
1149 * \param[in] var_name name of variable to output
1150 * \param[in] var_dim 1 for scalar, 3 for vector, 6 for symmetric tensor,
1151 * 9 for non-symmetric tensor
1152 * \param[in] interlace if a vector, true for interlaced values,
1153 * false otherwise
1154 * \param[in] use_parent true if values are defined on "parent" mesh,
1155 * false if values are defined on post-processing mesh
1156 * \param[in] datatype variable's data type
1157 * \param[in] cel_vals cell values
1158 * \param[in] i_face_vals interior face values
1159 * \param[in] b_face_vals boundary face values
1160 * \param[in] ts time step status structure, or NULL
1161 */
1162/*----------------------------------------------------------------------------*/
1163
1164void
1165cs_post_write_var(int mesh_id,
1166 int writer_id,
1167 const char *var_name,
1168 int var_dim,
1169 bool interlace,
1170 bool use_parent,
1171 cs_datatype_t datatype,
1172 const void *cel_vals,
1173 const void *i_face_vals,
1174 const void *b_face_vals,
1175 const cs_time_step_t *ts);
1176
1177/*----------------------------------------------------------------------------*/
1178/*
1179 * \brief Output a function evaluation at cells or faces of a
1180 * post-processing mesh using associated writers.
1181 *
1182 * The associated mesh and function locations must have compatible types.
1183 *
1184 * Note that while providing functions for multiple mesh locations
1185 * (such as interior and boundary faces when a postprocessing mesh contains
1186 * both) is possible, it is not handled yet, so such cases will be ignored.
1187 *
1188 * \param[in] mesh_id id of associated mesh
1189 * \param[in] writer_id id of specified associated writer,
1190 * or \ref CS_POST_WRITER_ALL_ASSOCIATED for all
1191 * \param[in] cell_f pointer to function object at cells
1192 * \param[in] i_face_f pointer to function object at interior faces
1193 * \param[in] b_face_f pointer to function object at boundary faces
1194 * \param[in] ts time step status structure, or NULL
1195 */
1196/*----------------------------------------------------------------------------*/
1197
1198void
1199cs_post_write_function(int mesh_id,
1200 int writer_id,
1201 const cs_function_t *cel_f,
1202 const cs_function_t *i_face_f,
1203 const cs_function_t *b_face_f,
1204 const cs_time_step_t *ts);
1205
1206/*----------------------------------------------------------------------------*/
1207/*
1208 * \brief Output a variable defined at vertices of a post-processing mesh using
1209 * associated writers.
1210 *
1211 * \param[in] mesh_id id of associated mesh
1212 * \param[in] writer_id id of specified associated writer,
1213 * or \ref CS_POST_WRITER_ALL_ASSOCIATED for all
1214 * \param[in] var_name name of variable to output
1215 * \param[in] var_dim 1 for scalar, 3 for vector, 6 for symmetric tensor,
1216 * 9 for non-symmetric tensor
1217 * \param[in] interlace if a vector, true for interlaced values,
1218 * false otherwise
1219 * \param[in] use_parent true if values are defined on "parent" mesh,
1220 * false if values are defined on post-processing mesh
1221 * \param[in] datatype variable's data type
1222 * \param[in] vtx_vals vertex values
1223 * \param[in] ts time step status structure, or NULL
1224 */
1225/*----------------------------------------------------------------------------*/
1226
1227void
1228cs_post_write_vertex_var(int mesh_id,
1229 int writer_id,
1230 const char *var_name,
1231 int var_dim,
1232 bool interlace,
1233 bool use_parent,
1234 cs_datatype_t datatype,
1235 const void *vtx_vals,
1236 const cs_time_step_t *ts);
1237
1238/*----------------------------------------------------------------------------*/
1239/*
1240 * \brief Output a function evaluation at cells or faces of a
1241 * post-processing mesh using associated writers.
1242 *
1243 * The associated mesh and function locations must have compatible types.
1244 *
1245 * \param[in] mesh_id id of associated mesh
1246 * \param[in] writer_id id of specified associated writer,
1247 * or \ref CS_POST_WRITER_ALL_ASSOCIATED for all
1248 * \param[in] f pointer to function object at vertices
1249 * \param[in] ts time step status structure, or NULL
1250 */
1251/*----------------------------------------------------------------------------*/
1252
1253void
1255 int writer_id,
1256 const cs_function_t *f,
1257 const cs_time_step_t *ts);
1258
1259/*----------------------------------------------------------------------------*/
1260/*
1261 * \brief Output an existing lagrangian particle attribute at particle
1262 * positions or trajectory endpoints of a particle mesh using
1263 * associated writers.
1264 *
1265 * \param[in] mesh_id id of associated mesh
1266 * \param[in] writer_id id of specified associated writer,
1267 * or \ref CS_POST_WRITER_ALL_ASSOCIATED for all
1268 * \param[in] attr_id associated particle attribute id
1269 * \param[in] var_name name of variable to output
1270 * \param[in] component_id if -1 : extract the whole attribute
1271 * if >0 : id of the component to extract
1272 * \param[in] ts time step status structure, or NULL
1273 */
1274/*----------------------------------------------------------------------------*/
1275
1276void
1278 int writer_id,
1279 int attr_id,
1280 const char *var_name,
1281 int component_id,
1282 const cs_time_step_t *ts);
1283
1284/*----------------------------------------------------------------------------*/
1285/*
1286 * \brief Output a variable defined at cells or faces of a post-processing mesh
1287 * using associated writers.
1288 *
1289 * \param[in] mesh_id id of associated mesh
1290 * \param[in] writer_id id of specified associated writer,
1291 * or \ref CS_POST_WRITER_ALL_ASSOCIATED for all
1292 * \param[in] var_name name of variable to output
1293 * \param[in] var_dim 1 for scalar, 3 for vector, 6 for symmetric
1294 * tensor, 9 for non-symmetric tensor
1295 * \param[in] datatype variable's data type
1296 * \param[in] parent_location_id asociated values mesh location, or 0
1297 * if values are passed directly
1298 * \param[in] interpolate_func pointer to interpolation function,
1299 * or NULL for default
1300 * \param[in] interpolate_input pointer to optional interpolation input
1301 * data, or NULL for default
1302 * \param[in] vals variable's values
1303 * \param[in] ts time step status structure, or NULL
1304 */
1305/*----------------------------------------------------------------------------*/
1306
1307void
1308cs_post_write_probe_values(int mesh_id,
1309 int writer_id,
1310 const char *var_name,
1311 int var_dim,
1312 cs_datatype_t datatype,
1313 int parent_location_id,
1314 cs_interpolate_from_location_t *interpolate_func,
1315 void *interpolate_input,
1316 const void *vals,
1317 const cs_time_step_t *ts);
1318
1319/*----------------------------------------------------------------------------*/
1320/*
1321 * \brief Output function-evaluated values at cells or faces of a
1322 * post-processing probe set using associated writers.
1323 *
1324 * - For real-valued data with interpolation, the function is evaluated on the
1325 * whole parent domain so as to be able to compute gradients, then
1326 * interpolate on the probe set.
1327 * * For vertex-based values, a lighter, cell-based interpolation would
1328 * be feasible, but is not available yet.
1329 * * For cell or face-based values, likewise, only the immediate neighborhood
1330 * of elements containing probes are needed, but such filtering would
1331 * require building the matching element list and adding an indirection
1332 * to the gradients computation.
1333 *
1334 * - In the specific case where the function evaluation uses an analytic
1335 * function, to which the exact coordinates are provides, such interpolation
1336 * is not deemed necessary, as the anaytic function may handle this more
1337 * efficiently.
1338 *
1339 * - For non-real-based values, or real-based values other than cs_real_t,
1340 * no interpolation is performed
1341 *
1342 * \param[in] mesh_id id of associated mesh
1343 * \param[in] writer_id id of specified associated writer,
1344 * or \ref CS_POST_WRITER_ALL_ASSOCIATED for all
1345 * \param[in] f pointer to associated function object
1346 * \param[in] parent_location_id associated values at mesh location, or 0
1347 * if values are passed directly
1348 * \param[in] interpolate_func pointer to interpolation function,
1349 * or NULL for default
1350 * \param[in] interpolate_input pointer to optional interpolation input
1351 * data, or NULL for default
1352 * \param[in] ts time step status structure, or NULL
1353 */
1354/*----------------------------------------------------------------------------*/
1355
1356void
1358 int writer_id,
1359 const cs_function_t *f,
1360 int parent_location_id,
1361 cs_interpolate_from_location_t *interpolate_func,
1362 void *interpolate_input,
1363 const cs_time_step_t *ts);
1364
1365/*----------------------------------------------------------------------------*/
1366/*
1367 * \brief Update references to parent mesh of post-processing meshes in case of
1368 * computational mesh cell renumbering.
1369 *
1370 * This function may be called only once, after possible renumbering of cells,
1371 * to update existing post-processing meshes. Post-processing meshes defined
1372 * after renumbering will automatically be based upon the new numbering,
1373 * so this function will not need to be called again.
1374 *
1375 * \param[in] init_cell_num initial cell numbering (new -> old)
1376 */
1377/*----------------------------------------------------------------------------*/
1378
1379void
1380cs_post_renum_cells(const cs_lnum_t init_cell_num[]);
1381
1382/*----------------------------------------------------------------------------*/
1383/*
1384 * \brief Update references to parent mesh of post-processing meshes in case of
1385 * computational mesh interior and/or boundary faces renumbering.
1386 *
1387 * This function may be called only once, after possible renumbering of faces,
1388 * to update existing post-processing meshes. Post-processing meshes defined
1389 * after renumbering will automatically be based upon the new numbering,
1390 * so this function will not need to be called again.
1391 *
1392 * \param[in] init_i_face_num initial interior numbering (new -> old)
1393 * \param[in] init_b_face_num initial boundary numbering (new -> old)
1394 */
1395/*----------------------------------------------------------------------------*/
1396
1397void
1398cs_post_renum_faces(const cs_lnum_t init_i_face_num[],
1399 const cs_lnum_t init_b_face_num[]);
1400
1401/*----------------------------------------------------------------------------*/
1402/*
1403 * \brief Configure the post-processing output so that mesh connectivity
1404 * may be automatically updated.
1405 *
1406 * This is done for meshes defined using selection criteria or functions.
1407 * The behavior of Lagrangian meshes is unchanged.
1408 *
1409 * To be effective, this function should be called before defining
1410 * postprocessing meshes.
1411 */
1412/*----------------------------------------------------------------------------*/
1413
1414void
1416
1417/*----------------------------------------------------------------------------*/
1421/*----------------------------------------------------------------------------*/
1422
1423void
1425
1426/*----------------------------------------------------------------------------*/
1427/*
1428 * \brief Initialize main post-processing meshes
1429 *
1430 * The check_flag variable is a mask, used for additionnal post-processing:
1431 *
1432 * - If (check_flag & 1), volume submeshes are output by groups if more
1433 * than one group is present and the default writer uses the EnSight format.
1434 *
1435 * - If (check_flag & 2), boundary submeshes are output by groups if more
1436 * than one group is present and the default writer uses the EnSight format.
1437 *
1438 * It is recommended that post-processing meshes be defined before calling
1439 * this function, though specific "automatic" meshes (for example those
1440 * related to couplings) may be defined between this call and a time loop.
1441 *
1442 * \param[in] check_mask mask used for additional output
1443 */
1444/*----------------------------------------------------------------------------*/
1445
1446void
1447cs_post_init_meshes(int check_mask);
1448
1449/*----------------------------------------------------------------------------*/
1450/*
1451 * \brief Check if post-processing is activated and then update post-processing
1452 * of meshes if there is a need to update time-dependent meshes
1453 *
1454 * \param[in] ts time step status structure, or NULL
1455 */
1456/*----------------------------------------------------------------------------*/
1457
1458void
1460
1461/*----------------------------------------------------------------------------*/
1462/*
1463 * \brief Loop on post-processing meshes to output variables.
1464 *
1465 * This handles all default fields output, as well as all
1466 * registered output functions and outputs defined in
1467 * \ref cs_user_postprocess_values
1468 *
1469 * \param[in] ts time step status structure, or NULL
1470 */
1471/*----------------------------------------------------------------------------*/
1472
1473void
1475
1476/*----------------------------------------------------------------------------*/
1477/*
1478 * \brief Flush writers and free time-varying and Lagragian mesh if needed
1479 * of meshes if there is a time-dependent mesh
1480 */
1481/*----------------------------------------------------------------------------*/
1482
1483void
1485
1486/*----------------------------------------------------------------------------*/
1487/*
1488 * \brief Loop on post-processing meshes to output variables.
1489 *
1490 * This handles all default fields output, as well as all
1491 * registered output functions and outputs defined in
1492 * \ref cs_user_postprocess_values
1493 *
1494 * \param[in] ts time step status structure, or NULL
1495 */
1496/*----------------------------------------------------------------------------*/
1497
1498void
1500
1501/*----------------------------------------------------------------------------*/
1502/*
1503 * \brief Destroy all structures associated with post-processing
1504 */
1505/*----------------------------------------------------------------------------*/
1506
1507void
1508cs_post_finalize(void);
1509
1510/*----------------------------------------------------------------------------*/
1511/*
1512 * \brief Postprocess free (isolated) faces of the current global mesh
1513 */
1514/*----------------------------------------------------------------------------*/
1515
1516void
1518
1519/*----------------------------------------------------------------------------*/
1520/*
1521 * \brief Initialize post-processing writer with same format and associated
1522 * options as default writer, but no time dependency, intended to
1523 * troubleshoot errors.
1524 */
1525/*----------------------------------------------------------------------------*/
1526
1527void
1529
1530/*----------------------------------------------------------------------------*/
1531/*
1532 * \brief Initialize post-processing writer with same format and associated
1533 * options as default writer, but no time dependency, and associate
1534 * and output global volume mesh.
1535 *
1536 * This is intended to help troubleshoot errors using fields based
1537 * on cells.
1538 *
1539 * \return id of error output mesh (< 0), or 0 if all writers are deactivated
1540 */
1541/*----------------------------------------------------------------------------*/
1542
1543int
1545
1546/*----------------------------------------------------------------------------*/
1547/*
1548 * \brief Register a processing of time-dependent variables to the call to
1549 * cs_post_write_vars().
1550 *
1551 * Note: if the input pointer is non-null, it must point to valid data
1552 * when the output function is called, so either:
1553 * - that value or structure should not be temporary (i.e. local);
1554 * - post-processing output must be ensured using cs_post_write_var()
1555 * or similar before the data pointed to goes out of scope.
1556 *
1557 * \param[in] function function to register
1558 * \param[in, out] input pointer to optional (untyped) value or structure
1559 */
1560/*----------------------------------------------------------------------------*/
1561
1562void
1564 void *input);
1565
1566/*----------------------------------------------------------------------------*/
1567/*
1568 * \brief Register a processing of time-dependent variables than can be output
1569 * on different meshes to the call to cs_post_write_vars().
1570 *
1571 * Note: if the input pointer is non-null, it must point to valid data
1572 * when the output function is called, so either:
1573 * - that value or structure should not be temporary (i.e. local);
1574 * - post-processing output must be ensured using cs_post_write_var()
1575 * or similar before the data pointed to goes out of scope.
1576 *
1577 * \param[in] function function to register
1578 * \param[in, out] input pointer to optional (untyped) value or structure
1579 */
1580/*----------------------------------------------------------------------------*/
1581
1582void
1584 void *input);
1585
1586/*----------------------------------------------------------------------------*/
1587
1589
1590#endif /* __CS_POST_H__ */
cs_datatype_t
Definition: cs_defs.h:300
Definition: cs_defs.h:542
Definition: cs_defs.h:543
Definition: cs_defs.h:335
@ t
Definition: cs_field_pointer.h:94
void() cs_interpolate_from_location_t(void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals)
Function pointer for interpolatation of values defined on a mesh location at a given set of points.
Definition: cs_interpolate.h:71
const char * cs_post_get_default_format_options(void)
Return the default writer format options.
Definition: cs_post.cpp:5651
int cs_post_get_free_mesh_id(void)
Definition: cs_post.cpp:5679
void cs_post_mesh_get_b_face_ids(int mesh_id, cs_lnum_t b_face_ids[])
Definition: cs_post.cpp:5358
void cs_post_write_probe_values(int mesh_id, int writer_id, const char *var_name, int var_dim, cs_datatype_t datatype, int parent_location_id, cs_interpolate_from_location_t *interpolate_func, void *interpolate_input, const void *vals, const cs_time_step_t *ts)
Output a variable defined at cells or faces of a post-processing mesh using associated writers.
Definition: cs_post.cpp:7003
void cs_post_time_step_output(const cs_time_step_t *ts)
Definition: cs_post.cpp:7793
void cs_post_add_time_mesh_dep_output(cs_post_time_mesh_dep_output_t *function, void *input)
Register a processing of time-dependent variables than can be output on different meshes to the call ...
Definition: cs_post.cpp:8598
int cs_post_get_free_writer_id(void)
Definition: cs_post.cpp:5665
void cs_post_init_error_writer(void)
Initialize post-processing writer with same format and associated options as default writer,...
Definition: cs_post.cpp:8465
void cs_post_add_writer_t_step(int writer_id, int nt)
Definition: cs_post.cpp:6012
void cs_post_renum_faces(const cs_lnum_t init_i_face_num[], const cs_lnum_t init_b_face_num[])
Update references to parent mesh of post-processing meshes in case of computational mesh interior and...
Definition: cs_post.cpp:7379
void cs_post_init_meshes(int check_mask)
Initialize main post-processing meshes.
Definition: cs_post.cpp:7600
void cs_post_add_free_faces(void)
Postprocess free (isolated) faces of the current global mesh.
Definition: cs_post.cpp:8254
void cs_post_time_step_begin(const cs_time_step_t *ts)
Check if post-processing is activated and then update post-processing of meshes if there is a need to...
Definition: cs_post.cpp:7760
void() cs_post_time_mesh_dep_output_t(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *ts)
Definition: cs_post.h:183
void cs_post_finalize(void)
Destroy all structures associated with post-processing.
Definition: cs_post.cpp:8159
void cs_post_define_mesh_by_location(int mesh_id, const char *mesh_name, int location_id, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a volume or surface post-processing mesh by associated mesh location id.
Definition: cs_post.cpp:4594
void cs_post_define_volume_mesh(int mesh_id, const char *mesh_name, const char *cell_criteria, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Definition: cs_post.cpp:4336
void cs_post_define_volume_mesh_by_func(int mesh_id, const char *mesh_name, cs_post_elt_select_t *cell_select_func, void *cell_select_input, bool time_varying, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Definition: cs_post.cpp:4404
void cs_post_mesh_get_vertex_ids(int mesh_id, cs_lnum_t *vertex_ids)
Get a postprocessing mesh's list of vertices.
Definition: cs_post.cpp:5430
void cs_post_write_vertex_var(int mesh_id, int writer_id, const char *var_name, int var_dim, bool interlace, bool use_parent, cs_datatype_t datatype, const void *vtx_vals, const cs_time_step_t *ts)
Output a variable defined at vertices of a post-processing mesh using associated writers.
Definition: cs_post.cpp:6607
void cs_post_write_particle_values(int mesh_id, int writer_id, int attr_id, const char *var_name, int component_id, const cs_time_step_t *ts)
Output an existing lagrangian particle attribute at particle positions or trajectory endpoints of a p...
Definition: cs_post.cpp:6840
cs_lnum_t cs_post_mesh_get_n_vertices(int mesh_id)
Get a postprocessing mesh's number of vertices.
Definition: cs_post.cpp:5400
cs_time_control_t * cs_post_get_time_control(int writer_id)
Definition: cs_post.cpp:5962
fvm_writer_t * cs_post_get_writer(int writer_id)
Definition: cs_post.cpp:5937
void cs_post_define_particles_mesh_by_func(int mesh_id, const char *mesh_name, cs_post_elt_select_t *p_select_func, void *p_select_input, bool trajectory, bool auto_variables, int n_writers, const int writer_ids[])
Definition: cs_post.cpp:4741
void cs_post_write_var(int mesh_id, int writer_id, const char *var_name, int var_dim, bool interlace, bool use_parent, cs_datatype_t datatype, const void *cel_vals, const void *i_face_vals, const void *b_face_vals, const cs_time_step_t *ts)
Definition: cs_post.cpp:6124
void cs_post_write_meshes(const cs_time_step_t *ts)
Definition: cs_post.cpp:6067
int cs_post_init_error_writer_cells(void)
Definition: cs_post.cpp:8515
bool cs_post_writer_exists(int writer_id)
Definition: cs_post.cpp:5546
void cs_post_write_vertex_function(int mesh_id, int writer_id, const cs_function_t *f, const cs_time_step_t *ts)
Output a function evaluation at cells or faces of a post-processing mesh using associated writers.
Definition: cs_post.cpp:6726
void cs_post_set_changing_connectivity(void)
Configure the post-processing output so that mesh connectivity may be automatically updated.
Definition: cs_post.cpp:7474
void cs_post_define_writer(int writer_id, const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int interval_n, double interval_t)
Define a writer; this objects manages a case's name, directory, and format, as well as associated mes...
Definition: cs_post.cpp:4181
void cs_post_define_particles_mesh(int mesh_id, const char *mesh_name, const char *cell_criteria, double density, bool trajectory, bool auto_variables, int n_writers, const int writer_ids[])
Definition: cs_post.cpp:4673
void cs_post_write_probe_function(int mesh_id, int writer_id, const cs_function_t *f, int parent_location_id, cs_interpolate_from_location_t *interpolate_func, void *interpolate_input, const cs_time_step_t *ts)
Output function-evaluated values at cells or faces of a post-processing probe set using associated wr...
Definition: cs_post.cpp:7141
const char * cs_post_get_default_format(void)
Return the default writer format name.
Definition: cs_post.cpp:5637
cs_lnum_t cs_post_mesh_get_n_cells(int mesh_id)
Get a postprocessing mesh's number of cells.
Definition: cs_post.cpp:5196
void cs_post_write_vars(const cs_time_step_t *ts)
Definition: cs_post.cpp:8137
void cs_post_add_time_dep_output(cs_post_time_dep_output_t *function, void *input)
Register a processing of time-dependent variables to the call to cs_post_write_vars().
Definition: cs_post.cpp:8557
cs_lnum_t cs_post_mesh_get_n_b_faces(int mesh_id)
Get a postprocessing mesh's number of boundary faces.
Definition: cs_post.cpp:5328
cs_datatype_t cs_post_type_t
Definition: cs_post.h:95
void cs_post_add_writer_t_value(int writer_id, double t)
Definition: cs_post.cpp:6040
void cs_post_mesh_set_post_domain(int mesh_id, bool post_domain)
Definition: cs_post.cpp:5459
void() cs_post_time_dep_output_t(void *input, const cs_time_step_t *ts)
Definition: cs_post.h:149
void cs_post_activate_by_time_step(const cs_time_step_t *ts)
Definition: cs_post.cpp:5697
void cs_post_activate_writer_if_enabled(int writer_id, bool activate)
Force the "active" or "inactive" flag for a specific writer or for all writers for the current time s...
Definition: cs_post.cpp:5831
void cs_post_mesh_get_cell_ids(int mesh_id, cs_lnum_t *cell_ids)
Get a postprocessing mesh's list of cells.
Definition: cs_post.cpp:5226
void cs_post_write_function(int mesh_id, int writer_id, const cs_function_t *cel_f, const cs_function_t *i_face_f, const cs_function_t *b_face_f, const cs_time_step_t *ts)
Definition: cs_post.cpp:6394
void() cs_post_elt_select_t(void *input, cs_lnum_t *n_elts, cs_lnum_t **elt_list)
Function pointer to elements selection definition.
Definition: cs_post.h:126
void cs_post_disable_writer(int writer_id)
Disable specific writer or all writers not currently active until cs_post_enable_writer or cs_post_ac...
Definition: cs_post.cpp:5869
void cs_post_free_mesh(int mesh_id)
Definition: cs_post.cpp:5482
void cs_post_activate_writer(int writer_id, bool activate)
Definition: cs_post.cpp:5802
void cs_post_define_surface_mesh(int mesh_id, const char *mesh_name, const char *i_face_criteria, const char *b_face_criteria, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Definition: cs_post.cpp:4454
void cs_post_mesh_detach_writer(int mesh_id, int writer_id)
Definition: cs_post.cpp:5048
void cs_post_mesh_get_i_face_ids(int mesh_id, cs_lnum_t i_face_ids[])
Definition: cs_post.cpp:5285
void cs_post_define_edges_mesh(int mesh_id, int base_mesh_id, int n_writers, const int writer_ids[])
Definition: cs_post.cpp:4931
void cs_post_mesh_attach_field(int mesh_id, int writer_id, int field_id, int comp_id)
Definition: cs_post.cpp:5112
cs_lnum_t cs_post_mesh_get_n_i_faces(int mesh_id)
Get a postprocessing mesh's number of interior faces.
Definition: cs_post.cpp:5255
void cs_post_time_step_end(void)
Flush writers and free time-varying and Lagragian mesh if needed of meshes if there is a time-depende...
Definition: cs_post.cpp:8093
void cs_post_renum_cells(const cs_lnum_t init_cell_num[])
Update references to parent mesh of post-processing meshes in case of computational mesh cell renumbe...
Definition: cs_post.cpp:7303
const int * cs_post_mesh_get_ent_flag(int mesh_id)
Definition: cs_post.cpp:5178
void cs_post_define_surface_mesh_by_func(int mesh_id, const char *mesh_name, cs_post_elt_select_t *i_face_select_func, cs_post_elt_select_t *b_face_select_func, void *i_face_select_input, void *b_face_select_input, bool time_varying, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Definition: cs_post.cpp:4534
int cs_post_mesh_find_next_with_cat_id(int cat_id, int start_mesh_id)
Find next mesh with a given category id.
Definition: cs_post.cpp:5603
void cs_post_init_writers(void)
Initialize post-processing writers.
Definition: cs_post.cpp:7486
void cs_post_mesh_attach_writer(int mesh_id, int writer_id)
Definition: cs_post.cpp:5003
void cs_post_mesh_set_element_centers_only(int mesh_id, bool centers_only)
Set restriction of a postprocessing mesh to element centers.
Definition: cs_post.cpp:4975
void cs_post_enable_writer(int writer_id)
Enable a specific writer or all writers currently disabled by previous calls to cs_post_disable_write...
Definition: cs_post.cpp:5906
bool cs_post_writer_is_active(int writer_id)
Definition: cs_post.cpp:5783
bool cs_post_mesh_exists(int mesh_id)
Definition: cs_post.cpp:5575
void cs_post_define_existing_mesh(int mesh_id, fvm_nodal_t *exp_mesh, int dim_shift, bool transfer, bool auto_variables, int n_writers, const int writer_ids[])
Create a post-processing mesh associated with an existing exportable mesh representation.
Definition: cs_post.cpp:4807
fvm_writer_time_dep_t cs_post_get_writer_time_dep(int writer_id)
Definition: cs_post.cpp:5981
Definition: fvm_writer.h:57
double precision, dimension(:,:,:), allocatable density
Definition: atimbr.f90:123
Definition: cs_function.h:121
Definition: cs_time_control.h:96
time step descriptor
Definition: cs_time_step.h:64
