8.3
At_imbrication
Data Types
interface  cs_f_atmo_get_pointers_imbrication
Functions/Subroutines
subroutine cs_f_atmo_get_pointers_imbrication (p_imbrication_flag, p_imbrication_verbose, p_cressman_u, p_cressman_v, p_cressman_qw, p_cressman_nc, p_cressman_tke, p_cressman_eps, p_cressman_theta, p_vertical_influence_radius, p_horizontal_influence_radius, p_id_u, p_id_v, p_id_nc, p_id_qw, p_id_tke, p_id_eps, p_id_theta)
logical(c_bool), pointer imbrication_flag
 activation flag More...
logical(c_bool), pointer, save imbrication_verbose
logical(c_bool), pointer cressman_u
 Flags for activating the cressman interpolation for the boundary conditions. More...
logical(c_bool), pointer cressman_v
logical(c_bool), pointer cressman_tke
logical(c_bool), pointer cressman_eps
logical(c_bool), pointer cressman_theta
logical(c_bool), pointer cressman_qw
logical(c_bool), pointer cressman_nc
real(c_double), pointer vertical_influence_radius
 numerical parameters for the cressman interpolation formulas More...
real(c_double), pointer horizontal_influence_radius
integer line_len
 Parameter for "meteo" files. More...
character(line_lenimbrication_files_list
character(line_len), dimension(:), allocatable imbrication_files
integer number_of_files
character *(3) skip_chars
integer thermal_profile_dim
 Profile dimension variable. More...
integer dynamical_profile_dim
integer sections_per_file
 Time sections per files. More...
integer, dimension(:,:), allocatable years
 read data from "meteo" files More...
integer, dimension(:,:), allocatable ordinals
integer, dimension(:,:), allocatable hours
integer, dimension(:,:), allocatable minutes
double precision, dimension(:,:), allocatable seconds
double precision, dimension(:,:), allocatable xpos
 Positions. More...
double precision, dimension(:,:), allocatable ypos
double precision, dimension(:,:), allocatable ground_pressure
double precision, dimension(:,:,:), allocatable zt
 Vertical grid for temperature and humidity variables. More...
double precision, dimension(:,:,:), allocatable tempc
double precision, dimension(:,:,:), allocatable qw
double precision, dimension(:,:,:), allocatable nc
double precision, dimension(:,:,:), allocatable zd
 Vertical grid for wind variables. More...
double precision, dimension(:,:,:), allocatable u
double precision, dimension(:,:,:), allocatable v
double precision, dimension(:,:,:), allocatable tke
double precision, dimension(:,:,:), allocatable eps
double precision, dimension(:,:), allocatable, target times
 derived data More...
double precision, dimension(:,:,:), allocatable pressure
double precision, dimension(:,:,:), allocatable theta
double precision, dimension(:,:,:), allocatable density
double precision, dimension(:,:), allocatable ti_zt
 time interpolated profiles More...
double precision, dimension(:,:), allocatable ti_tempc
double precision, dimension(:,:), allocatable ti_qw
double precision, dimension(:,:), allocatable ti_nc
double precision, dimension(:,:), allocatable ti_zd
double precision, dimension(:,:), allocatable ti_u
double precision, dimension(:,:), allocatable ti_v
double precision, dimension(:,:), allocatable ti_tke
double precision, dimension(:,:), allocatable ti_eps
double precision, dimension(:,:), allocatable ti_pressure
double precision, dimension(:,:), allocatable ti_theta
double precision, dimension(:,:), allocatable ti_density
double precision, dimension(:,:,:), allocatable coordinates_th
 additional variables More...
double precision, dimension(:,:,:), allocatable influence_param_th
double precision, dimension(:,:,:), allocatable coordinates_dyn
double precision, dimension(:,:,:), allocatable influence_param_dyn
integer(c_int), pointer id_u
integer(c_int), pointer id_v
integer(c_int), pointer id_qw
integer(c_int), pointer id_nc
integer(c_int), pointer id_tke
integer(c_int), pointer id_eps
integer(c_int), pointer id_theta
double precision, dimension(:), pointer times_sequence =>null()
 1D array of times at which profiles are given More...
◆ cs_f_atmo_get_pointers_imbrication()
subroutine cs_f_atmo_get_pointers_imbrication ( type(c_ptr), intent(out)  p_imbrication_flag,
type(c_ptr), intent(out)  p_imbrication_verbose,
type(c_ptr), intent(out)  p_cressman_u,
type(c_ptr), intent(out)  p_cressman_v,
type(c_ptr), intent(out)  p_cressman_qw,
type(c_ptr), intent(out)  p_cressman_nc,
type(c_ptr), intent(out)  p_cressman_tke,
type(c_ptr), intent(out)  p_cressman_eps,
type(c_ptr), intent(out)  p_cressman_theta,
type(c_ptr), intent(out)  p_vertical_influence_radius,
type(c_ptr), intent(out)  p_horizontal_influence_radius,
type(c_ptr), intent(out)  p_id_u,
type(c_ptr), intent(out)  p_id_v,
type(c_ptr), intent(out)  p_id_nc,
type(c_ptr), intent(out)  p_id_qw,
type(c_ptr), intent(out)  p_id_tke,
type(c_ptr), intent(out)  p_id_eps,
type(c_ptr), intent(out)  p_id_theta
◆ coordinates_dyn
◆ coordinates_th
◆ cressman_eps
◆ cressman_nc
◆ cressman_qw
◆ cressman_theta
◆ cressman_tke
◆ cressman_u
◆ cressman_v
◆ density
◆ dynamical_profile_dim
◆ eps
◆ ground_pressure
◆ horizontal_influence_radius
◆ hours
◆ id_eps
◆ id_nc
◆ id_qw
◆ id_theta
◆ id_tke
◆ id_u
◆ id_v
◆ imbrication_files
◆ imbrication_files_list
character(line_len) imbrication_files_list
◆ imbrication_flag
activation flag
◆ imbrication_verbose
◆ influence_param_dyn
◆ influence_param_th
◆ line_len
integer line_len
◆ minutes
◆ nc
◆ number_of_files
◆ ordinals
◆ pressure
◆ qw
◆ seconds
◆ sections_per_file
◆ skip_chars
character*(3) skip_chars
◆ tempc
◆ thermal_profile_dim
◆ theta
◆ ti_density
◆ ti_eps
◆ ti_nc
◆ ti_pressure
◆ ti_qw
◆ ti_tempc
◆ ti_theta
◆ ti_tke
◆ ti_u
◆ ti_v
◆ ti_zd
◆ ti_zt
◆ times
derived data
◆ times_sequence
◆ tke
◆ u
◆ v
◆ vertical_influence_radius
◆ xpos
Positions.
◆ years
Time variables
◆ ypos
◆ zd
◆ zt
