Include dependency graph for cs_wall_distance.h:Go to the source code of this file.
| struct | cs_wall_distance_options_t |
| void | cs_wall_distance (int iterns) |
| Compute distance to wall by solving a 3d diffusion equation. Solve. More... | |
| void | cs_wall_distance_yplus (cs_real_t visvdr[]) |
| Compute the dimensionless distance to the wall solving a steady transport equation. More... | |
| void | cs_wall_distance_geometric (void) |
| Compute distance to wall by a brute force geometric approach (serial only) More... | |
| cs_wall_distance_options_t * | cs_get_glob_wall_distance_options (void) |
| Provide read/write access to cs_glob_wall_distance. More... | |
| const cs_wall_distance_options_t * | cs_glob_wall_distance_options |
| cs_wall_distance_options_t * cs_get_glob_wall_distance_options | ( | void | ) |
| void cs_wall_distance | ( | int | iterns | ) |
with:
| [in] | iterns | iteration number on Navier-Stokes equations |
| void cs_wall_distance_geometric | ( | void | ) |
| void cs_wall_distance_yplus | ( | cs_real_t | visvdr[] | ) |
This function solves the following steady pure convection equation on
where the vector field
is defined by:
The boundary conditions on
read:
Then the dimensionless distance is deduced by:
Then, Imposition of an amortization of Van Driest type for the LES.
is absorbed by
where
is set at 26.
| [in] | visvdr | dynamic viscosity in edge cells after driest velocity amortization |
extern |
