8.3
cs_timer_stats.h
1#ifndef __CS_TIMER_STATS_H__
2#define __CS_TIMER_STATS_H__
5 * Application timer statistics and graphs
31 * Local headers
34#include "cs_defs.h"
35#include "cs_timer.h"
36#include "cs_time_plot.h"
43 * Public types
45
47 * Public function prototypes
49
50/*----------------------------------------------------------------------------*/
58/*----------------------------------------------------------------------------*/
59
60void
62
63/*----------------------------------------------------------------------------*/
67/*----------------------------------------------------------------------------*/
68
69void
71
72/*----------------------------------------------------------------------------*/
81/*----------------------------------------------------------------------------*/
82
83void
85
86/*----------------------------------------------------------------------------*/
100/*----------------------------------------------------------------------------*/
101
102void
104 int frequency,
105 int n_buffer_steps,
106 double flush_wtime);
107
108/*----------------------------------------------------------------------------*/
112/*----------------------------------------------------------------------------*/
113
114void
116
117/*----------------------------------------------------------------------------*/
127/*----------------------------------------------------------------------------*/
128
129int
130cs_timer_stats_create(const char *parent_name,
131 const char *name,
132 const char *label);
133
134/*----------------------------------------------------------------------------*/
144/*----------------------------------------------------------------------------*/
145
146int
147cs_timer_stats_id_by_name(const char *name);
148
149/*----------------------------------------------------------------------------*/
162/*----------------------------------------------------------------------------*/
163
164void
166 int plot);
167
168/*----------------------------------------------------------------------------*/
176/*----------------------------------------------------------------------------*/
177
178int
180
181/*----------------------------------------------------------------------------*/
193/*----------------------------------------------------------------------------*/
194
195void
197
198/*----------------------------------------------------------------------------*/
206/*----------------------------------------------------------------------------*/
207
208void
209cs_timer_stats_stop(int id);
210
211/*----------------------------------------------------------------------------*/
222
223int
225
226/*----------------------------------------------------------------------------*/
237/*----------------------------------------------------------------------------*/
238
239void
241 const cs_timer_t *t0,
242 const cs_timer_t *t1);
243
244/*----------------------------------------------------------------------------*/
252/*----------------------------------------------------------------------------*/
253
254void
256
257/*----------------------------------------------------------------------------*/
258
260
261#endif /* __CS_TIMER_STATS_H__ */
Definition: cs_defs.h:542
Definition: cs_defs.h:543
cs_time_plot_format_t
Definition: cs_time_plot.h:56
int cs_timer_stats_id_by_name(const char *name)
Return the id of a defined statistic based on its name.
Definition: cs_timer_stats.cpp:557
void cs_timer_stats_initialize(void)
Initialize timer statistics handling.
Definition: cs_timer_stats.cpp:297
int cs_timer_stats_is_active(int id)
indicate if a timer for a given statistic is currently active.
Definition: cs_timer_stats.cpp:598
void cs_timer_stats_stop(int id)
Stop a timer for a given statistic.
Definition: cs_timer_stats.cpp:669
void cs_timer_stats_increment_time_step(void)
Increment time step for timer statistics.
Definition: cs_timer_stats.cpp:406
void cs_timer_stats_define_defaults(void)
Define default timer statistics.
Definition: cs_timer_stats.cpp:797
void cs_timer_stats_start(int id)
Start a timer for a given statistic.
Definition: cs_timer_stats.cpp:624
void cs_timer_stats_set_plot(int id, int plot)
Enable or disable plotting for a timer statistic.
Definition: cs_timer_stats.cpp:578
int cs_timer_stats_create(const char *parent_name, const char *name, const char *label)
Create a timer statistics structure.
Definition: cs_timer_stats.cpp:456
void cs_timer_stats_set_start_time(int time_id)
Set a start time for time stats.
Definition: cs_timer_stats.cpp:362
void cs_timer_stats_set_plot_options(cs_time_plot_format_t format, int frequency, int n_buffer_steps, double flush_wtime)
Set global timer statistics plot options.
Definition: cs_timer_stats.cpp:387
void cs_timer_stats_add_diff(int id, const cs_timer_t *t0, const cs_timer_t *t1)
Add a timing range to an inactive timer.
Definition: cs_timer_stats.cpp:774
void cs_timer_stats_finalize(void)
Finalize timer statistics handling.
Definition: cs_timer_stats.cpp:325
int cs_timer_stats_switch(int id)
Start a timer for a given statistic, stopping previous timers of the same type which are not a parent...
Definition: cs_timer_stats.cpp:707
real(c_double), pointer, save t0
reference temperature.
Definition: cstphy.f90:217
char * label
Definition: keywords.h:58
Definition: cs_timer.h:46
