8.3
cs_thermal_model.h File Reference
+ Include dependency graph for cs_thermal_model.h:
Data Structures
struct  cs_thermal_model_t
 Thermal model descriptor. More...
Enumerations
enum  cs_thermal_model_variable_t {
  CS_THERMAL_MODEL_INIT = -999 , CS_THERMAL_MODEL_NONE = 0 , CS_THERMAL_MODEL_TEMPERATURE , CS_THERMAL_MODEL_ENTHALPY ,
  CS_THERMAL_MODEL_TOTAL_ENERGY , CS_THERMAL_MODEL_INTERNAL_ENERGY , CS_THERMAL_MODEL_N_TYPES
enum  cs_temperature_scale_t { CS_TEMPERATURE_SCALE_NONE = 0 , CS_TEMPERATURE_SCALE_KELVIN = 1 , CS_TEMPERATURE_SCALE_CELSIUS = 2 }
cs_thermal_model_tcs_get_glob_thermal_model (void)
cs_field_tcs_thermal_model_field (void)
void cs_thermal_model_log_setup (void)
void cs_thermal_model_init (void)
 Initialize thermal variables if needed. More...
void cs_thermal_model_c_square (const cs_real_t cp[], const cs_real_t temp[], const cs_real_t pres[], const cs_real_t fracv[], const cs_real_t fracm[], const cs_real_t frace[], cs_real_t dc2[])
 Compute the inverse of the square of sound velocity multiplied by gamma. More...
CS_F_HOST_DEVICE cs_real_t cs_thermal_model_demdt (const cs_real_t pres, const cs_real_t temp, const cs_real_t yw, const cs_real_t rvsra, const cs_real_t cva, const cs_real_t cvv, const cs_real_t cpl, const cs_real_t l00)
 Compute the derivative of the internal energy related to the temperature at constant pressure. More...
CS_F_HOST_DEVICE cs_real_t cs_thermal_model_demdt_ecsnt (const cs_real_t pres, const cs_real_t temp, const cs_real_t yw, const cs_real_t rvsra, const cs_real_t cva, const cs_real_t cvv, const cs_real_t cpl, const cs_real_t l00)
 Compute the derivative of the internal energy related to the temperature at constant internal energy. More...
void cs_thermal_model_kinetic_st_prepare (const cs_real_t imasfl[], const cs_real_t bmasfl[], const cs_real_t vela[][3], const cs_real_t vel[][3])
 First pass to compute the contribution of the kinetic energy based source term from the prediction step. More...
void cs_thermal_model_kinetic_st_finalize (const cs_real_t cromk1[], const cs_real_t cromk[])
 Finalize the computation of the kinetic energy based source term. More...
void cs_thermal_model_add_kst (cs_real_t smbrs[])
 Add the kinetic source term if needed. More...
void cs_thermal_model_cflp (const cs_real_t croma[], const cs_real_t trav2[][3], const cs_real_t cvara_pr[], const cs_real_t imasfl[], cs_real_t cflp[])
 Compute the CFL number related to the pressure equation. More...
void cs_thermal_model_cflt (const cs_real_t croma[], const cs_real_t tempk[], const cs_real_t tempka[], const cs_real_t xcvv[], const cs_real_t vel[][3], const cs_real_t i_massflux[], const cs_real_t b_massflux[], cs_real_t cflt[])
 Compute the CFL number related to the thermal equation. More...
void cs_thermal_model_cv (cs_real_t *xcvv)
 Compute the isochoric heat capacity. More...
void cs_thermal_model_dissipation (const cs_real_t vistot[], const cs_real_t gradv[][3][3], cs_real_t smbrs[])
 Compute and add the dissipation term of the thermal equation to its right hand side. More...
void cs_thermal_model_newton_t (int method, const cs_real_t *pk1, const cs_real_t th_scal[], const cs_real_t cvar_pr[], const cs_real_t cvara_pr[], const cs_real_t yw[], cs_real_t yv[], cs_real_t temp[])
 Perform the Newton method to compute the temperature from the internal energy. More...
void cs_thermal_model_pdivu (cs_real_t smbrs[])
 Add the term pdivu to the thermal equation rhs. More...
const cs_thermal_model_tcs_glob_thermal_model
◆ cs_temperature_scale_t
Enumerator
◆ cs_thermal_model_variable_t
Enumerator
◆ cs_get_glob_thermal_model()
cs_thermal_model_t * cs_get_glob_thermal_model ( void  )
◆ cs_thermal_model_add_kst()
void cs_thermal_model_add_kst ( cs_real_t  smbrs[])
[in,out]smbrsRHS of the thermal equation
◆ cs_thermal_model_c_square()
void cs_thermal_model_c_square ( const cs_real_t  cp[],
cs_real_t  dc2[]
[in]cparray of isobaric specific heat values for dry air
[in]temparray of temperature values
[in]presarray of pressure values
[in,out]fracvarray of volume fraction values
[in,out]fracmarray of mass fraction values
[in,out]fracearray of energy fraction values
[out]dc2array of the values of the square of sound velocity
◆ cs_thermal_model_cflp()
void cs_thermal_model_cflp ( const cs_real_t  croma[],
cs_real_t  cflp[]
[in]cromadensity values at the last time iteration
[in]trav2predicted velocity
[in]cvara_prpressure values at the last time iteration
[in]imasflface mass fluxes
[in,out]cflpCFL condition related to the pressure equation
[in]i_massfluxface mass fluxes
◆ cs_thermal_model_cflt()
void cs_thermal_model_cflt ( const cs_real_t  croma[],
cs_real_t  cflt[]
[in]cromaarray of density values at the last time iteration
[in]tempkarray of the temperature
[in]tempkaarray of the temperature at the previous time step
[in]xcvvarray of the isochoric heat capacity
[in]velarray of the velocity
[in]i_massfluxarray of the inner faces mass fluxes
[in]b_massfluxarray of the boundary faces mass fluxes
[in]cfltCFL condition related to thermal equation
◆ cs_thermal_model_cv()
void cs_thermal_model_cv ( cs_real_t xcvv)
[in]xcvvisobaric heat capacity
◆ cs_thermal_model_demdt()
CS_F_HOST_DEVICE cs_real_t cs_thermal_model_demdt ( const cs_real_t  pres,
const cs_real_t  yw,
const cs_real_t  l00
[in]temparray of temperature values (in Kelvin)
[in]ywarray of the total water mass fraction
[in]rvsraratio gas constant h2o / dry air
[in]cvadifference between heat capacity of the dry air and r_pg_const
[in]cvvdifference beteween heat capacity of the water in its gaseous phase and r_v_cnst
[in]cplheat capacity of the water in its liquid phase
[in]l00water latent heat
◆ cs_thermal_model_demdt_ecsnt()
CS_F_HOST_DEVICE cs_real_t cs_thermal_model_demdt_ecsnt ( const cs_real_t  pres,
const cs_real_t  yw,
const cs_real_t  l00
◆ cs_thermal_model_dissipation()
void cs_thermal_model_dissipation ( const cs_real_t  vistot[],
cs_real_t  smbrs[]
[in]vistotarray for the total viscosity
[in]gradvtensor for the velocity gradient
[in,out]smbrsarray of equation right hand side
◆ cs_thermal_model_field()
cs_field_t * cs_thermal_model_field ( void  )
◆ cs_thermal_model_init()
void cs_thermal_model_init ( void  )
◆ cs_thermal_model_kinetic_st_finalize()
void cs_thermal_model_kinetic_st_finalize ( const cs_real_t  cromk1[],
[in]cromk1density values at time n+1/2,k-1
[in]cromkdensity values at time n+1/2,k
◆ cs_thermal_model_kinetic_st_prepare()
void cs_thermal_model_kinetic_st_prepare ( const cs_real_t  i_massflux[],
[in]imasflinner mass flux used in the momentum equation
[in]bmasflboundary mass flux used in the momentum equation
[in]velavelocity at previous time step
[in]velvelocity at iteration k
[in]i_massfluxinner mass flux used in the momentum equation
[in]b_massfluxboundary mass flux used in the momentum equation
◆ cs_thermal_model_log_setup()
void cs_thermal_model_log_setup ( void  )
◆ cs_thermal_model_newton_t()
void cs_thermal_model_newton_t ( int  method,
const cs_real_t pk1,
cs_real_t  yv[],
cs_real_t  temp[]
[in]methodmethod used to compute the temperature
[in]th_scalinternal energy values
[in]pk1pressure values at the last inner iteration
[in]cvar_prpressure values
[in]ywtotal water mass fraction
[in,out]yvvapor of water mass fraction
[in,out]temptemperature values
◆ cs_thermal_model_pdivu()
void cs_thermal_model_pdivu ( cs_real_t  smbrs[])
[in,out]smbrsarray of the right hand side
◆ cs_glob_thermal_model
const cs_thermal_model_t* cs_glob_thermal_model
extern
