#include "cs_defs.h"#include <float.h>#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <mpi.h>#include "cs_1d_wall_thermal.h"#include "cs_1d_wall_thermal_check.h"#include "cs_ale.h"#include "cs_array.h"#include "cs_at_data_assim.h"#include "cs_atmo.h"#include "cs_boundary_conditions.h"#include "cs_boundary_conditions_set_coeffs.h"#include "cs_cdo_main.h"#include "cs_cf_boundary_conditions.h"#include "cs_control.h"#include "cs_coupling.h"#include "cs_domain_op.h"#include "cs_domain_setup.h"#include "cs_field_pointer.h"#include "cs_gas_mix.h"#include "cs_gui.h"#include "cs_ibm.h"#include "cs_initialize_fields.h"#include "cs_lagr.h"#include "cs_lagr_lec.h"#include "cs_les_balance.h"#include "cs_les_inflow.h"#include "cs_log_iteration.h"#include "cs_mesh.h"#include "cs_mesh_save.h"#include "cs_mobile_structures.h"#include "cs_parall.h"#include "cs_parameters.h"#include "cs_physical_model.h"#include "cs_physical_properties_default.h"#include "cs_porosity_from_scan.h"#include "cs_porous_model.h"#include "cs_post.h"#include "cs_post_default.h"#include "cs_prototypes.h"#include "cs_rad_transfer.h"#include "cs_rad_transfer_restart.h"#include "cs_resource.h"#include "cs_restart.h"#include "cs_restart_default.h"#include "cs_restart_main_and_aux.h"#include "cs_restart_map.h"#include "cs_runaway_check.h"#include "cs_sat_coupling.h"#include "cs_solve_all.h"#include "cs_time_moment.h"#include "cs_time_step.h"#include "cs_timer_stats.h"#include "cs_turbomachinery.h"#include "cs_turbulence_bc.h"#include "cs_turbulence_htles.h"#include "cs_turbulence_model.h"#include "cs_vof.h"#include "cs_volume_mass_injection.h"#include "cs_wall_condensation.h"#include "cs_wall_condensation_1d_thermal.h"#include "cs_time_stepping.h"Functions | |
| void | cs_f_boundary_conditions_init (void) |
| void | cs_f_init_chemistry_reacnum (void) |
| void | cs_f_combustion_models_boundary_conditions_map (void) |
| void | cs_f_atmsol (void) |
| void | cs_f_user_extra_operations_wrapper (cs_real_t dt[]) |
| void | cs_f_finalize_meteo (void) |
| void | cs_f_finalize_imbrication (void) |
| void | cs_f_finalize_chemistry (void) |
| void | cs_f_finalize_steady_laminar_flamelet_library (void) |
| void | cs_f_pp_models_bc_map (void) |
| void | cs_time_stepping (void) |
| Main time loop. More... | |
| void | cs_time_stepping_write_checkpoint (bool checkpoint_mesh) |
| Output a checkpoint. More... | |
Main time loop.
| void cs_f_atmsol | ( | void | ) |
| void cs_f_boundary_conditions_init | ( | void | ) |
| void cs_f_combustion_models_boundary_conditions_map | ( | void | ) |
| void cs_f_finalize_chemistry | ( | void | ) |
| void cs_f_finalize_imbrication | ( | void | ) |
| void cs_f_finalize_meteo | ( | void | ) |
| void cs_f_finalize_steady_laminar_flamelet_library | ( | void | ) |
| void cs_f_init_chemistry_reacnum | ( | void | ) |
| void cs_f_pp_models_bc_map | ( | void | ) |
| void cs_f_user_extra_operations_wrapper | ( | cs_real_t | dt[] | ) |
| void cs_time_stepping | ( | void | ) |
Main time loop.
| void cs_time_stepping_write_checkpoint | ( | bool | checkpoint_mesh | ) |
If needed, the mesh is also output in the checkpoint directory, exect if this function is called for checkpoint serialized in memory (which is a special case for FMI exchange).
| [in] | checkpoint_mesh | also save mesh in checkpoint directory |
