1#ifndef __CS_TURBULENCE_BC_H__
2#define __CS_TURBULENCE_BC_H__
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
Definition: cs_defs.h:335
@ k
Definition: cs_field_pointer.h:72
@ mu
Definition: cs_field_pointer.h:105
@ eps
Definition: cs_field_pointer.h:73
@ rho
Definition: cs_field_pointer.h:99
@ rij
Definition: cs_field_pointer.h:75
void cs_turbulence_bc_ke_turb_intensity(double uref2, double t_intensity, double dh, double *k, double *eps)
Calculation of and from a diameter , a turbulent intensity and the reference velocity for a circu...
Definition: cs_turbulence_bc.cpp:728
Definition: cs_turbulence_bc.cpp:772
void cs_turbulence_bc_set_uninit_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh)
Set inlet boundary condition values for turbulence variables based on a diameter ,...
Definition: cs_turbulence_bc.cpp:985
void cs_turbulence_bc_rij_transform(int is_sym, cs_real_t p_lg[3][3], cs_real_t alpha[6][6])
Compute matrix used in the computation of the Reynolds stress tensor boundary conditions.
Definition: cs_turbulence_bc.cpp:1082
void cs_turbulence_bc_inlet_k_eps(cs_lnum_t face_id, double k, double eps)
Definition: cs_turbulence_bc.cpp:824
void cs_turbulence_bc_free_pointers(void)
Free memory allocations for turbulence boundary condition pointers.
Definition: cs_turbulence_bc.cpp:642
void cs_turbulence_bc_set_uninit_inlet(cs_lnum_t face_num, double k, double rij[], double eps)
void cs_turbulence_bc_set_uninit_inlet_k_eps(cs_lnum_t face_id, double k, double eps, double vel_dir[], double shear_dir[])
Set inlet boundary condition values for turbulence variables based on given k and epsilon values only...
Definition: cs_turbulence_bc.cpp:1012
void cs_turbulence_bc_ke_hyd_diam(double uref2, double dh, double rho, double mu, double *ustar2, double *k, double *eps)
Calculation of , and from a diameter and the reference velocity for a circular duct flow with smo...
Definition: cs_turbulence_bc.cpp:696
void cs_turbulence_bc_init_pointers(void)
Initialize turbulence model boundary condition pointers.
Definition: cs_turbulence_bc.cpp:551
void cs_turbulence_bc_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh)
Definition: cs_turbulence_bc.cpp:800
void cs_turbulence_bc_set_hmg_neumann(cs_lnum_t face_id)
Assign homogeneous Neumann turbulent boundary conditions to a given face.
Definition: cs_turbulence_bc.cpp:841
void cs_turbulence_bc_set_uninit_inlet_hyd_diam(cs_lnum_t face_id, double vel_dir[], double shear_dir[], double uref2, double dh, double rho, double mu)
Definition: cs_turbulence_bc.cpp:952
real(c_double), dimension(:), pointer, save dh
hydraulic diameter
Definition: ppincl.f90:322
