8.3
cs_vof.h
1#ifndef CS_VOF_H
2#define CS_VOF_H
5 * Functions associated to VOF model
35 * Local headers
38#include "cs_defs.h"
39#include "cs_mesh.h"
40#include "cs_mesh_quantities.h"
42/*----------------------------------------------------------------------------*/
45
46/*=============================================================================
47 * Macro definitions
49
59#define CS_VOF_ENABLED (1 << 0)
60
62#define CS_VOF_FREE_SURFACE (1 << 1)
63
65#define CS_VOF_MERKLE_MASS_TRANSFER (1 << 2)
66
72/*============================================================================
73 * Type definitions
74 *============================================================================*/
75
76/* VOF model parameters */
77/*----------------------*/
78
79typedef struct {
80
81 unsigned vof_model; /* VoF model (sum of masks defining Volume of
82 Fluid model and submodels */
83
84 double rho1; /* density */
85
86 double rho2;
87
88 double mu1; /* viscosity */
89
90 double mu2;
91
92 double sigma_s; /* surface tension */
93
94 int idrift; /* drift velocity model */
95
96 double cdrift; /* C_gamma constante (drift flux factor)*/
97
98 double kdrift;
99
101
102/* Cavitation parameters */
103/*-----------------------*/
104
105typedef struct {
106
107 cs_real_t presat; /* reference saturation pressure */
108 cs_real_t uinf; /* reference velocity */
109 cs_real_t linf; /* reference length scale */
110 cs_real_t cdest; /* constant of condensation model (Merkle) */
111 cs_real_t cprod; /* constant of vaporization model (Merkle) */
112 int icvevm; /* eddy-viscosity correction indicator */
113 cs_real_t mcav; /* eddy-viscosity correction cstt (Reboud) */
114 int itscvi; /* eddy-viscosity correction indicator */
115
117
118/*=============================================================================
119 * Global variables
120 *============================================================================*/
121
122/* pointer to VOF model parameters structure */
123
125
126/* pointer to cavitation model parameters structure */
127
129
130/*============================================================================
131 * Public function prototypes
132 *============================================================================*/
133
134/*----------------------------------------------------------------------------
135 *!
136 * \brief Provide write access to VOF structure.
137 */
138/*----------------------------------------------------------------------------*/
139
142
143/*----------------------------------------------------------------------------*/
144/*
145 * \brief Create VoF fields
146 */
147/*----------------------------------------------------------------------------*/
148
149void
151
152/*----------------------------------------------------------------------------*/
156/*----------------------------------------------------------------------------*/
157
158void
159cs_vof_log_setup(void);
160
161/*----------------------------------------------------------------------------*/
180/*----------------------------------------------------------------------------*/
181
182void
184
185/*----------------------------------------------------------------------------*/
217/*----------------------------------------------------------------------------*/
218
219void
221
222/*----------------------------------------------------------------------------*/
231/*----------------------------------------------------------------------------*/
232
233void
235 const cs_mesh_quantities_t *mq,
236 cs_real_3_t stf[]);
237
238/*----------------------------------------------------------------------------*/
251/*----------------------------------------------------------------------------*/
252
253void
255 const cs_mesh_quantities_t *mq);
256
257/*----------------------------------------------------------------------------*/
295/*----------------------------------------------------------------------------*/
296
297void
299 const cs_mesh_quantities_t *mq);
300
301/*----------------------------------------------------------------------------*/
333/*----------------------------------------------------------------------------*/
334
335void
337 int nswrgp,
338 int imligp,
339 int iwarnp,
340 cs_real_t epsrgp,
341 cs_real_t climgp,
342 cs_real_t *pvar,
343 const cs_real_t *pvara,
344 cs_real_t *rhs);
345
346/*----------------------------------------------------------------------------*/
347/*
348 * \param[in] iterns Navier-Stokes iteration number
349 */
350/*----------------------------------------------------------------------------*/
351
352void
354
355/*----------------------------------------------------------------------------
356 *!
357 * \brief Provide write access to cavitation parameters structure.
358 */
359/*----------------------------------------------------------------------------*/
360
363
364/*----------------------------------------------------------------------------*/
365/*
366 * \brief Compute the vaporization source term
367 * \f$ \Gamma_V \left(\alpha, p\right) = m^+ + m^- \f$ using the
368 * Merkle model:
369 *
370 * \f[
371 * m^+ = -\dfrac{C_{prod} \rho_l \min \left( p-p_V,0 \right)\alpha(1-\alpha)}
372 * {0.5\rho_lu_\infty^2t_\infty},
373 * \f]
374 * \f[
375 * m^- = -\dfrac{C_{dest} \rho_v \max \left( p-p_V,0 \right)\alpha(1-\alpha)}
376 * {0.5\rho_lu_\infty^2t_\infty},
377 * \f]
378 * with \f$ C_{prod}, C_{dest} \f$ empirical constants,
379 * \f$ t_\infty=l_\infty/u_\infty \f$ a reference time scale and \f$p_V\f$
380 * the reference saturation pressure.
381 * \f$ l_\infty \f$, \f$ u_\infty \f$ and \f$p_V\f$ may be provided by
382 * the user (user function).
383 *
384 * Note that the r.h.s. of the void fraction transport equation is
385 * \f$ \Gamma_V/\rho_v \f$.
386 *
387 * \param[in] pressure Pressure array
388 * \param[in] voidf Void fraction array
389 */
390/*----------------------------------------------------------------------------*/
391
392void
394 const cs_real_t voidf[]);
395
396/*----------------------------------------------------------------------------*/
397
399
400#endif /* CS_VOF_H */
Definition: cs_defs.h:542
Definition: cs_defs.h:342
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
Definition: cs_defs.h:543
void cs_vof_deshpande_drift_flux(const cs_mesh_t *m, const cs_mesh_quantities_t *mq)
Compute the flux of the drift velocity , by using the flux of the standard velocity following the ap...
Definition: cs_vof.cpp:1256
void cs_vof_surface_tension(const cs_mesh_t *m, const cs_mesh_quantities_t *mq, cs_real_3_t stf[])
Compute the surface tension momentum source term following the CSF model of Brackbill et al....
Definition: cs_vof.cpp:1032
cs_cavitation_parameters_t * cs_get_glob_cavitation_parameters(void)
Definition: cs_vof.cpp:1945
void cs_vof_drift_term(int imrgra, int nswrgp, int imligp, int iwarnp, cs_real_t epsrgp, cs_real_t climgp, cs_real_t *pvar, const cs_real_t *pvara, cs_real_t *rhs)
Add the explicit part of the convection/diffusion terms of a standard transport equation of a scalar ...
void cs_vof_compute_linear_rho_mu(const cs_mesh_t *m)
Compute the mixture density, mixture dynamic viscosity given fluid volume fractions and the reference...
Definition: cs_vof.cpp:745
void cs_vof_field_create(void)
Create VoF fields.
Definition: cs_vof.cpp:538
void cs_cavitation_compute_source_term(const cs_real_t pressure[], const cs_real_t voidf[])
Compute the vaporization source term using the Merkle model:
Definition: cs_vof.cpp:1979
void cs_vof_log_setup(void)
Log setup of VoF model.
Definition: cs_vof.cpp:652
const cs_vof_parameters_t * cs_glob_vof_parameters
void cs_vof_log_mass_budget(const cs_mesh_t *m, const cs_mesh_quantities_t *mq)
Write in main log the global mixture mass budget:
Definition: cs_vof.cpp:882
const cs_cavitation_parameters_t * cs_glob_cavitation_parameters
void cs_vof_update_phys_prop(const cs_mesh_t *m)
Compute the mixture density, mixture dynamic viscosity and mixture mass flux given the volumetric flu...
Definition: cs_vof.cpp:824
void cs_vof_solve_void_fraction(int iterns)
Solve the void fraction for the Volume of Fluid method (and hence for cavitating flows).
Definition: cs_vof.cpp:1566
cs_vof_parameters_t * cs_get_glob_vof_parameters(void)
Definition: cs_vof.cpp:526
double precision, dimension(:,:,:), allocatable pressure
Definition: atimbr.f90:121
int itscvi
Definition: cs_vof.h:114
cs_real_t cprod
Definition: cs_vof.h:111
cs_real_t presat
Definition: cs_vof.h:107
cs_real_t uinf
Definition: cs_vof.h:108
cs_real_t cdest
Definition: cs_vof.h:110
cs_real_t linf
Definition: cs_vof.h:109
cs_real_t mcav
Definition: cs_vof.h:113
int icvevm
Definition: cs_vof.h:112
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:92
double cdrift
Definition: cs_vof.h:96
double rho2
Definition: cs_vof.h:86
unsigned vof_model
Definition: cs_vof.h:81
double mu2
Definition: cs_vof.h:90
double mu1
Definition: cs_vof.h:88
int idrift
Definition: cs_vof.h:94
double sigma_s
Definition: cs_vof.h:92
double kdrift
Definition: cs_vof.h:98
double rho1
Definition: cs_vof.h:84
Cavitation model parameters.
Definition: cs_vof.h:105
Definition: cs_mesh.h:85
VOF model parameters. Void fraction variable tracks fluid 2.
Definition: cs_vof.h:79
