Collaboration diagram for Mixture properties:Data Structures | |
| struct | cs_vof_parameters_t |
| VOF model parameters. Void fraction variable tracks fluid 2. More... | |
| unsigned | vof_model |
| double | rho1 |
| double | rho2 |
| double | mu1 |
| double | mu2 |
| double | sigma_s |
| int | idrift |
| double | cdrift |
| double | kdrift |
| cdrift |
Flux factor parameter. In case of drift flux, factor of the local flux compared to the global max flux.
| idrift |
drift velocity model
| kdrift |
Turbulent like diffusion effect (m2/s). In case of drift velocity, factor of a volume fraction gradient
| mu1 |
reference molecular viscosity of fluid 1 (kg/(m s))
| mu2 |
reference molecular viscosity of fluid 2 (kg/(m s))
| rho1 |
reference density of fluid 1 (kg/m3). By convention, liquid phase for cavitation model.
| rho2 |
reference density of fluid 2 (kg/m3). By convention, gas phase for cavitation model.
| sigma_s |
reference surface tension (N/m)
| vof_model |
Volume of Fluid model - sum of masks defining VoF model and submodels. See defined masks in Masks used to specify Volume of Fluid models.
