void cs_ale_log_setup(void)
Definition: cs_ale.cpp:1678
void cs_ale_activate(void)
Activate the mesh velocity solving with CDO.
Definition: cs_ale.cpp:1506
void cs_ale_finalize_setup(cs_domain_t *domain)
Finalize the setup stage for the equation of the mesh velocity.
Definition: cs_ale.cpp:1821
int cs_glob_ale_n_ini_f
Definition: cs_ale.cpp:94
void cs_ale_update_mesh(int itrale)
Update mesh in the ALE framework.
Definition: cs_ale.cpp:1380
void cs_ale_update_bcs(int *ale_bc_type, cs_real_3_t *b_fluid_vel)
Update ALE BCs for required for the fluid.
Definition: cs_ale.cpp:1466
cs_ale_data_t * cs_glob_ale_data
Definition: cs_ale.cpp:91
void cs_ale_add_property_fields(void)
Add "property" fields dedicated to the ALE model.
Definition: cs_ale.cpp:1563
void cs_ale_destroy_all(void)
Free the main structure related to the ALE mesh velocity solving.
Definition: cs_ale.cpp:1844
cs_ale_type_t cs_glob_ale
Definition: cs_ale.cpp:89
void cs_ale_restart_write(cs_restart_t *r)
Write ALE data from restart file.
Definition: cs_ale.cpp:1930
void cs_ale_init_setup(cs_domain_t *domain)
Setup the equations solving the mesh velocity when CDO is activated.
Definition: cs_ale.cpp:1623
void cs_ale_setup_boundaries(const cs_domain_t *domain)
Setup the equations solving the mesh velocity.
Definition: cs_ale.cpp:1716
void cs_ale_allocate(void)
Allocation of ialtyb and impale for the ALE structure.
Definition: cs_ale.cpp:1109
bool cs_ale_is_activated(void)
Test if mesh velocity solving with CDO is activated.
Definition: cs_ale.cpp:1548
cs_ale_type_t
Definition: cs_ale.h:56
@ CS_ALE_LEGACY
Definition: cs_ale.h:59
@ CS_ALE_NONE
Definition: cs_ale.h:58
@ CS_ALE_CDO
Definition: cs_ale.h:60
void cs_ale_restart_read(cs_restart_t *r)
Read ALE data from restart file.
Definition: cs_ale.cpp:1869
void cs_ale_solve_mesh_velocity(int iterns)
Solve a Poisson equation on the mesh velocity in ALE framework.
Definition: cs_ale.cpp:1487
void cs_ale_update_mesh_quantities(cs_real_t *min_vol, cs_real_t *max_vol, cs_real_t *tot_vol)
Compute cell and face centers of gravity, cell volumes and update bad cells.
Definition: cs_ale.cpp:1139
void cs_ale_project_displacement(const int ale_bc_type[], const cs_real_3_t *meshv, const cs_real_33_t gradm[], const cs_real_3_t *claale, const cs_real_33_t *clbale, const cs_real_t *dt, cs_real_3_t *disp_proj)
Project the displacement on mesh vertices (solved on cell center).
Definition: cs_ale.cpp:1172
int cs_glob_ale_need_init
Definition: cs_ale.cpp:97
Definition: cs_defs.h:542
Definition: cs_defs.h:342
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
Definition: cs_defs.h:543
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:368
@ dt
Definition: cs_restart.h:95
int * impale
Definition: cs_ale.h:68
int * bc_type
Definition: cs_ale.h:69
Definition: cs_domain.h:129
