1#ifndef __CS_RESTART_H__
2#define __CS_RESTART_H__
52#define CS_RESTART_INTERVAL_NONE -2
53#define CS_RESTART_INTERVAL_ONLY_AT_END -1
54#define CS_RESTART_INTERVAL_DEFAULT 0
58#define CS_RESTART_SUCCESS 0
59#define CS_RESTART_ERR_FILE_NUM -1
60#define CS_RESTART_ERR_LOCATION -2
61#define CS_RESTART_ERR_VAL_TYPE -3
62#define CS_RESTART_ERR_N_VALS -4
63#define CS_RESTART_ERR_MODE -5
64#define CS_RESTART_ERR_EXISTS -6
65#define CS_RESTART_ERR_NO_MAP -7
122 const char *sec_name,
152 const char *sec_name,
180 const char *sec_name,
213 double *wt_interval);
449 const char *location_name,
605 const char *sec_name,
628 const char *sec_name,
649 const char *sec_name,
690 int particles_location_id,
719 bool number_by_coords,
750 const char *sec_name,
775 const char *sec_name,
801 const char *sec_name,
802 const char *old_name,
831 const char *sec_name,
832 const char *old_name_x,
833 const char *old_name_y,
834 const char *old_name_z,
864 const char *sec_name,
865 const char *old_name_xx,
866 const char *old_name_yy,
867 const char *old_name_zz,
868 const char *old_name_xy,
869 const char *old_name_yz,
870 const char *old_name_xz,
900 const char *sec_name,
901 const char *old_name_xx,
902 const char *old_name_yy,
903 const char *old_name_zz,
904 const char *old_name_xy,
905 const char *old_name_yz,
906 const char *old_name_xz,
Definition: cs_defs.h:542
Definition: cs_defs.h:342
cs_real_t cs_real_66_t[6][6]
6x6 matrix of floating-point values
Definition: cs_defs.h:369
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
uint64_t cs_gnum_t
global mesh entity number
Definition: cs_defs.h:325
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:361
Definition: cs_defs.h:543
Definition: cs_defs.h:335
int cs_restart_is_from_ncfd(void)
Returns if restart is done from a NCFD checkpoint file.
Definition: cs_restart.cpp:4164
cs_restart_mode_t
Definition: cs_restart.h:74
@ CS_RESTART_MODE_WRITE
Definition: cs_restart.h:77
@ CS_RESTART_MODE_READ
Definition: cs_restart.h:76
void cs_checkpoint_set_to_memory_serialized(bool status)
Indicate checkpoint will be done to serialized data in memory.
Definition: cs_restart.cpp:2116
cs_restart_val_type_t
Definition: cs_restart.h:83
@ CS_TYPE_int
Definition: cs_restart.h:85
@ CS_TYPE_cs_gnum_t
Definition: cs_restart.h:86
@ CS_TYPE_cs_real_t
Definition: cs_restart.h:87
@ CS_TYPE_char
Definition: cs_restart.h:84
int cs_restart_read_real_6_t_compat(cs_restart_t *restart, const char *sec_name, const char *old_name_xx, const char *old_name_yy, const char *old_name_zz, const char *old_name_xy, const char *old_name_yz, const char *old_name_xz, int location_id, cs_real_6_t *val)
Read a cs_real_6_t tensor section from a restart file, when that section may have used a different na...
Definition: cs_restart.cpp:3806
bool cs_restart_checkpoint_required(const cs_time_step_t *ts)
Check if checkpointing is recommended at a given time.
Definition: cs_restart.cpp:1929
cs_lnum_t cs_restart_get_n_location_elts(const cs_restart_t *restart, int location_id)
Return local number of elements associated with a given restart location.
Definition: cs_restart.cpp:2793
void cs_restart_checkpoint_get_intervals(int *nt_interval, double *t_interval, double *wt_interval)
Query checkpoint intervals.
Definition: cs_restart.cpp:1801
const char * cs_restart_get_name(const cs_restart_t *restart)
Return name of restart file.
Definition: cs_restart.cpp:2773
void cs_restart_set_context(void *context)
Associate a context to restart section check operations.
Definition: cs_restart.cpp:2692
int cs_restart_present(void)
Check if we have a restart directory.
Definition: cs_restart.cpp:2168
void cs_restart_check_base_location(const cs_restart_t *restart, bool *match_cell, bool *match_i_face, bool *match_b_face, bool *match_vertex)
Check the locations associated with a restart file.
Definition: cs_restart.cpp:2470
void cs_restart_clear_locations_ref(void)
Clear reference location definitions with a private copy.
Definition: cs_restart.cpp:2665
Definition: cs_restart.h:95
int cs_restart_check_if_restart_from_ncfd(cs_restart_t *r)
Checks if restart is done from a NCFD checkpoint file.
Definition: cs_restart.cpp:4135
int() cs_restart_read_section_t(cs_restart_t *restart, void *context, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, void *val)
Function pointer for modifying behavior when reading a section.
Definition: cs_restart.h:150
int cs_restart_check_section(cs_restart_t *restart, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type)
Check the presence of a given section in a restart file.
Definition: cs_restart.cpp:2854
void cs_restart_checkpoint_set_last_ts(int nt_last)
Define last forced checkpoint time step.
Definition: cs_restart.cpp:1871
void cs_restart_checkpoint_set_next_wt(double wt_next)
Define next forced checkpoint wall-clock time value.
Definition: cs_restart.cpp:1913
void cs_restart_log_setup(void)
Log checkpoint/restart setup.
Definition: cs_restart.cpp:4071
cs_restart_t * cs_restart_create(const char *name, const char *path, cs_restart_mode_t mode)
Initialize a restart file.
Definition: cs_restart.cpp:2198
cs_restart_check_section_t * cs_restart_set_check_section_func(cs_restart_check_section_t *func)
Associate a function to restart section check operations.
Definition: cs_restart.cpp:2710
cs_restart_read_section_t * cs_restart_set_read_section_func(cs_restart_read_section_t *func)
Associate a function and its input to all restart section read operations.
Definition: cs_restart.cpp:2732
void cs_restart_set_n_max_checkpoints(int n_checkpoints)
Set the number of checkpoint files to keep.
Definition: cs_restart.cpp:4188
cs_restart_write_section_t * cs_restart_set_write_section_func(cs_restart_write_section_t *func)
Associate a function and its input to all restart section write operations.
Definition: cs_restart.cpp:2754
int() cs_restart_check_section_t(cs_restart_t *restart, void *context, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type)
Function pointer for modifying behavior when checking a section's presence.
Definition: cs_restart.h:120
int cs_restart_read_real_3_t_compat(cs_restart_t *restart, const char *sec_name, const char *old_name_x, const char *old_name_y, const char *old_name_z, int location_id, cs_real_3_t *val)
Read a cs_real_3_t vector section from a restart file, when that section may have used a different na...
Definition: cs_restart.cpp:3692
void cs_restart_set_from_memory_serialized(size_t nb, void *data)
Indicate restart will be done based on a serialized data in memory.
Definition: cs_restart.cpp:2066
void() cs_restart_write_section_t(cs_restart_t *restart, void *context, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, const void *val)
Function pointer for modifying behavior when writing a section.
Definition: cs_restart.h:178
void cs_restart_checkpoint_set_next_tv(double t_next)
Define next forced checkpoint time value.
Definition: cs_restart.cpp:1899
void cs_restart_write_section(cs_restart_t *restart, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, const void *val)
Write a section to a restart file.
Definition: cs_restart.cpp:2930
int cs_restart_read_particles_info(cs_restart_t *restart, const char *name, cs_lnum_t *n_particles)
Read basic particles information from a restart file.
Definition: cs_restart.cpp:2970
void cs_restart_destroy(cs_restart_t **restart)
Destroy structure associated with a restart file (and close the file).
Definition: cs_restart.cpp:2412
void cs_restart_write_ids(cs_restart_t *restart, const char *sec_name, int location_id, int ref_location_id, cs_lnum_t ref_id_base, const cs_lnum_t *ref_id)
Write a referenced location id section to a restart file.
Definition: cs_restart.cpp:3512
int cs_restart_read_real_66_t_compat(cs_restart_t *restart, const char *sec_name, const char *old_name_xx, const char *old_name_yy, const char *old_name_zz, const char *old_name_xy, const char *old_name_yz, const char *old_name_xz, int location_id, cs_real_66_t *val)
Read a cs_real_66_t tensor section from a restart file, when that section may have used a different n...
Definition: cs_restart.cpp:3948
int cs_restart_read_section_compat(cs_restart_t *restart, const char *sec_name, const char *old_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, void *val)
Read a section from a restart file, when that section may have used a different name in a previous ve...
Definition: cs_restart.cpp:3615
int cs_restart_add_location(cs_restart_t *restart, const char *location_name, cs_gnum_t n_glob_ents, cs_lnum_t n_ents, const cs_gnum_t *ent_global_num)
Add a location definition.
Definition: cs_restart.cpp:2528
int cs_restart_read_particles(cs_restart_t *restart, int particles_location_id, cs_lnum_t *particle_cell_id, cs_real_t *particle_coords)
Definition: cs_restart.cpp:3157
void cs_restart_multiwriters_destroy_all(void)
Destroy the multiwriter structure at the end of the computation.
Definition: cs_restart.cpp:4269
void cs_restart_dump_index(const cs_restart_t *restart)
Print the index associated with a restart file in read mode.
Definition: cs_restart.cpp:2815
int cs_restart_read_section(cs_restart_t *restart, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, void *val)
Read a section from a restart file.
Definition: cs_restart.cpp:2887
void cs_restart_clean_multiwriters_history(void)
Remove all previous checkpoints which are not to be retained.
Definition: cs_restart.cpp:4210
void cs_restart_add_location_ref(const char *location_name, cs_gnum_t n_glob_ents, cs_lnum_t n_ents, const cs_gnum_t *ent_global_num)
Add a reference location definition with a private copy.
Definition: cs_restart.cpp:2623
int cs_restart_write_particles(cs_restart_t *restart, const char *name, bool number_by_coords, cs_lnum_t n_particles, const cs_lnum_t *particle_cell_id, const cs_real_t *particle_coords)
Write basic particles information to a restart file.
Definition: cs_restart.cpp:3274
void cs_restart_checkpoint_set_interval(int nt_interval, double t_interval, double wt_interval)
Define default checkpoint interval.
Definition: cs_restart.cpp:1827
void cs_restart_get_from_memory_serialized(size_t *nb, void **data)
Definition: cs_restart.cpp:2043
void cs_restart_checkpoint_set_mesh_mode(int mode)
Define checkpoint behavior for mesh.
Definition: cs_restart.cpp:1857
int cs_restart_read_ids(cs_restart_t *restart, const char *sec_name, int location_id, int ref_location_id, cs_lnum_t ref_id_base, cs_lnum_t *ref_id)
Read a referenced location id section from a restart file.
Definition: cs_restart.cpp:3409
void cs_restart_checkpoint_done(const cs_time_step_t *ts)
Indicate checkpointing has been done at a given time.
Definition: cs_restart.cpp:2001
void cs_restart_print_stats(void)
Print statistics associated with restart files.
Definition: cs_restart.cpp:4112
void cs_restart_checkpoint_set_next_ts(int nt_next)
Define next forced checkpoint time step.
Definition: cs_restart.cpp:1885
time step descriptor
Definition: cs_time_step.h:64
