◆ cs_get_glob_wall_condensation()
cs_wall_condensation_t * cs_get_glob_wall_condensation |
void |
Provide writable access to _wall_cond structure.
- Returns
- pointer to global wall_cond structure
◆ cs_wall_condensation_compute()
void cs_wall_condensation_compute |
cs_real_t |
total_htc[] | ) |
Compute the wall condensation source terms.
◆ cs_wall_condensation_create()
void cs_wall_condensation_create |
void |
Create the context for wall condensation models.
◆ cs_wall_condensation_free()
void cs_wall_condensation_free |
void |
Free all structures related to wall condensation models.
◆ cs_wall_condensation_initialize()
void cs_wall_condensation_initialize |
void |
Initialize wall condensation models.
This includes building the associated meshes.
◆ cs_wall_condensation_log()
void cs_wall_condensation_log |
void |
Output statistics about wall condensation source terms (for user log)
◆ cs_wall_condensation_reset()
void cs_wall_condensation_reset |
cs_wall_condensation_t * |
wall_cond, |
const int |
n_var |
◆ cs_wall_condensation_set_model()
void cs_wall_condensation_set_model |
cs_wall_cond_natural_conv_model_t |
model | ) |
Set the wall condensation model.
- Parameters
[in] | model | integer corresponding to the desired model |
◆ cs_wall_condensation_set_onoff_state()
void cs_wall_condensation_set_onoff_state |
int |
icondb, |
int |
icondv |
Set the onoff state of wall condensation modeling.
- Parameters
[in] | icondb | integer corresponding to the onoff state (-1: off, 0: on) |
[in] | icondv | integer corresponding to the onoff state with metal structures (-1: off, 0: on) |
◆ cs_wall_condensation_source_terms()
Explicit and implicit sources terms from sources condensation computation.
- Parameters
[in] | f | pointer to field structure |
[in] | xcpp | array of specific heat (Cp) |
[in] | pvara | variable value at time step beginning |
[in,out] | st_exp | explicit source term part linear in the variable |
[in,out] | st_imp | associated value with tsexp to be stored in the matrix |
◆ cs_wall_condensation_volume_exchange_surf_at_cells()
void cs_wall_condensation_volume_exchange_surf_at_cells |
cs_real_t * |
surf | ) |
Return condensing volume structures surface at each cell.
- Parameters
[out] | surf | array of volume structure surfaces at each cell |
