Include dependency graph for cs_notebook.h:Go to the source code of this file.
| void | cs_notebook_load_from_file (void) |
| Initialize the notebook object (based on cs_tree_node_t). More... | |
| int | cs_notebook_parameter_is_present (const char *name, int *editable) |
| Check if a parameter value is present. More... | |
| cs_real_t | cs_notebook_parameter_value_by_name (const char *name) |
| Return a parameter value (real). More... | |
| void | cs_notebook_parameter_set_value (const char *name, cs_real_t val) |
| Set a parameter value (real) for an editable parameter. More... | |
| int | cs_notebook_parameter_get_openturns_status (char *name) |
| Indicate whether the parameter is used for a study with openturns. More... | |
| const char * | cs_notebook_parameter_get_description (char *name) |
| Returns the description of the parameter (GUI defined). More... | |
| int | cs_notebook_parameter_get_id (const char *name) |
| Get id associated with a notebook parameter. More... | |
| void | cs_notebook_get_values (int n, const int ids[], double values[]) |
| Get a group of notebook variable values. More... | |
| void | cs_notebook_set_values (int n, const int ids[], const double values[]) |
| Set a group of notebook variable values. More... | |
| void | cs_notebook_destroy_all (void) |
| Destroy the notebook structure. More... | |
| void | cs_notebook_log_setup (void) |
| Output the notebook info to the setup log. More... | |
| void | cs_notebook_log (void) |
| Print values of editable notebook variables to default log file. More... | |
| int | cs_notebook_nb_var (void) |
| Number of notebook variables. More... | |
| bool | cs_notebook_var_is_editable (int id) |
| Indicate if the notebook parameter is editable. More... | |
| bool | cs_notebook_var_is_read_from_checkpoint (int id) |
| Indicate if the notebook parameter is read at restart. More... | |
| void | cs_notebook_var_change_editable (int id, bool val) |
| Change the editable property of the notebook parameter. More... | |
| const char * | cs_notebook_name_by_id (int id) |
| Get name of a notebook parameter based on its id. More... | |
| void | cs_notebook_uncertain_output (void) |
| Write uncertain values to output file. More... | |
| void cs_notebook_destroy_all | ( | void | ) |
Destroys the structures related to the notebook.
| void cs_notebook_get_values | ( | int | n, |
| const int | ids[], | ||
| double | values[] | ||
| [in] | n | number of notebook variables to query |
| [in] | ids | ids of notebook variables to query (value set to 0 where id < 0) |
| [out] | values | values of notebook variables to query |
| void cs_notebook_load_from_file | ( | void | ) |
| void cs_notebook_log | ( | void | ) |
| void cs_notebook_log_setup | ( | void | ) |
| const char * cs_notebook_name_by_id | ( | int | id | ) |
| [in] | id | Id of the notebook parameter |
| [out] | name | Name of the notebook parameter |
| int cs_notebook_nb_var | ( | void | ) |
| const char * cs_notebook_parameter_get_description | ( | char * | name | ) |
| [in] | name | name of the parameter |
| int cs_notebook_parameter_get_id | ( | const char * | name | ) |
| int cs_notebook_parameter_get_openturns_status | ( | char * | name | ) |
Returns an int flag to indicate whether this paramter is used for an OpenTurns study. -1 : The parameter is not used with OpenTurns 0 : The parameter is used as an input from OpenTurns 1 : The parameter is used as an output to OpenTurns
| int cs_notebook_parameter_is_present | ( | const char * | name, |
| int * | editable | ||
| [out] | editable | 1 if the value is editable, 0 otherwise (optional) |
| void cs_notebook_parameter_set_value | ( | const char * | name, |
| cs_real_t | val | ||
The name used is the same as the one in the GUI.
| [in] | val | value of the parameter |
| cs_real_t cs_notebook_parameter_value_by_name | ( | const char * | name | ) |
| void cs_notebook_set_values | ( | int | n, |
| const double | values[] | ||
| [in] | n | number of notebook variables to set |
| [in] | ids | ids of notebook variables to set (ignored where id < 0) |
| [in] | values | values of notebook variables to set |
| void cs_notebook_uncertain_output | ( | void | ) |
If input and output uncertain variables are provided, output values are written to an output file: cs_uncertain_output.dat Results are ordered in the definition order in the notebook.
| void cs_notebook_var_change_editable | ( | int | id, |
| const bool | val | ||
| [in] | val | flag (bool) indicating if the value is set to editable |
| bool cs_notebook_var_is_editable | ( | const int | id | ) |
Returns a boolean to indicate wheter this parameter is editable
| bool cs_notebook_var_is_read_from_checkpoint | ( | const int | id | ) |
Returns a boolean to indicate wheter this parameter is read at restart
