8.3
cs_block_dist.h
1#ifndef __CS_BLOCK_DIST_H__
2#define __CS_BLOCK_DIST_H__
5 * Definition of a block distribution.
31 * Local headers
34#include "cs_defs.h"
41 * Macro definitions
45 * Type definitions
48/* Information structure for block size and entity range */
49
50typedef struct {
51
52 cs_gnum_t gnum_range[2]; /* Start and past-the-end global numbers
53 associated with local block */
54 int n_ranks; /* Number of active ranks */
55 int rank_step; /* Step between active block ranks
56 (1 in basic case, > 1 if we seek to
57 avoid too small buffers and agglomerate
58 blocks on only a few ranks) */
59 cs_lnum_t block_size; /* Basic block size */
60
62
63/*=============================================================================
64 * Public function prototypes
65 *============================================================================*/
66
67/*----------------------------------------------------------------------------
68 * Compute block size and rank info for use with a block distribution.
69 *
70 * arguments:
71 * rank_id <-- id of local rank
72 * n_ranks <-- number of associated ranks
73 * min_rank_step <-- minimum rank step between blocks
74 * min_block_size <-- minimum number of entities per block
75 * n_g_ents <-- total number of associated entities
76 *
77 * returns:
78 * block size and range info structure
79 *----------------------------------------------------------------------------*/
80
83 int n_ranks,
84 int min_rank_step,
85 cs_lnum_t min_block_size,
86 cs_gnum_t n_g_ents);
87
88/*----------------------------------------------------------------------------
89 * Compute block size and rank info for use with a block distribution
90 * for a new global number of entities with a given number of active
91 * ranks.
92 *
93 * arguments:
94 * rank_id <-- id of local rank (ignored in serial mode)
95 * n_ranks <-- number of associated ranks
96 * n_block_ranks <-- number of ranks associated with a block
97 * n_g_ents <-- total number of associated entities
98 *
99 * returns:
100 * block size and range info structure
101 *----------------------------------------------------------------------------*/
102
105 int n_ranks,
106 int n_block_ranks,
107 cs_gnum_t n_g_ents);
108
109/*----------------------------------------------------------------------------*/
110
112
113#endif /* __CS_BLOCK_DIST_H__ */
cs_block_dist_info_t cs_block_dist_compute_sizes(int rank_id, int n_ranks, int min_rank_step, cs_lnum_t min_block_size, cs_gnum_t n_g_ents)
Definition: cs_block_dist.cpp:91
cs_block_dist_info_t cs_block_dist_compute_sizes_nr(int rank_id, int n_ranks, int n_block_ranks, cs_gnum_t n_g_ents)
Compute block size and rank info for use with a block distribution for a new global number of entitie...
Definition: cs_block_dist.cpp:196
Definition: cs_defs.h:542
uint64_t cs_gnum_t
global mesh entity number
Definition: cs_defs.h:325
Definition: cs_defs.h:543
Definition: cs_defs.h:335
int n_ranks
Definition: cs_block_dist.h:54
int rank_step
Definition: cs_block_dist.h:55
Definition: cs_block_dist.h:59
