#include "cs_config.h"#include "cs_defs.h"#include <math.h>#include <stdlib.h>#include <time.h>#include <sys/time.h>#include <sys/resource.h>#include <unistd.h>#include "cs_timer.h"
Include dependency graph for cs_timer.cpp:Macros | |
| #define | _POSIX_C_SOURCE 200112L |
| double | cs_timer_wtime (void) |
| Return Wall clock time. More... | |
| double | cs_timer_cpu_time (void) |
| Return CPU time. More... | |
| void | cs_timer_cpu_times (double *user_time, double *system_time) |
| Return separate user and system CPU times. More... | |
| cs_timer_t | cs_timer_time (void) |
| Return a timer's value. More... | |
| cs_timer_counter_t | cs_timer_diff (const cs_timer_t *t0, const cs_timer_t *t1) |
| Compute the difference between 2 timers. More... | |
| const char * | cs_timer_wtime_method (void) |
| Return method used to return wall clock time. More... | |
| const char * | cs_timer_cpu_time_method (void) |
| Return method used to return CPU time. More... | |
| #define _POSIX_C_SOURCE 200112L |
| double cs_timer_cpu_time | ( | void | ) |
Return CPU time.
Note that in the rare case that only the minimal C library clock() method is available (see cs_timer_cpu_time_method()), at least one of the cs_timer_...() functions (possibly this one) must be called upon program start for this function to be used. In addition, in this case, time may "loop" back to 0 every multiple of 2^size_t / CLOCKS_PER_SEC seconds.
| const char * cs_timer_cpu_time_method | ( | void | ) |
| void cs_timer_cpu_times | ( | double * | user_time, |
| double * | system_time | ||
Note that in the rare case that only the minimal C library clock() method is available, this function will return -1 values.
| [out] | user_time | current user CPU usage. |
| [out] | system_time | current system CPU usage. |
| cs_timer_counter_t cs_timer_diff | ( | const cs_timer_t * | t0, |
| const cs_timer_t * | t1 | ||
| [in] | t0 | oldest timer value |
| [in] | t1 | most recent timer value |
| cs_timer_t cs_timer_time | ( | void | ) |
| double cs_timer_wtime | ( | void | ) |
| const char * cs_timer_wtime_method | ( | void | ) |
