void | cs_sat_coupling_define (const char *saturne_name, const char *boundary_cpl_criteria, const char *volume_cpl_criteria, const char *boundary_loc_criteria, const char *volume_loc_criteria, int reverse, int verbosity) |
| Define new code_saturne coupling. More...
int | cs_sat_coupling_n_couplings (void) |
cs_sat_coupling_t * | cs_sat_coupling_by_id (int coupling_id) |
void | cs_sat_coupling_all_init (void) |
void | cs_sat_coupling_initialize (void) |
| Initialization of main variables for code_saturne/code_saturne coupling. More...
void | cs_sat_coupling_locate_all (void) |
| Set the list of cells and boundary faces associated to a coupling and a cloud of point. More...
void | cs_sat_coupling_add (const char *face_cpl_sel_c, const char *cell_cpl_sel_c, const char *face_loc_sel_c, const char *cell_loc_sel_c, const char *sat_name, int reverse, int verbosity) |
void | cs_sat_coupling_add_internal (cs_sat_coupling_tag_t *tag_func, void *tag_context, const char *boundary_cpl_criteria, const char *volume_cpl_criteria, const char *boundary_loc_criteria, const char *volume_loc_criteria, float loc_tolerance, int reverse, int verbosity) |
void | cs_sat_coupling_array_exchange (int cpl_id, cs_lnum_t nbrdis, cs_lnum_t nbrloc, cs_real_t *vardis, cs_real_t *varloc) |
void | cs_sat_coupling_exchange_at_cells (cs_field_t *f, cs_real_t *rhs, cs_real_t *fimp) |
| code_saturne/code_saturne coupling using volumic source terms. More...
void | cs_sat_coupling_bnd_initialize (int *bc_type) |
| code_saturne/code_saturne boundary coupling initialization call More...
void | cs_sat_coupling_exchange_at_bnd_faces (int *bc_type, cs_real_t *dt) |
| code_saturne/code_saturne coupling using boundary conditions More...
void | cs_sat_coupling_all_finalize (void) |
void cs_sat_coupling_define |
const char * |
saturne_name, |
const char * |
boundary_cpl_criteria, |
const char * |
volume_cpl_criteria, |
const char * |
boundary_loc_criteria, |
const char * |
volume_loc_criteria, |
int |
reverse, |
int |
verbosity |
The arguments to cs_sat_coupling_define are:
- Parameters
[in] | saturne_name | matching code_saturne application name |
[in] | boundary_cpl_criteria | boundary face selection criteria for coupled faces, or nullptr |
[in] | volume_cpl_criteria | cell selection criteria for coupled cells, or nullptr |
[in] | boundary_loc_criteria | boundary face selection criteria for location (not functional) |
[in] | volume_loc_criteria | cell selection criteria for location |
[in] | reverse | reverse mode if 1 |
[in] | verbosity | verbosity level |
In the case of only 2 code_saturne instances, the 'saturne_name' argument is ignored, as there is only one matching possibility.
In case of multiple couplings, a coupling will be matched with available code_saturne instances based on the 'saturne_name' argument.
void cs_sat_coupling_locate_all |
void |
The local "support" cells and boundary faces are used to locate the values in the distant "coupled" cells and faces. Depending on the role of sender and/or receiver of the current process in the coupling, some of these sets can be empty or not.
The cell values are always located and interpolated on the distant "cells" support. The face values are located and interpolated on the distant "face" support if present, or on the distant "cell" support if not.
If the input arrays LCESUP and LFBSUP are not ordered, they will be orderd in output.
