#include "cs_defs.h"#include <float.h>#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <mpi.h>#include "bft_printf.h"#include "cs_array.h"#include "cs_blas.h"#include "cs_boundary_conditions.h"#include "cs_boundary_conditions_set_coeffs.h"#include "cs_convection_diffusion.h"#include "cs_equation_iterative_solve.h"#include "cs_face_viscosity.h"#include "cs_field_default.h"#include "cs_field_operator.h"#include "cs_field_pointer.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"#include "cs_turbulence_model.h"#include "cs_wall_distance.h"
Include dependency graph for cs_wall_distance.cpp:Functions | |
| void | cs_wall_distance (int iterns) |
| Compute distance to wall by solving a 3d diffusion equation. Solve. More... | |
| void | cs_wall_distance_yplus (cs_real_t visvdr[]) |
| Compute the dimensionless distance to the wall solving a steady transport equation. More... | |
| void | cs_wall_distance_geometric (void) |
| Computes distance to wall by a brute force geometric approach (serial only) More... | |
| cs_wall_distance_options_t * | cs_get_glob_wall_distance_options (void) |
| Provide read/write access to cs_glob_wall_distance. More... | |
| static bool | _initialized = false |
| static cs_lnum_t | n_wall = 0 |
| static cs_wall_distance_options_t | _wall_distance_options |
| const cs_wall_distance_options_t * | cs_glob_wall_distance_options = &_wall_distance_options |
Compute distance to wall.
| cs_wall_distance_options_t * cs_get_glob_wall_distance_options | ( | void | ) |
| void cs_wall_distance | ( | int | iterns | ) |
with:
| [in] | iterns | iteration number on Navier-Stokes equations |
| void cs_wall_distance_geometric | ( | void | ) |
Compute distance to wall by a brute force geometric approach (serial only)
| void cs_wall_distance_yplus | ( | cs_real_t | visvdr[] | ) |
This function solves the following steady pure convection equation on
where the vector field
is defined by:
The boundary conditions on
read:
Then the dimensionless distance is deduced by:
Then, Imposition of an amortization of Van Driest type for the LES.
is absorbed by
where
is set at 26.
| [in] | visvdr | dynamic viscosity in edge cells after driest velocity amortization |
static |
static |
| const cs_wall_distance_options_t* cs_glob_wall_distance_options = &_wall_distance_options |
static |
