8.3
cs_blas.h
1#ifndef __CS_BLAS_H__
2#define __CS_BLAS_H__
5 * BLAS (Basic Linear Algebra Subroutine) functions
30#include "cs_defs.h"
33 * External library headers
37 * Local headers
38 *----------------------------------------------------------------------------*/
40#include "cs_base.h"
41#include "cs_log.h"
43/*----------------------------------------------------------------------------*/
46
48 * Macro definitions
50
51/*============================================================================
52 * Type definitions
53 *============================================================================*/
54
55/* BLAS reduction algorithm families */
56
57typedef enum {
58
61
63
64/*============================================================================
65 * Public function prototypes
66 *============================================================================*/
67
68/*----------------------------------------------------------------------------*/
69/*
70 * \brief Print information on BLAS libraries used.
71 *
72 * \param[in] log_type log type
73 */
74/*----------------------------------------------------------------------------*/
75
76void
78
79/*----------------------------------------------------------------------------*/
80/*
81 * \brief Set the preferred BLAS reduction algorithm family.
82 *
83 * This may not be enforced for all algorithms, though it should at least
84 * be enforced for the most general functions such as \ref cs_dot.
85 *
86 * \param[in] mode BLAS mode to use
87 */
88/*----------------------------------------------------------------------------*/
89
90void
92
93/*----------------------------------------------------------------------------
94 * Constant times a vector plus a vector: y <-- ax + y
95 *
96 * parameters:
97 * n <-- size of arrays x and y
98 * a <-- multiplier for x
99 * x <-- array of floating-point values
100 * y <-- array of floating-point values
101 *----------------------------------------------------------------------------*/
102
103void
105 double a,
106 const cs_real_t *x,
107 cs_real_t *y);
108
109/*----------------------------------------------------------------------------
110 * Return the sum of a vector. For better precision, a superblock algorithm
111 * is used.
112 *
113 * parameters:
114 * n <-- size of array x
115 * x <-- array of floating-point values
116 *
117 * returns:
118 * the resulting sum
119 *----------------------------------------------------------------------------*/
120
121double
123 const cs_real_t *x);
124
125/*----------------------------------------------------------------------------
126 * Return the weighted sum of a vector. For better precision, a superblock
127 * algorithm is used.
128 *
129 * \param[in] n size of array x
130 * \param[in] w array of floating-point weights
131 * \param[in] x array of floating-point values
132 *
133 * \return the resulting weighted sum
134 *----------------------------------------------------------------------------*/
135
136double
138 const cs_real_t *w,
139 const cs_real_t *x);
140
141/*----------------------------------------------------------------------------
142 * Return the dot product of 2 vectors: x.y
143 *
144 * parameters:
145 * n <-- size of arrays x and y
146 * x <-- array of floating-point values
147 * y <-- array of floating-point values
148 *
149 * returns:
150 * dot product
151 *----------------------------------------------------------------------------*/
152
153double
155 const cs_real_t *x,
156 const cs_real_t *y);
157
158/*----------------------------------------------------------------------------
159 * Return dot products of a vector with itself: x.x
160 *
161 * parameters:
162 * n <-- size of arrays x
163 * x <-- array of floating-point values
164 *
165 * returns:
166 * dot product
167 *----------------------------------------------------------------------------*/
168
169double
171 const cs_real_t *x);
172
173/*----------------------------------------------------------------------------
174 * Return weighted dot products of a vector with itself: x.x
175 *
176 * For better precision, a superblock algorithm is used.
177 *
178 * parameters:
179 * n <-- size of arrays x
180 * w <-- array of weights
181 * x <-- array of floating-point values
182 *
183 * returns:
184 * dot product
185 *----------------------------------------------------------------------------*/
186
187double
189 const cs_real_t *w,
190 const cs_real_t *x);
191
192/*----------------------------------------------------------------------------
193 * Return the double dot product of 2 vectors: x.x, and x.y
194 *
195 * The products could be computed separately, but computing them
196 * simultaneously adds more optimization opportunities and possibly better
197 * cache behavior.
198 *
199 * parameters:
200 * n <-- size of arrays x and y
201 * x <-- array of floating-point values
202 * y <-- array of floating-point values
203 * xx --> x.x dot product
204 * xy --> x.y dot product
205 *----------------------------------------------------------------------------*/
206
207void
209 const cs_real_t *x,
210 const cs_real_t *y,
211 double *xx,
212 double *xy);
213
214/*----------------------------------------------------------------------------
215 * Return the double dot product of 3 vectors: x.y, and y.z
216 *
217 * The products could be computed separately, but computing them
218 * simultaneously adds more optimization opportunities and possibly better
219 * cache behavior.
220 *
221 * parameters:
222 * n <-- size of arrays x and y
223 * x <-- array of floating-point values
224 * y <-- array of floating-point values
225 * z <-- array of floating-point values
226 * xy --> x.y dot product
227 * yz --> x.z dot product
228 *----------------------------------------------------------------------------*/
229
230void
232 const cs_real_t *x,
233 const cs_real_t *y,
234 const cs_real_t *z,
235 double *xx,
236 double *xy);
237
238/*----------------------------------------------------------------------------
239 * Return 3 dot products of 3 vectors: x.x, x.y, and y.z
240 *
241 * The products could be computed separately, but computing them
242 * simultaneously adds more optimization opportunities and possibly better
243 * cache behavior.
244 *
245 * parameters:
246 * n <-- size of arrays x and y
247 * x <-- array of floating-point values
248 * y <-- array of floating-point values
249 * z <-- array of floating-point values
250 * xx --> x.y dot product
251 * xy --> x.y dot product
252 * yz --> y.z dot product
253 *----------------------------------------------------------------------------*/
254
255void
257 const cs_real_t *x,
258 const cs_real_t *y,
259 const cs_real_t *z,
260 double *xx,
261 double *xy,
262 double *yz);
263
264/*----------------------------------------------------------------------------
265 * Return 5 dot products of 3 vectors: x.x, y.y, x.y, x.z, and y.z
266 *
267 * The products could be computed separately, but computing them
268 * simultaneously adds more optimization opportunities and possibly better
269 * cache behavior.
270 *
271 * parameters:
272 * n <-- size of arrays x and y
273 * x <-- array of floating-point values
274 * y <-- array of floating-point values
275 * z <-- array of floating-point values
276 * xx --> x.y dot product
277 * yy --> y.y dot product
278 * xy --> x.y dot product
279 * xz --> x.z dot product
280 * yz --> y.z dot product
281 *----------------------------------------------------------------------------*/
282
283void
285 const cs_real_t *x,
286 const cs_real_t *y,
287 const cs_real_t *z,
288 double *xx,
289 double *yy,
290 double *xy,
291 double *xz,
292 double *yz);
293
294/*----------------------------------------------------------------------------
295 * Return the global dot product of 2 vectors: x.y
296 *
297 * In parallel mode, the local results are summed on the default
298 * global communicator.
299 *
300 * parameters:
301 * n <-- size of arrays x and y
302 * x <-- array of floating-point values
303 * y <-- array of floating-point values
304 *
305 * returns:
306 * dot product
307 *----------------------------------------------------------------------------*/
308
309double
311 const cs_real_t *x,
312 const cs_real_t *y);
313
314/*----------------------------------------------------------------------------
315 * Return the global dot product of a vector: x.x
316 *
317 * In parallel mode, the local results are summed on the default
318 * global communicator.
319 *
320 * parameters:
321 * n <-- size of arrays x and y
322 * x <-- array of floating-point values
323 *
324 * returns:
325 * dot product
326 *----------------------------------------------------------------------------*/
327
328double
329cs_gdot_xx(cs_lnum_t n, const cs_real_t *x);
330
331/*----------------------------------------------------------------------------
332 * Return the global double dot product of 2 vectors: x.x, and x.y
333 *
334 * The products could be computed separately, but computing them
335 * simultaneously adds more optimization opportunities and possibly better
336 * cache behavior.
337 *
338 * In parallel mode, the local results are summed on the default
339 * global communicator.
340 *
341 * parameters:
342 * n <-- size of arrays x and y
343 * x <-- array of floating-point values
344 * y <-- array of floating-point values
345 * xx --> x.x dot product
346 * xy --> x.y dot product
347 *----------------------------------------------------------------------------*/
348
349void
351 const cs_real_t *x,
352 const cs_real_t *y,
353 double *xx,
354 double *xy);
355
356/*----------------------------------------------------------------------------
357 * Return the global residual of 2 intensive vectors:
358 * 1/sum(vol) . sum(vol.x.y)
359 *
360 * parameters:
361 * n <-- size of arrays x and y
362 * vol <-- array of floating-point values
363 * x <-- array of floating-point values
364 * y <-- array of floating-point values
365 *
366 * returns:
367 * global residual
368 *----------------------------------------------------------------------------*/
369
370double
372 const cs_real_t *vol,
373 const cs_real_t *x,
374 const cs_real_t *y);
375
376/*----------------------------------------------------------------------------
377 * Return the global volume weighted mean
378 * 1/sum(vol) . sum(vol.x)
379 *
380 * parameters:
381 * n <-- size of arrays x
382 * vol <-- array of floating-point values
383 * x <-- array of floating-point values
384 *
385 * returns:
386 * global residual
387 *----------------------------------------------------------------------------*/
388
389double
391 const cs_real_t *vol,
392 const cs_real_t *x);
393
394/*----------------------------------------------------------------------------*/
395
397
398#endif /* __CS_BLAS_H__ */
double cs_gmean(cs_lnum_t n, const cs_real_t *vol, const cs_real_t *x)
Return the global spacial average of an intensive vectors: 1/sum(vol) . sum(x.vol)
Definition: cs_blas.cpp:1828
double cs_dot_wxx(cs_lnum_t n, const cs_real_t *w, const cs_real_t *x)
Definition: cs_blas.cpp:1535
void cs_axpy(cs_lnum_t n, double a, const cs_real_t *x, cs_real_t *y)
double cs_dot(cs_lnum_t n, const cs_real_t *x, const cs_real_t *y)
Return the dot product of 2 vectors: x.y.
Definition: cs_blas.cpp:1495
void cs_gdot_xx_xy(cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, double *xx, double *xy)
Definition: cs_blas.cpp:1769
double cs_gdot_xx(cs_lnum_t n, const cs_real_t *x)
Definition: cs_blas.cpp:1741
void cs_dot_xy_yz(cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, const cs_real_t *z, double *xx, double *xy)
double cs_weighted_sum(cs_lnum_t n, const cs_real_t *w, const cs_real_t *x)
Definition: cs_blas.cpp:1438
double cs_dot_xx(cs_lnum_t n, const cs_real_t *x)
Return dot products of a vector with itself: x.x.
Definition: cs_blas.cpp:1516
void cs_dot_xx_xy_yz(cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, const cs_real_t *z, double *xx, double *xy, double *yz)
cs_blas_reduce_t
Definition: cs_blas.h:57
@ CS_BLAS_REDUCE_KAHAN
Definition: cs_blas.h:60
@ CS_BLAS_REDUCE_SUPERBLOCK
Definition: cs_blas.h:59
void cs_blas_set_reduce_algorithm(cs_blas_reduce_t mode)
Definition: cs_blas.cpp:1312
void cs_dot_xx_yy_xy_xz_yz(cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, const cs_real_t *z, double *xx, double *yy, double *xy, double *xz, double *yz)
double cs_gres(cs_lnum_t n, const cs_real_t *vol, const cs_real_t *x, const cs_real_t *y)
Return the global residual of 2 intensive vectors: 1/sum(vol) . sum(x.y.vol)
Definition: cs_blas.cpp:1803
void cs_dot_xx_xy(cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, double *xx, double *xy)
double cs_sum(cs_lnum_t n, const cs_real_t *x)
Definition: cs_blas.cpp:1384
void cs_blas_library_info(cs_log_t log_type)
Definition: cs_blas.cpp:1284
double cs_gdot(cs_lnum_t n, const cs_real_t *x, const cs_real_t *y)
Return the global dot product of 2 vectors: x.y.
Definition: cs_blas.cpp:1715
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
Definition: cs_defs.h:335
cs_log_t
Definition: cs_log.h:48
