8.3
cs_blas.h File Reference
+ Include dependency graph for cs_blas.h:
Enumerations
enum  cs_blas_reduce_t { CS_BLAS_REDUCE_SUPERBLOCK , CS_BLAS_REDUCE_KAHAN }
void cs_blas_library_info (cs_log_t log_type)
 Print information on BLAS libraries used. More...
void cs_blas_set_reduce_algorithm (cs_blas_reduce_t mode)
 Set the preferred BLAS reduction algorithm family. More...
void cs_axpy (cs_lnum_t n, double a, const cs_real_t *x, cs_real_t *y)
double cs_sum (cs_lnum_t n, const cs_real_t *x)
double cs_weighted_sum (cs_lnum_t n, const cs_real_t *w, const cs_real_t *x)
double cs_dot (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y)
 Return the dot product of 2 vectors: x.y. More...
double cs_dot_xx (cs_lnum_t n, const cs_real_t *x)
 Return dot products of a vector with itself: x.x. More...
double cs_dot_wxx (cs_lnum_t n, const cs_real_t *w, const cs_real_t *x)
void cs_dot_xx_xy (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, double *xx, double *xy)
void cs_dot_xy_yz (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, const cs_real_t *z, double *xx, double *xy)
void cs_dot_xx_xy_yz (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, const cs_real_t *z, double *xx, double *xy, double *yz)
void cs_dot_xx_yy_xy_xz_yz (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, const cs_real_t *z, double *xx, double *yy, double *xy, double *xz, double *yz)
double cs_gdot (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y)
 Return the global dot product of 2 vectors: x.y. More...
double cs_gdot_xx (cs_lnum_t n, const cs_real_t *x)
void cs_gdot_xx_xy (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, double *xx, double *xy)
double cs_gres (cs_lnum_t n, const cs_real_t *vol, const cs_real_t *x, const cs_real_t *y)
 Return the global residual of 2 intensive vectors: 1/sum(vol) . sum(x.y.vol) More...
double cs_gmean (cs_lnum_t n, const cs_real_t *vol, const cs_real_t *x)
 Return the global spacial average of an intensive vectors: 1/sum(vol) . sum(x.vol) More...
◆ cs_blas_reduce_t
Enumerator
Reduction based on l3superblock60 algorithm, described in [8]
Reduction based on Kahan's compensated summation, described in [12]
◆ cs_axpy()
void cs_axpy ( cs_lnum_t  n,
double  a,
const cs_real_t x,
cs_real_t y
◆ cs_blas_library_info()
void cs_blas_library_info ( cs_log_t  log_type)
[in]log_typelog type
◆ cs_blas_set_reduce_algorithm()
void cs_blas_set_reduce_algorithm ( cs_blas_reduce_t  mode)
This may not be enforced for all algorithms, though it should at least be enforced for the most general functions such as cs_dot.
[in]modeBLAS mode to use
◆ cs_dot()
double cs_dot ( cs_lnum_t  n,
const cs_real_t x,
const cs_real_t y
[in]nsize of arrays x and y
[in]xarray of floating-point values
[in]yarray of floating-point values
dot product
◆ cs_dot_wxx()
double cs_dot_wxx ( cs_lnum_t  n,
const cs_real_t w,
const cs_real_t x
◆ cs_dot_xx()
double cs_dot_xx ( cs_lnum_t  n,
const cs_real_t x
For better precision, a superblock algorithm is used.
[in]nsize of array x
dot product
◆ cs_dot_xx_xy()
void cs_dot_xx_xy ( cs_lnum_t  n,
const cs_real_t x,
const cs_real_t y,
double *  xx,
double *  xy
◆ cs_dot_xx_xy_yz()
void cs_dot_xx_xy_yz ( cs_lnum_t  n,
const cs_real_t x,
const cs_real_t y,
const cs_real_t z,
double *  xx,
double *  xy,
double *  yz
◆ cs_dot_xx_yy_xy_xz_yz()
void cs_dot_xx_yy_xy_xz_yz ( cs_lnum_t  n,
const cs_real_t x,
const cs_real_t y,
const cs_real_t z,
double *  xx,
double *  yy,
double *  xy,
double *  xz,
double *  yz
◆ cs_dot_xy_yz()
void cs_dot_xy_yz ( cs_lnum_t  n,
const cs_real_t x,
const cs_real_t y,
const cs_real_t z,
double *  xx,
double *  xy
◆ cs_gdot()
double cs_gdot ( cs_lnum_t  n,
const cs_real_t x,
const cs_real_t y
In parallel mode, the local results are summed on the default global communicator.
dot product
◆ cs_gdot_xx()
double cs_gdot_xx ( cs_lnum_t  n,
const cs_real_t x
◆ cs_gdot_xx_xy()
void cs_gdot_xx_xy ( cs_lnum_t  n,
const cs_real_t x,
const cs_real_t y,
double *  xx,
double *  xy
◆ cs_gmean()
double cs_gmean ( cs_lnum_t  n,
const cs_real_t vol,
const cs_real_t x
[in]volarray of floating-point values
global residual
◆ cs_gres()
double cs_gres ( cs_lnum_t  n,
const cs_real_t x,
const cs_real_t y
global residual
◆ cs_sum()
double cs_sum ( cs_lnum_t  n,
const cs_real_t x
◆ cs_weighted_sum()
double cs_weighted_sum ( cs_lnum_t  n,
const cs_real_t w,
const cs_real_t x
