Files | |
| file | cs_alge_headers.h [code] |
| file | cs_bad_cells_regularisation.cpp |
| file | cs_bad_cells_regularisation.h [code] |
| file | cs_balance.cpp |
| Wrapper to the function which adds the explicit part of the convection/diffusion terms of a transport equation of a field. | |
| file | cs_balance.h [code] |
| file | cs_balance_by_zone.cpp |
| file | cs_balance_by_zone.h [code] |
| file | cs_benchmark.cpp |
| file | cs_benchmark.h [code] |
| file | cs_benchmark_cuda.h [code] |
| file | cs_benchmark_matrix.cpp |
| file | cs_benchmark_matrix.h [code] |
| file | cs_blas.cpp |
| file | cs_blas.h [code] |
| file | cs_blas_cuda.h [code] |
| file | cs_bw_time_diff.cpp |
| file | cs_bw_time_diff.h [code] |
| file | cs_cell_to_vertex.cpp |
| Cell to vertex interpolation.. | |
| file | cs_cell_to_vertex.h [code] |
| file | cs_convection_diffusion.cpp |
| Convection-diffusion operators. | |
| file | cs_convection_diffusion.h [code] |
| file | cs_convection_diffusion_priv.h [code] |
| file | cs_divergence.cpp |
| file | cs_divergence.h [code] |
| file | cs_face_viscosity.cpp |
| Face viscosity. | |
| file | cs_face_viscosity.h [code] |
| file | cs_gradient.cpp |
| file | cs_gradient.h [code] |
| file | cs_gradient_boundary.cpp |
| Gradient reconstruction at boundaries and associated functions. | |
| file | cs_gradient_boundary.h [code] |
| file | cs_gradient_priv.h [code] |
| file | cs_grid.cpp |
| file | cs_grid.h [code] |
| file | cs_matrix.cpp |
| Sparse Matrix Representation and Operations. | |
| file | cs_matrix.h [code] |
| file | cs_matrix_assembler.cpp |
| Incremental or general construction of matrix structure. | |
| file | cs_matrix_assembler.h [code] |
| file | cs_matrix_assembler_priv.h [code] |
| file | cs_matrix_building.cpp |
| file | cs_matrix_building.h [code] |
| file | cs_matrix_default.cpp |
| file | cs_matrix_default.h [code] |
| file | cs_matrix_hypre.cpp |
| Sparse Matrix Representation and Operations using HYPRE. | |
| file | cs_matrix_hypre.h [code] |
| file | cs_matrix_hypre_priv.h [code] |
| file | cs_matrix_petsc.cpp |
| Sparse Matrix Representation and Operations using PETSc. | |
| file | cs_matrix_petsc.h [code] |
| file | cs_matrix_petsc_priv.h [code] |
| file | cs_matrix_priv.h [code] |
| file | cs_matrix_spmv.cpp |
| Sparse Matrix SpMV kernels. | |
| file | cs_matrix_spmv.h [code] |
| file | cs_matrix_spmv_cuda.h [code] |
| Sparse Matrix SpMV operations with CUDA. | |
| file | cs_matrix_tuning.cpp |
| file | cs_matrix_tuning.h [code] |
| file | cs_matrix_util.cpp |
| file | cs_matrix_util.h [code] |
| file | cs_multigrid.cpp |
| file | cs_multigrid.h [code] |
| file | cs_multigrid_smoother.cpp |
| file | cs_multigrid_smoother.h [code] |
| file | cs_param_amg.cpp |
| file | cs_param_amg.h [code] |
| Routines to handle the set of parameters for algebraic multigrids (AMG) like boomerAMG of the HYPRE library, GAMG of the PETSc library or the Notay's K-cycle (in-house implementation) for instance. | |
| file | cs_param_mumps.cpp |
| file | cs_param_mumps.h [code] |
| Routines and structure to handle the MUMPS setup. The structure is used as a context structure of a cs_param_sles_t structure. | |
| file | cs_param_saddle.cpp |
| Handle the settings of saddle-point systems. These systems arise from the monolithic coupling of the Navier-Stokes equations or in mixed formulation of scalar-valued equations. | |
| file | cs_param_saddle.h [code] |
| file | cs_param_sles.cpp |
| file | cs_param_sles.h [code] |
| Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs_param_sles_t structure. | |
| file | cs_param_sles_setup.cpp |
| file | cs_param_sles_setup.h [code] |
| Routines to handle the setup of SLES relying on a cs_param_sles_t structure. | |
| file | cs_saddle_solver.cpp |
| Set of functions to solve saddle-point problems. | |
| file | cs_saddle_solver.h [code] |
| file | cs_saddle_solver_setup.cpp |
| file | cs_saddle_solver_setup.h [code] |
| Routines to handle the setup of SLES relying on a cs_param_saddle_t structure. | |
| file | cs_sles.cpp |
| Sparse linear equation solver driver. | |
| file | cs_sles.h [code] |
| file | cs_sles_amgx.cpp |
| handling of AmgX-based linear solvers | |
| file | cs_sles_amgx.h [code] |
| file | cs_sles_default.cpp |
| file | cs_sles_default.h [code] |
| file | cs_sles_hypre.cpp |
| handling of HYPRE-based linear solvers | |
| file | cs_sles_hypre.h [code] |
| file | cs_sles_it.cpp |
| file | cs_sles_it.h [code] |
| file | cs_sles_it_cuda.h [code] |
| file | cs_sles_it_priv.cpp |
| file | cs_sles_it_priv.h [code] |
| file | cs_sles_mumps.cpp |
| Set of functions to handle the interface with the MUMPS library to solve sparse linear system with a direct approach. | |
| file | cs_sles_mumps.h [code] |
| file | cs_sles_pc.cpp |
| Sparse linear equation solver preconditioner driver and simple preconditioners. | |
| file | cs_sles_pc.h [code] |
| file | cs_sles_pc_cuda.h [code] |
| file | cs_sles_pc_priv.h [code] |
| file | cs_sles_petsc.cpp |
| file | cs_sles_petsc.h [code] |
| file | cs_vertex_to_cell.cpp |
| file | cs_vertex_to_cell.h [code] |
