1#ifndef __CS_MATRIX_PRIV_H__
2#define __CS_MATRIX_PRIV_H__
76(cs_matrix_destroy_struct_t) (
void **ms);
85(cs_matrix_copy_diagonal_t) (
const cs_matrix_t *matrix,
89(cs_matrix_get_diagonal_t)(
const cs_matrix_t *matrix);
92(cs_matrix_assembler_values_create_t) (
126typedef struct _cs_matrix_struct_native_t {
138} cs_matrix_struct_native_t;
143typedef struct _cs_matrix_struct_csr_t {
151 bool direct_assembly;
162} cs_matrix_struct_csr_t;
188typedef struct _cs_matrix_struct_dist_t {
195 cs_matrix_struct_csr_t e;
196 cs_matrix_struct_csr_t
h;
201} cs_matrix_struct_dist_t;
208typedef struct _cs_matrix_coeff_t {
249struct _cs_matrix_structure_t {
279 const char *type_name;
280 const char *type_fname;
296 unsigned int need_xa : 1;
300 const void *structure;
330 const short int *c2f_sgn;
346 cs_matrix_set_coeffs_t *set_coefficients;
347 cs_matrix_release_coeffs_t *release_coefficients;
348 cs_matrix_copy_diagonal_t *copy_diagonal;
349 cs_matrix_get_diagonal_t *get_diagonal;
351 cs_matrix_destroy_struct_t *destroy_structure;
352 cs_matrix_destroy_coeffs_t *destroy_coefficients;
353 cs_matrix_destroy_adaptor_t *destroy_adaptor;
355 cs_matrix_assembler_values_create_t *assembler_values_create;
363#if defined(HAVE_ACCEL)
380struct _cs_matrix_variant_t {
Definition: cs_defs.h:542
Definition: cs_defs.h:342
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:352
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
Definition: cs_defs.h:543
Definition: cs_defs.h:335
@ h
Definition: cs_field_pointer.h:93
@ CS_MATRIX_SPMV_N_TYPES
Definition: cs_matrix.h:100
Definition: cs_matrix.h:110
cs_matrix_fill_type_t
Definition: cs_matrix.h:72
@ CS_MATRIX_N_FILL_TYPES
Definition: cs_matrix.h:85
cs_matrix_type_t
Definition: cs_matrix.h:54
cs_alloc_mode_t
Definition: cs_mem.h:50
Definition: cs_numbering.h:87
