#include "cs_defs.h"#include <math.h>#include <stdio.h>#include "cs_base.h"#include "cs_log.h"#include "cs_parall.h"#include "cs_blas.h"
Include dependency graph for cs_blas.cpp:Functions | |
| void | cs_blas_library_info (cs_log_t log_type) |
| Print information on BLAS libraries used. More... | |
| void | cs_blas_set_reduce_algorithm (cs_blas_reduce_t mode) |
| Set the preferred BLAS reduction algorithm family. More... | |
| void | cs_axpy (cs_lnum_t n, double a, const cs_real_t *x, cs_real_t *restrict y) |
| Constant times a vector plus a vector: y <– ax + y. More... | |
| double | cs_sum (cs_lnum_t n, const cs_real_t *x) |
| double | cs_weighted_sum (cs_lnum_t n, const cs_real_t *w, const cs_real_t *x) |
| double | cs_dot (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y) |
| Return the dot product of 2 vectors: x.y. More... | |
| double | cs_dot_xx (cs_lnum_t n, const cs_real_t *x) |
| Return dot products of a vector with itself: x.x. More... | |
| double | cs_dot_wxx (cs_lnum_t n, const cs_real_t *w, const cs_real_t *x) |
| void | cs_dot_xx_xy (cs_lnum_t n, const cs_real_t *restrict x, const cs_real_t *restrict y, double *xx, double *xy) |
| Return 2 dot products of 2 vectors: x.x, and x.y. More... | |
| void | cs_dot_xy_yz (cs_lnum_t n, const cs_real_t *restrict x, const cs_real_t *restrict y, const cs_real_t *restrict z, double *xy, double *yz) |
| Return 2 dot products of 3 vectors: x.y, and y.z. More... | |
| void | cs_dot_xx_xy_yz (cs_lnum_t n, const cs_real_t *restrict x, const cs_real_t *restrict y, const cs_real_t *restrict z, double *xx, double *xy, double *yz) |
| Return 3 dot products of 3 vectors: x.x, x.y, and y.z. More... | |
| void | cs_dot_xx_yy_xy_xz_yz (cs_lnum_t n, const cs_real_t *restrict x, const cs_real_t *restrict y, const cs_real_t *restrict z, double *xx, double *yy, double *xy, double *xz, double *yz) |
| Return 5 dot products of 3 vectors: x.x, y.y, x.y, x.z, and y.z. More... | |
| double | cs_gdot (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y) |
| Return the global dot product of 2 vectors: x.y. More... | |
| double | cs_gdot_xx (cs_lnum_t n, const cs_real_t *x) |
| void | cs_gdot_xx_xy (cs_lnum_t n, const cs_real_t *x, const cs_real_t *y, double *xx, double *xy) |
| double | cs_gres (cs_lnum_t n, const cs_real_t *vol, const cs_real_t *x, const cs_real_t *y) |
| Return the global residual of 2 intensive vectors: 1/sum(vol) . sum(x.y.vol) More... | |
| double | cs_gmean (cs_lnum_t n, const cs_real_t *vol, const cs_real_t *x) |
| Return the global spacial average of an intensive vectors: 1/sum(vol) . sum(x.vol) More... | |
BLAS (Basic Linear Algebra Subroutines) type functions
| [in] | n | size of arrays x and y |
| [in] | a | multiplier for x |
| [in] | x | array of floating-point values |
| [in,out] | y | array of floating-point values |
| void cs_blas_library_info | ( | cs_log_t | log_type | ) |
| void cs_blas_set_reduce_algorithm | ( | cs_blas_reduce_t | mode | ) |
This may not be enforced for all algorithms, though it should at least be enforced for the most general functions such as cs_dot.
| [in] | mode | BLAS mode to use |
| [in] | y | array of floating-point values |
For better precision, a superblock algorithm is used.
| [in] | n | size of array x |
| void cs_dot_xx_xy | ( | cs_lnum_t | n, |
| const cs_real_t *restrict | x, | ||
| const cs_real_t *restrict | y, | ||
| double * | xx, | ||
| double * | xy | ||
The products could be computed separately, but computing them simultaneously adds more optimization opportunities and possibly better cache behavior.
| [out] | xx | x.x dot product |
| [out] | xy | x.y dot product |
| void cs_dot_xx_xy_yz | ( | cs_lnum_t | n, |
| const cs_real_t *restrict | z, | ||
| double * | xx, | ||
| double * | xy, | ||
| double * | yz | ||
| [in] | n | size of arrays x and y, and z |
| [in] | z | array of floating-point values |
| [out] | yz | y.z dot product |
| void cs_dot_xx_yy_xy_xz_yz | ( | cs_lnum_t | n, |
| double * | xx, | ||
| double * | yy, | ||
| double * | xy, | ||
| double * | xz, | ||
| double * | yz | ||
| [out] | yy | y.y dot product |
| [out] | xz | x.z dot product |
| void cs_dot_xy_yz | ( | cs_lnum_t | n, |
| double * | xy, | ||
| double * | yz | ||
In parallel mode, the local results are summed on the default global communicator.
| void cs_gdot_xx_xy | ( | cs_lnum_t | n, |
| const cs_real_t * | x, | ||
| const cs_real_t * | y, | ||
| double * | xx, | ||
| double * | xy | ||
| [in] | n | size of arrays x |
| [in] | vol | array of floating-point values |
