Routines to handle the setup of SLES relying on a cs_param_sles_t structure. More...
#include "cs_param_sles.h"
Include dependency graph for cs_param_sles_setup.h:Go to the source code of this file.
| int | cs_param_sles_setup (bool use_field_id, cs_param_sles_t *slesp) |
| Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Sparse Linear Equation Solver) More... | |
| void | cs_param_sles_setup_cvg_param (bool use_field_id, const cs_param_sles_t *slesp) |
| Update the settings associated to a cs_sles_t structure and apply those defined in the given cs_param_sles_t structure. This function is used only when a first setup has been performed. More... | |
| int cs_param_sles_setup | ( | bool | use_field_id, |
| cs_param_sles_t * | slesp | ||
| [in] | use_field_id | if false use system name to define a SLES |
| [in,out] | slesp | pointer to a cs_param_sles_t structure |
| void cs_param_sles_setup_cvg_param | ( | bool | use_field_id, |
| const cs_param_sles_t * | slesp | ||
One modifies only some specific options like the max. number of iterations or the relative tolerance
| [in] | use_field_id | if false use a name to retrieve the cs_sles_t struc. |
| [in] | slesp | pointer to a cs_param_sles_t structure |
