handling of AmgX-based linear solvers More...
#include "cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <amgx_c.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_log.h"#include "cs_fp_exception.h"#include "cs_halo.h"#include "cs_matrix.h"#include "cs_matrix_default.h"#include "cs_timer.h"#include "cs_sles.h"#include "cs_sles_amgx.h"
Include dependency graph for cs_sles_amgx.cpp:Functions | |
| cs_sles_amgx_t * | cs_sles_amgx_define (int f_id, const char *name) |
| Define and associate an AmgX linear system solver for a given field or equation name. More... | |
| cs_sles_amgx_t * | cs_sles_amgx_create (void) |
| Create AmgX linear system solver info and context. More... | |
| void * | cs_sles_amgx_copy (const void *context) |
| Create AmgX linear system solver info and context based on existing info and context. More... | |
| void | cs_sles_amgx_destroy (void **context) |
| Destroy AmgX linear system solver info and context. More... | |
| const char * | cs_sles_amgx_get_config (void *context) |
| return the configuration for an AmgX solver. More... | |
| void | cs_sles_amgx_set_config (void *context, const char *config) |
| Define the solver configuration for an AmgX solver. More... | |
| const char * | cs_sles_amgx_get_config_file (void *context) |
| return the name of the solver configuration file for an AmgX solver. More... | |
| void | cs_sles_amgx_set_config_file (void *context, const char *path) |
| Set the solver configuration file for an AmgX solver. More... | |
| bool | cs_sles_amgx_get_use_device (void *context) |
| Query whether an AmgX solver should use the device or host. More... | |
| void | cs_sles_amgx_set_use_device (void *context, bool use_device) |
| Define whether an AmgX solver should use the device or host. More... | |
| int | cs_sles_amgx_get_flags (void *context) |
| Query additional AmgX solver usage flags. More... | |
| void | cs_sles_amgx_set_flags (void *context, int flags) |
| Define additional AmgX solver usage flags. More... | |
| void | cs_sles_amgx_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| Setup AmgX linear equation solver. More... | |
| cs_sles_convergence_state_t | cs_sles_amgx_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| Call AmgX linear equation solver. More... | |
| void | cs_sles_amgx_free (void *context) |
| Free AmgX linear equation solver setup context. More... | |
| void | cs_sles_amgx_log (const void *context, cs_log_t log_type) |
| void | cs_sles_amgx_library_info (cs_log_t log_type) |
| Print information on AmgX library. More... | |
| void * cs_sles_amgx_copy | ( | const void * | context | ) |
| [in] | context | pointer to reference info and context (actual type: cs_sles_amgx_t *) |
| cs_sles_amgx_t * cs_sles_amgx_create | ( | void | ) |
| cs_sles_amgx_t * cs_sles_amgx_define | ( | int | f_id, |
| const char * | name | ||
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_amgx_create.
| [in] | name | associated name if f_id < 0, or nullptr |
| void cs_sles_amgx_destroy | ( | void ** | context | ) |
| [in,out] | context | pointer to AmgX solver info and context (actual type: cs_sles_amgx_t **) |
| void cs_sles_amgx_free | ( | void * | context | ) |
| [in,out] | context | pointer to AmgX solver info and context (actual type: cs_sles_amgx_t *) |
| const char * cs_sles_amgx_get_config | ( | void * | context | ) |
return the solver configuration for an AmgX solver.
Check the AmgX docummentation for configuration strings syntax.
| [in,out] | context | pointer to AmgX solver info and context |
| const char * cs_sles_amgx_get_config_file | ( | void * | context | ) |
Check the AmgX docummentation for configuration file syntax.
| int cs_sles_amgx_get_flags | ( | void * | context | ) |
| [in] | context | pointer to AmgX solver info and context |
| bool cs_sles_amgx_get_use_device | ( | void * | context | ) |
| void cs_sles_amgx_library_info | ( | cs_log_t | log_type | ) |
| void cs_sles_amgx_log | ( | const void * | context, |
| cs_log_t | log_type | ||
| [in] | context | pointer to AmgX solver info and context (actual type: cs_sles_amgx_t *) |
| void cs_sles_amgx_set_config | ( | void * | context, |
| const char * | config | ||
Define the configuration for an AmgX solver.
If this function is not called, a default configuration will be used.
| [in] | config | string defining configuration to use |
| void cs_sles_amgx_set_config_file | ( | void * | context, |
| const char * | path | ||
| [in] | path | path to configuration file |
| void cs_sles_amgx_set_flags | ( | void * | context, |
| int | flags | ||
| [in] | flags | flags (sum/bitwise of) for AmgX usage options. |
| void cs_sles_amgx_set_use_device | ( | void * | context, |
| bool | use_device | ||
| [in] | use_device | true for devince, false for host only |
| void cs_sles_amgx_setup | ( | void * | context, |
| const char * | name, | ||
| int | verbosity | ||
| cs_sles_convergence_state_t cs_sles_amgx_solve | ( | void * | context, |
| int | verbosity, | ||
| double | precision, | ||
| double | r_norm, | ||
| int * | n_iter, | ||
| double * | residual, | ||
| cs_real_t * | vx_ini, | ||
| cs_real_t * | vx, | ||
| size_t | aux_size, | ||
| void * | aux_vectors | ||
| [in] | a | matrix |
| aux_vectors | optional working area (internal allocation if nullptr) |
