Enumerations | |
enum | cs_field_interpolate_t { CS_FIELD_INTERPOLATE_MEAN , CS_FIELD_INTERPOLATE_GRADIENT } |
void | cs_field_gradient_scalar (const cs_field_t *f, bool use_previous_t, int inc, cs_real_3_t *grad) |
void | cs_field_gradient_scalar_array (int f_id, int inc, const cs_field_bc_coeffs_t *bc_coeffs, cs_real_t var[], cs_real_3_t grad[]) |
Compute cell gradient of scalar array using parameters associated with a given field. More... | |
void | cs_field_gradient_potential (const cs_field_t *f, bool use_previous_t, int inc, int hyd_p_flag, cs_real_3_t f_ext[], cs_real_3_t *grad) |
void | cs_field_gradient_vector (const cs_field_t *f, bool use_previous_t, int inc, cs_real_33_t *grad) |
void | cs_field_gradient_tensor (const cs_field_t *f, bool use_previous_t, int inc, cs_real_63_t *grad) |
void | cs_field_gradient_boundary_iprime_scalar (const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_t var_iprime[]) |
Compute the values of a scalar field at boundary face I' positions. More... | |
void | cs_field_gradient_boundary_iprime_vector (const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_3_t var_iprime[]) |
Compute the values of a vector field at boundary face I' positions. More... | |
void | cs_field_gradient_boundary_iprime_tensor (const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_6_t var_iprime[]) |
Compute the values of a symmetric tensor field at boundary face I' positions. More... | |
void | cs_field_interpolate (cs_field_t *f, cs_field_interpolate_t interpolation_type, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], cs_real_t *val) |
Interpolate field values at a given set of points. More... | |
void | cs_field_local_extrema_scalar (int f_id, cs_halo_type_t halo_type, cs_real_t *local_max, cs_real_t *local_min) |
Find local extrema of a given scalar field at each cell. More... | |
void | cs_field_set_volume_average (cs_field_t *f, const cs_real_t mean) |
Shift field values in order to set its spatial average to a given value. More... | |
void | cs_field_synchronize (cs_field_t *f, cs_halo_type_t halo_type) |
Synchronize current parallel and periodic field values. More... | |
void cs_field_gradient_boundary_iprime_scalar | ( | const cs_field_t * | f, |
bool | use_previous_t, | ||
cs_lnum_t | n_faces, | ||
const cs_lnum_t * | face_ids, | ||
cs_real_t | var_iprime[] | ||
[in] | f | pointer to field |
[in] | use_previous_t | should we use values from the previous time step ? |
[in] | inc | if 0, solve on increment; 1 otherwise |
[out] | grad | gradient |
void cs_field_gradient_boundary_iprime_tensor | ( | const cs_field_t * | f, |
cs_real_6_t | var_iprime[] | ||
void cs_field_gradient_boundary_iprime_vector | ( | const cs_field_t * | f, |
cs_real_3_t | var_iprime[] | ||
void cs_field_gradient_potential | ( | const cs_field_t * | f, |
int | inc, | ||
int | hyd_p_flag, | ||
cs_real_3_t | f_ext[], | ||
cs_real_3_t * | grad | ||
void cs_field_gradient_scalar | ( | const cs_field_t * | f, |
int | inc, | ||
void cs_field_gradient_scalar_array | ( | int | f_id, |
int | inc, | ||
const cs_field_bc_coeffs_t * | bc_coeffs, | ||
cs_real_t | var[], | ||
cs_real_3_t | grad[] | ||
[in] | f_id | associated field id |
[in] | bc_coeffs | boundary condition structure |
[in,out] | var | gradient's base variable |
void cs_field_gradient_tensor | ( | const cs_field_t * | f, |
int | inc, | ||
cs_real_63_t * | grad | ||
void cs_field_gradient_vector | ( | const cs_field_t * | f, |
int | inc, | ||
cs_real_33_t * | grad | ||
void cs_field_interpolate | ( | cs_field_t * | f, |
cs_field_interpolate_t | interpolation_type, | ||
cs_lnum_t | n_points, | ||
const cs_lnum_t | point_location[], | ||
const cs_real_3_t | point_coords[], | ||
cs_real_t * | val | ||
[in] | interpolation_type | interpolation type |
[in] | n_points | number of points at which interpolation is required |
[in] | point_location | location of points in mesh elements (based on the field location) |
[in] | point_coords | point coordinates |
[out] | val | interpolated values |
void cs_field_local_extrema_scalar | ( | int | f_id, |
cs_halo_type_t | halo_type, | ||
cs_real_t * | local_max, | ||
cs_real_t * | local_min | ||
This assumes the field values have been synchronized.
[in] | f_id | scalar field id |
[in] | halo_type | halo type |
[in,out] | local_max | local maximum value |
[in,out] | local_min | local minimum value |
void cs_field_set_volume_average | ( | cs_field_t * | f, |
const cs_real_t | va | ||
[in] | va | real value of volume average to be set |
[in] | va | real value of fluid volume average to be set |
void cs_field_synchronize | ( | cs_field_t * | f, |
cs_halo_type_t | halo_type | ||
This function currently only upates fields based on CS_MESH_LOCATION_CELLS.
[in,out] | f | pointer to field |
