8.3
cs_eos.hxx
1#ifndef __CS_EOS_HXX__
2#define __CS_EOS_HXX__
5 * Equation of state
35 * Local headers
40#include "cs_base.h"
42/*----------------------------------------------------------------------------*/
45 * Local Macro Definitions
49 * Structure definition
51
52/*============================================================================
53 * Global variables definition
54 *============================================================================*/
55
56/*============================================================================
57 * Public function prototypes
58 *============================================================================*/
59
60/*----------------------------------------------------------------------------
61 * Define new EOS instances
62 *
63 * parameters:
64 * EOSMethod <-- table for EOS thermo properties (CATHARE, THETIS, ...)
65 * EOSRef <-- reference table for EOS thermo properties
66 *----------------------------------------------------------------------------*/
67
68#ifdef __cplusplus
69extern "C"
70#endif
71void
72cs_eos_create(const char *EOSMethod,
73 char *EOSRef);
74
75/*----------------------------------------------------------------------------
76 * Delete EOS instances
77 *----------------------------------------------------------------------------*/
78
79#ifdef __cplusplus
80extern "C"
81#endif
82void
83cs_eos_destroy(void);
84
85/*----------------------------------------------------------------------------*/
97/*----------------------------------------------------------------------------*/
98
99#ifdef __cplusplus
100extern "C"
101#endif
102void
104 cs_phys_prop_type_t property,
105 const cs_lnum_t n_vals,
106 double var1[],
107 double var2[],
108 cs_real_t val[]);
109
110/*----------------------------------------------------------------------------*/
111
112#endif /* __CS_EOS_HXX__ */
Definition: cs_defs.h:342
Definition: cs_defs.h:335
void cs_eos_destroy(void)
Definition: cs_eos.cxx:152
void cs_phys_prop_eos(cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, double var1[], double var2[], cs_real_t val[])
Computes physical properties in (P,h,Yi) for compressible flow.
Definition: cs_eos.cxx:175
void cs_eos_create(const char *EOSMethod, char *EOSRef)
Definition: cs_eos.cxx:138
Definition: cs_physical_properties.h:42
cs_phys_prop_type_t
Definition: cs_physical_properties.h:54
